  4. Unusual zwavejs entity naming convention
2 Posts 1 Posters 885 Views 1 Watching
  • SnowmanS Offline
    SnowmanS Offline
    Snowman
    @toggledbits I have noticed after upgrading both Reactor and ZWaveJSController to version 24257 that two of my devices/entities, TILT-ZWAVE2.5-ECO and Zooz ZSE18, had their entity re-named in an unusual way and also appears to be duplicated.
    Reactor version 24257
    ZWaveJSController version 24257
    Z-Wave JS UI version 9.18.1
    zwave-js version 13.2.0
    Vestibule Motion Sensor State attributes/partial screenshot of entities it created. All entities have the same attributes.
    motion_sensor.state=true
    x_zwave_values.Notification_Home_Security_Motion_sensor_status=8
    zwave_device.capabilities=[113]
    zwave_device.endpoint=0
    zwave_device.failed=null
    zwave_device.manufacturer_info=null
    zwave_device.node_id=23
    zwave_device.valueId=[113,"Notification","Home Security","Home Security","Motion sensor status","Motion sensor status"]
    zwave_device.version_info=null
    Tilt Sensor Door State and Tilt Sensor Door State Simple attributes/partial screenshot of entities it created. All entities have similar attributes with exception of x_zwave_values.Notification_Access_Control_Door_State = 22 or 23.
    tilt_sensor.state=true
    x_zwave_values.Notification_Access_Control_Door_state=22
    zwave_device.node_id=24
    zwave_device.valueId=[113,"Notification","Access Control","Access Control","Door state","Door state"]
    x_zwave_values.Notification_Access_Control_Door_state_simple=22
    zwave_device.valueId=[113,"Notification","Access Control","Access Control","Door state (simple)","Door state (simple)"]
    tilt_sensor.state=false
    x_zwave_values.Notification_Access_Control_Door_state=23
    x_zwave_values.Notification_Access_Control_Door_state_simple=23
    • SnowmanS Offline
      SnowmanS Offline
      Snowman
      @toggledbits It appears the ZIP file you provided me with to fix the TILT-ZWAVE2.5-ECO tilt_sensor.state issue also fixed this topic. I do not see the unusual entity names. Thanks
