(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up).
Bare metal latest-26328
Issue 1: Nodes don't update in Reactor after update from 26318.
Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start.
Notice: No device mapping matches Intrusion Sensor.
I don't know if you still support EzloController but seems like an easy fix?
Let me know if you need more info!
[latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online.
[latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2]
[latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-]
at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153)
at /home/homebridge/reactor/server/lib/EzloController.js:1388:48
at process.processTicksAndRejections (node:internal/process/task_queues:104:5)
[latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2"
[latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2"
[latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-]
[latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-]
at /home/homebridge/reactor/server/lib/EzloController.js:1649:58
at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226)
at /home/homebridge/reactor/server/lib/EzloController.js:1418:54
[latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-]
[latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-]
[latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped
[latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-]
[latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-]
[latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped
[latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms
[latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328.
Bare metal latest-26318.
I tried to add the group "ArmedSensors" but it would not show in UI.
"ArmedSensors":
- include_capability: arming
filter_expression: entity.attributes.arming.state
The log:
[latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-]
[latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-]
at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18)
at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43)
at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13)
at async Promise.allSettled (index 3)
Nothing related before or after that I could find.
I then copied an existing group to exclude type errors in the new group.
"OKforLarm":
name: OK för Larm
"OKforLarm2":
name: "OK för Larm 2"
Same error in log.
[latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-]
[latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-]
[latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-]
[latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-]
Let me know if I missed something or you need more info.
authtrack:
max_attempts: 4
EDIT: some logs
reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
ZWaveJSController - Warning/Error Traceback - Registering action set volume for Aeotec Siren 6 (ZW164)
@toggledbits Since I have upgraded ZWaveJSController to 24293 from 24257 I am seeing entries related to registering action set_volume, but action is not defined by the capability 143 every time I restart Reactor.
The Siren seems to be doing what it is supposed to do. The volume levels are fine. Should I worry about it?
Reactor version 24302
ZWaveJSController version 24293
Z-Wave JS UI version 9.27.4
zwave-js version 14.3.4[latest-24302]2024-11-22T02:10:32.852Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 143 endpoint 0 (entity "143-0") [latest-24302]2024-11-22T02:10:32.854Z <Entity:WARN> Entity#zwavejs>143-1 registering action set_volume, but action is not defined by the capability [latest-24302]2024-11-22T02:10:32.855Z <Entity:CRIT> Error: Traceback [-] Error: Traceback at Entity.registerAction (/opt/reactor/server/lib/Entity.js:703:288) at ZWaveJSController._register_node (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1689:112) at ZWaveJSController._register_nodes (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1401:84) at ZWaveJSController._process_init_data (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:844:38) at /var/reactor/ext/ZWaveJSController/ZWaveJSController.js:774:39 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-24302]2024-11-22T02:10:32.859Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 143 endpoint 1 (entity "143-1") [latest-24302]2024-11-22T02:10:32.860Z <Entity:WARN> Entity#zwavejs>143-2 registering action set_volume, but action is not defined by the capability [latest-24302]2024-11-22T02:10:32.861Z <Entity:CRIT> Error: Traceback [-] Error: Traceback at Entity.registerAction (/opt/reactor/server/lib/Entity.js:703:288) at ZWaveJSController._register_node (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1689:112) at ZWaveJSController._register_nodes (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1401:84) at ZWaveJSController._process_init_data (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:844:38) at /var/reactor/ext/ZWaveJSController/ZWaveJSController.js:774:39 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-24302]2024-11-22T02:10:32.864Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 143 endpoint 2 (entity "143-2") [latest-24302]2024-11-22T02:10:32.866Z <Entity:WARN> Entity#zwavejs>143-3 registering action set_volume, but action is not defined by the capability [latest-24302]2024-11-22T02:10:32.866Z <Entity:CRIT> Error: Traceback [-] Error: Traceback at Entity.registerAction (/opt/reactor/server/lib/Entity.js:703:288) at ZWaveJSController._register_node (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1689:112) at ZWaveJSController._register_nodes (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1401:84) at ZWaveJSController._process_init_data (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:844:38) at /var/reactor/ext/ZWaveJSController/ZWaveJSController.js:774:39 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-24302]2024-11-22T02:10:32.870Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 143 endpoint 3 (entity "143-3") [latest-24302]2024-11-22T02:10:32.871Z <Entity:WARN> Entity#zwavejs>143-4 registering action set_volume, but action is not defined by the capability [latest-24302]2024-11-22T02:10:32.872Z <Entity:CRIT> Error: Traceback [-] Error: Traceback at Entity.registerAction (/opt/reactor/server/lib/Entity.js:703:288) at ZWaveJSController._register_node (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1689:112) at ZWaveJSController._register_nodes (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1401:84) at ZWaveJSController._process_init_data (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:844:38) at /var/reactor/ext/ZWaveJSController/ZWaveJSController.js:774:39 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-24302]2024-11-22T02:10:32.876Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 143 endpoint 4 (entity "143-4") [latest-24302]2024-11-22T02:10:32.878Z <Entity:WARN> Entity#zwavejs>143-5 registering action set_volume, but action is not defined by the capability [latest-24302]2024-11-22T02:10:32.878Z <Entity:CRIT> Error: Traceback [-] Error: Traceback at Entity.registerAction (/opt/reactor/server/lib/Entity.js:703:288) at ZWaveJSController._register_node (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1689:112) at ZWaveJSController._register_nodes (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1401:84) at ZWaveJSController._process_init_data (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:844:38) at /var/reactor/ext/ZWaveJSController/ZWaveJSController.js:774:39 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-24302]2024-11-22T02:10:32.881Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 143 endpoint 5 (entity "143-5") [latest-24302]2024-11-22T02:10:32.883Z <Entity:WARN> Entity#zwavejs>143-6 registering action set_volume, but action is not defined by the capability [latest-24302]2024-11-22T02:10:32.884Z <Entity:CRIT> Error: Traceback [-] Error: Traceback at Entity.registerAction (/opt/reactor/server/lib/Entity.js:703:288) at ZWaveJSController._register_node (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1689:112) at ZWaveJSController._register_nodes (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1401:84) at ZWaveJSController._process_init_data (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:844:38) at /var/reactor/ext/ZWaveJSController/ZWaveJSController.js:774:39 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-24302]2024-11-22T02:10:32.887Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 143 endpoint 6 (entity "143-6") [latest-24302]2024-11-22T02:10:32.888Z <Entity:WARN> Entity#zwavejs>143-7 registering action set_volume, but action is not defined by the capability [latest-24302]2024-11-22T02:10:32.889Z <Entity:CRIT> Error: Traceback [-] Error: Traceback at Entity.registerAction (/opt/reactor/server/lib/Entity.js:703:288) at ZWaveJSController._register_node (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1689:112) at ZWaveJSController._register_nodes (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1401:84) at ZWaveJSController._process_init_data (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:844:38) at /var/reactor/ext/ZWaveJSController/ZWaveJSController.js:774:39 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-24302]2024-11-22T02:10:32.892Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 143 endpoint 7 (entity "143-7") [latest-24302]2024-11-22T02:10:32.893Z <Entity:WARN> Entity#zwavejs>143-8 registering action set_volume, but action is not defined by the capability [latest-24302]2024-11-22T02:10:32.894Z <Entity:CRIT> Error: Traceback [-] Error: Traceback at Entity.registerAction (/opt/reactor/server/lib/Entity.js:703:288) at ZWaveJSController._register_node (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1689:112) at ZWaveJSController._register_nodes (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:1401:84) at ZWaveJSController._process_init_data (/var/reactor/ext/ZWaveJSController/ZWaveJSController.js:844:38) at /var/reactor/ext/ZWaveJSController/ZWaveJSController.js:774:39 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-24302]2024-11-22T02:10:32.896Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 143 endpoint 8 (entity "143-8") -
Harmless. Just a warning. I'll see about quieting it for the next build.
T toggledbits unlocked this topic on
