  4. [ZwaveJS] Remotec zrc90 not updating Central Scene variable
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 2 Posters 938 Views 2 Watching
    Hi @toggledbits.
    After a couple of weeks, I noticed that my Remotec zrc90 isn't working as expected.
    Scenes are working in ZWaveJS, but this device has a strange behavior: the scene change, but then it's set again to null. In Reactor, this remains null:
    battery_power.level=0.7
    battery_power.since=1725817957361
    x_debug.dt={"description":"Scene master 8 button remote","model":"BW8510/ZRC-90US","default_name":"Scene master 8 button remote","manufacturerId":21076,"productType":0,"productId":34064}
    x_zwave_values.Battery_isLow=false
    x_zwave_values.Battery_level=70
    x_zwave_values.Central_Scene_scene_001=null
    x_zwave_values.Central_Scene_scene_002=null
    x_zwave_values.Central_Scene_scene_003=null
    x_zwave_values.Central_Scene_scene_004=null
    x_zwave_values.Central_Scene_scene_005=null
    x_zwave_values.Central_Scene_scene_006=null
    x_zwave_values.Central_Scene_scene_007=null
    x_zwave_values.Central_Scene_scene_008=null
    x_zwave_values.Central_Scene_slowRefresh=null
    x_zwave_values.Manufacturer_Specific_manufacturerId=21076
    x_zwave_values.Manufacturer_Specific_productId=34064
    x_zwave_values.Manufacturer_Specific_productType=1
    x_zwave_values.Version_firmwareVersions=["1.1","1.1"]
    x_zwave_values.Version_hardwareVersion=3
    x_zwave_values.Version_libraryType=2
    x_zwave_values.Version_protocolVersion="4.5"
    x_zwave_values.Wake_Up_controllerNodeId=1
    x_zwave_values.Wake_Up_wakeUpInterval=0
    zwave_device.capabilities=[91,114,128,132,134]
    zwave_device.endpoint=0
    zwave_device.failed=false
    zwave_device.generic_class="Remote Controller"
    zwave_device.impl_sig="24242:1:22315:1"
    zwave_device.is_beaming=false
    zwave_device.is_listening=false
    zwave_device.is_routing=false
    zwave_device.is_secure=false
    zwave_device.manufacturer_info=[21076,1,34064]
    zwave_device.node_id=154
    zwave_device.specific_class="Simple Remote Control"
    zwave_device.status=2
    zwave_device.status_text="awake"
    zwave_device.version_info=[null,"1.1"]
    zwave_device.wakeup_interval=0
    Anything I could look at? Thanks.
      Add monitor_nodes: [154] to your ZWaveJSController config. Then restart Reactor and activate just one button on the device.
      ZWaveJSController forces a separate log stream file named xxxx.log, where xxxx is the controller ID, so capture that file and upload it to me along with the xxxx_154_monitor.json file. I'll DM you a link.
        I'll keep this instruction for the future. I got frustrated, reset the device and paired it again and it's now reporting good when changed. I tried everything before the inevitable dance. Who knows what was corrupted. Guess "it's just Zwave"™️ Thanks.
          163.8k
