  4. [ZwaveJS] Position and cover not working for Roller Shutter 1/2/3
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
37 Posts 2 Posters 13.4k Views 3 Watching
    That's wonderful. I have a FGR222 (previous fw) that's working. Here's node 3:
    cover.state=false
    energy_sensor.units="kWh"
    energy_sensor.value=0
    position.value=0
    power_sensor.units="W"
    power_sensor.value=0
    power_switch.state=true
    x_debug.dt={"entity_class":"Cover","match":"deviceClass.generic.key=17;deviceClass.specific.key=6","capabilities":["cover","toggle","position"],"primary_attribute":"cover.state","description":"Roller Shutter","model":"FGRM222","default_name":"Roller Shutter","values":[{"match":{"commandClass":38,"property":"currentValue"},"capabilities":{"cover":{"attributes":{"state":{"expr":"value !== 0"}},"actions":{"open":{"valueId":"+targetValue:#","value":99},"close":{"valueId":"+targetValue:#","value":0},"stop":{"valueId":"+Up:","value":false}}},"position":{"attributes":{"value":{"expr":"round( value / 99, 2 )"}},"actions":{"set":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( parameters.value ?# 0 ), 0 ) ) )"}},"increase":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) + ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}},"decrease":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) - ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}},"relative":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) + ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}}}},"toggle":{"actions":{"toggle":{"valueId":"+targetValue:#","value":{"expr":"entity.attributes.cover.state ? 0 : 99"}}}}}}],"manufacturerId":271,"productType":769,"productId":4097}
    x_zwave_values.Binary_Switch_currentValue=true
    x_zwave_values.Binary_Switch_targetValue=null
    x_zwave_values.Configuration_Delay_Time_After_S2=10
    x_zwave_values.Configuration_Energy_Reports=10
    x_zwave_values.Configuration_Forced_Roller_Shutter_Calibration=0
    x_zwave_values.Configuration_Lamellas_Positioning_Mode=1
    x_zwave_values.Configuration_Managing_Lamellas_in_Response_to_Alarm=0
    x_zwave_values.Configuration_Motor_Operation_Detection=1
    x_zwave_values.Configuration_Motor_Operation_Time=240
    x_zwave_values.Configuration_Periodic_Power_or_Energy_Reports=3600
    x_zwave_values.Configuration_Power_Reports=10
    x_zwave_values.Configuration_Reports_Type=0
    x_zwave_values.Configuration_Response_to_General_Alarm=0
    x_zwave_values.Configuration_Response_to_Smoke_CO_CO2_Alarm=0
    x_zwave_values.Configuration_Response_to_Temperature_Alarm=0
    x_zwave_values.Configuration_Response_to_Water_Flood_Alarm=0
    x_zwave_values.Configuration_Roller_Shutter_Operating_Modes=0
    x_zwave_values.Configuration_Scenes_Associations_Activation=1
    x_zwave_values.Configuration_Self_Measurement=0
    x_zwave_values.Configuration_Switch_Type=0
    x_zwave_values.Configuration_Turning_Time_Delay_Time=150
    x_zwave_values.Manufacturer_Proprietary_fibaro_venetianBlindsPosition=99
    x_zwave_values.Manufacturer_Specific_manufacturerId=271
    x_zwave_values.Manufacturer_Specific_productId=4097
    x_zwave_values.Manufacturer_Specific_productType=769
    x_zwave_values.Meter_reset=null
    x_zwave_values.Meter_value_65537=0
    x_zwave_values.Meter_value_66049=0
    x_zwave_values.Multilevel_Sensor_Power=0
    x_zwave_values.Multilevel_Switch_Close=null
    x_zwave_values.Multilevel_Switch_Open=null
    x_zwave_values.Multilevel_Switch_currentValue=0
    x_zwave_values.Multilevel_Switch_duration=null
    x_zwave_values.Multilevel_Switch_restorePrevious=null
    x_zwave_values.Multilevel_Switch_targetValue=0
    x_zwave_values.Protection_exclusiveControlNodeId=null
    x_zwave_values.Protection_local=0
    x_zwave_values.Protection_rf=0
    x_zwave_values.Protection_timeout=null
    x_zwave_values.Version_firmwareVersions=["24.24"]
    x_zwave_values.Version_libraryType=3
    x_zwave_values.Version_protocolVersion="3.52"
    zwave_device.capabilities=[37,38,49,50,112,114,117,134,145]
    zwave_device.endpoint=0
    zwave_device.failed=false
    zwave_device.generic_class="Multilevel Switch"
    zwave_device.impl_sig="24233:1:24233:2"
    zwave_device.is_beaming=false
    zwave_device.is_listening=true
    zwave_device.is_routing=true
    zwave_device.is_secure=false
    zwave_device.manufacturer_info=[271,769,4097]
    zwave_device.node_id=3
    zwave_device.specific_class="Motor Control Class B"
    zwave_device.status=4
    zwave_device.status_text="alive"
    zwave_device.version_info=[null,"24.24"]
    • toggledbitsT Online
      toggledbitsT Online
      OK. I think I see it. #4 has a different type and ID, and the alias has an error. Pull the new data ZIP and try again.
        That did the trick. Two things. position.value is now incosistent, whereas dimming.level was ok before. I tried to set node 4 to .9, and it's now reporting .31. A refresh is updating the position (to .91), but now power_switch.state=null.
        power_sensor.value is still 0.
          toggledbitsT Online
          What are you comparing it to? For node 4, the last data you show have the Meter class value (meterType 1, property value, propertyKey 66049) at 0, and the Multilevel Sensor with sensorType=4 (Power) also 0. What are you expecting the value to be? Again, can you show more context, too? Post all the attributes? These things are moving targets, so more data is better than less.
            I'm getting the values from ZWaveJS UI and checking on the reported values from MSR:
            Position
            Watts reading seems to be more related to the device not refreshing itself (or refreshing randomly), as it was doing on Vera. I'll keep debugging the ZWaveJS part, since it seems that if I refresh the device, the values is passed onto Reactor.
            Thanks for the help!
              toggledbitsT Online
              Sorry, but the image looks like you're showing position, not watts. I would like to understand which of the two power values provided by the device you are trying to reconcile.
              That said, a position of 0.91 would be correct, as the scale of the position.value attribute in Reactor is 0.0 to 1.0, computed from the device range of 0 to 99 (90/99 = 0.91 rounded to two digits).
                @toggledbits said in [ZwaveJS] Position and cover not working for Roller Shutter 1/2/3:
                no screenshot. As I've said, I'm finding that the device is not reporting that well. I'm 100% sure it was OK under Vera, and maybe it was part of the custom code they wrote for the device, Idk.
                ok, but I've asked for 0.90 via Reactor and I got 0.91 inside Reactor and 0.90 inside ZWaveJS. Imagine something that tries to position the device until it is OK...
                  toggledbitsT Online
                  #28
                  The rounding is a function of the scaling.
                  I believe I mentioned in another thread that comparing equality of floating point numbers is a well-known Bad Idea in pretty much all programming languages.
                  The raw value is always available in the x_ extended attributes.
                    #29
                    so, the correct way is to look for x_zwave_values.Multilevel_Switch_currentValue and divide by 100?
                    EDIT: anyway, I still think that this behavior is not OK, because value are not consistent, but the call is yours.
                      toggledbitsT Online
                      #30
                      I can change it, but it may be a breaking change for all users at this point. Not something to be taken lightly. I have considered it.
                      I still don't have enough information from you to do anything about the power issue, assuming there still is one.
                        No problem, I found it strange and I was reporting. It's also strange 'cause after a refresh the value from the controller is overwritten.
                        Yes, but it's zwavejs that's not updating. I suspect Vera was doing some magic behind the scene. I'll keep watching it, now that the new system is almost stable.
                          toggledbitsT Online
                          toggledbitsT Online
                          @therealdb said in [ZwaveJS] Position and cover not working for Roller Shutter 1/2/3:
                          I see. I guess I didn't understand that before. OK. Let me know if you figure anything out that helps. There may be something I can bolt on to help with that. There do seem to be delta-sensitivity configuration settings on the device. I wonder if those are related?
                          So for the moment, have we covered all the hot-button items? Anything I haven't addressed yet?
                            Maybe. I'm experimenting with parameter and I'll report back. I still have a couple of strange behaviors to fix before I could dedicate to fine tuning.
                            Yes, the only thing pending is tilt position. I managed to use it via raw ZWave commands, but I think it could useful to have a separate endpoint for that. RS 3 and 4 are already exposing multiple endpoints, where the first is controlling the blind and the second the lamellas (and root does nothing).
                            Unfortunately, those from Fibaro are the only ZWave devices in Europe that are supporting lamellas. I'm sure eventually Shelly will catchup with its new ZWave series from Qubino and I'll eventually replace my RS2s, since they're not ZWave+ and are 8+ years old (I bought them for the old house, where I started with just roller shutters, so they served their purpose well).
                              toggledbitsT Online
                              toggledbitsT Online
                              OK. I've lost the thread there. What's the problem with tilt at this point? In my bench-top use, changes in the Z-Wave reports feed to the position attribute correctly, so I'm not clear where the issue remains.
                                Sorry, I was referring to this thread: https://smarthome.community/topic/1576/zwavejs-venetian-blind-tilt-for-fibaro-roller-shutters-2-fgr222/4
                                  ok, meter fixed. I don't know how it worked all these years, but the associations of device 4 were completely wrong (assigned to a non-existence device), thus it was somewhat working on Vera. Go figure. I reset the values and now it's reporting ok.
                                  The very last thing about the device is that, after configuring a parameter, they support scene activation v0 and it would be nice to have a separate scene device, as in the switch. Otherwise, I'll simply go with x_zwave_values. Thanks.
                                    toggledbitsT Online
                                    Try activating the central scene on the device. Since these values are events, they aren't created until the first event is received. You may also need to refresh the browser, or at least "stimulate" the redraw of the entity list (by modifying the filters, etc.).
                                      163.7k
