  2. How-To
  3. [How-to] Managing holidays in Reactor
Apple Home Automation Issue
Build 24343 has fully HTTP actions, so cool things could be created (see docs). I've recently changed a couple of cams because better definition and I've found tha Reolink has a couple of cams that have spotlights. While the spotlights are driven by motion (so the cam could record in color), I wanted to drive them directly, so in case of any "security" event, like alarm on, door open, etc, I could use the lights to have a better video and make - you know - light. So, if you want to use HTTP actions in VirtualController, just go to config, entities under your VirtualEntityController section in reactor.yaml, and add this: - id: cams_retro_spotlights name: "Retro Cam - Spotlights" template: Binary Switch # update the status at interval http_request: interval: 900 # 15m url: "http://192.168.1.31/cgi-bin/api.cgi?user=foo&password=foo" method: "POST" force_json: true headers: "Content-Type": "application/json" "Accept": "application/json" body: '[{"cmd": "GetWhiteLed", "action": 0 , "param": { "channel": 0 }}]' capabilities: power_switch: attributes: state: expr: "isnull( response ) ? null : response[0]?.value?.WhiteLed?.state == 1" default: false actions: "on": http_request: url: "http://192.168.1.31/cgi-bin/api.cgi?user=foo&password=foo" method: "POST" force_json: true headers: "Content-Type": "application/json" "Accept": "application/json" body: '[{"cmd": "SetWhiteLed", "param": { "WhiteLed": {"bright" : 100, "channel": 0, "mode": 1, "state": 1}}}]' target: state expr: "isnull( response ) ? null: response[0]?.value?.rspCode == '200'" "off": http_request: url: "http://192.168.1.31/cgi-bin/api.cgi?user=foo&password=foo" method: "POST" force_json: true headers: "Content-Type": "application/json" "Accept": "application/json" body: '[{"cmd": "SetWhiteLed", "param": { "WhiteLed": {"bright" : 100, "channel": 0, "mode": 1, "state": 0}}}]' target: state expr: "isnull( response ) ? null : response[0]?.value?.rspCode == '200' ? false : null" Reolink has API where you have to post a JSON and the response will give you a JSON (in theory). It's not really JSON, so force_json: true will do the trick for you. I'm lefting this as an example of cool things you could do with the new capabilites added/documented in 24343. HTH.
So, it was time for me to move from Vera to something modern. It served me well, but I have new devices I want to add and old that I want to fully use. I have 3 weeks off in August, so plenty of times to tweak things. Long story short, I moved and turned off my two Veras (one prod, one dev). Hardware: Zwave.me controller, updated to FW 5.39, SDK 6.28.1 (it is necessary, since my Veras have the latest FW available). I opted for a 500 controller because of all the drama with 700/800 and the need to stay on something stable. I have 60 Zwave devices, so starting from scratch was a big no for me. I started from this famous guide, after taking a backup from the Vera Prod to the Vera Dev: https://github.com/rafale77/Z-Way But it was not working. So, the route I went is: Go the Vera UI and go under Settings/Z-wave settings, take a screenshot (HouseId in particular). take a backup from the prod system extract the file /etc/cmh/user_data.json.lzo from the backup move the file to the /tmp directory of your dev system execute pluto-lzo d /tmp/user_data.json.lzo /tmp/user_data.json open and edit the file, looking for a port node with something like /dev.. and put /dev/ttyACM0 inside. save the file. run pluto-lzo c /tmp/user_data.json /tmp/user_data.json.lzo copy the .lzo file to the backup, in the same position insert the Zwave key into the USB of your dev Vera reboot the dev Vera wait a lot for it to finish ️ it will probably say that it cannot start ZWave, don't worry Go the Vera UI and go under Settings/Z-wave settings, you should see the old HouseId. Anyway, double check with the screenshot you took previously: if it matches, you've moved your Zwave Network to the new controller! Shutdown the Veras, take the USB Key with your ZWave network and move it to ZwaveJS! I've installed it via Docker, very easy. Go for ZwaveJS UI, so you got the UI as well. Interview the nodes, have patience. Some battery nodes will need wake-ups, others will complete automatically. I had to re-pair a couple of devices because of incorrect pairing with Vera (security and non-security mixed together). In this case, pro tip: reset the device, and then use the replace function from ZWave JS, to have the same node id. Now, if you're already running under Reactor, you'll need to rewrite all your logic. I asked ChatGPT to write me a Powershell script to get the device from the Veras and build the new naming convention. The logic is that AltId in Vera is in fact the ZWave Node ID, and on Reactor you'll get device like zwavejs>nodeid-endpoint (ie: 95-0, 95-1, etc). So, I built a script that replaced all the occurrences from the storage of Reactor (did I mentioned to do a lot of backups?) and set the name via ZwaveJS MQTT apis. Then, I build an Excel file (thanks ChatGPT!) and renamed all the endpoints in Reactor (manually, no APIs to do so). It took me about an hour. Now, no more trip/untrip lost along the radios, and a blazing fast ZWave network to enjoy. Since a couple of devices are recognized in a different way, I had to re-write a couple of rules (and wait a couple of fix here and there by @toggledbits for devices not properly recognized, thanks!), but I was OK in a couple of days, and ready to run by the first afternoon, so I maintained an high WAF. Now, I could experiment the joy of SmartStart and proprietary commands. Thanks to the people that moved before me, inspired me and to @toggledbits for the incredible platform that has built in the latest years! Feel free to ask question if you need help.
HTTPS
X
Car integration
      @therealdb I have mine broken out like this:
      The trick for the normal FOH wash is this:
      If any of those are TRUE, the default is overruled and the holiday lighting takes over.
      My current issue is with Thanksgiving and Christmas as they rely on a floating Thursday (the fourth one in November). Thanksgiving lighting goes from 11/01 to the end of the fourth Thursday. Christmas starts on the Friday immediately following Thanksgiving Thursday.
        @gwp1 That's not too different from Easter. I have another virtual switch for the current program (as a string). it's set to default unless a specific program is found. My logic is quite easy:
        • at 1 am, get the current holiday via webcal.guru/fixed dates. save it to a virtual entity.
        • try to match current holiday with pre-defined light programs. save the value to a virtual entity.
        • when dark, cycle every 15 minutes and randomize lights according to the current light program.
        For Christmas Time after Thanksgiving, you could set a virtual entity/global variable (Christmas Time) to true when it's Thanksgiving and run the corresponding lights only if both are not true. Then, the day after, you'll still have the variable/entity to true, but a different holiday. I have a fixed Christmas Time (1 Dec to 6 Jan), because that's the range we usually have in Italy, so it's easier for me.
        I was thinking of creating a specific Controller for Holiday Lights, integrated with webcal.guru or similar, but I fear what every one of us is doing is quite different.
          162.2k
          1.3k
