  4. How to reference a local expression inside a Shell Command
reactor
4 Posts 2 Posters 1.2k Views 2 Watching
  • SnowmanS Offline
    SnowmanS Offline
    Snowman
    Referencing an expression inside a reaction is in the form of ${{ expression }}. When referenced inside my shell command to set the watering delay duration for my Rachio sprinkler system, it just does not work.
    If I enter "86400" instead of referencing the expression lWateringDelayDuration, it works. Either I am doing something wrong or referencing an expression inside a shell command is not supported.
    Reactor version: 24212
    Local Expression
    lWateringDelayDuration =
    WDD = getEntity( "hass>input_number_h_watering_delay_duration" ).attributes.value_sensor.value,
    if WDD == 0 then 0
      elif WDD == 1 then 86400
      elif WDD == 2 then 172800
      elif WDD == 3 then 259200
      elif WDD == 4 then 345600
    endif
    Setting Reaction using Shell command
    curl -X PUT -H "Content-Type: application/json" -H "Authorization: Bearer xxxxxxxxxx -d '{ "id" : "xxxxxxxxxx", "duration" : ${{ lWateringDelayDuration}} }' https://api.rach.io/1/public/device/rain_delay
      Because of the security concerns around shell commands (which is why they are disabled by default), I never allowed substitutions. But that was also in the days when Reactor didn't have authentication and access control. Now that it does, the chance of the action being abused is reduced, so I can add substitution in shell commands to a future (soon) build. It will likely be an additional option you need to enable.
        By the way, this is probably better done using an HTTP Request action. Is there a reason you're not doing it that way?
        SnowmanS 1 Reply Last reply
          SnowmanS Offline
          SnowmanS Offline
          Snowman
          @toggledbits It never crossed my mind to use HTTP. I'll give it a try.
            1.1k
            158.3k
