  2. How-To
  3. Super newbie here. Need help with lots of stuff
Apple Home Automation Issue
Build 24343 has fully HTTP actions, so cool things could be created (see docs). I've recently changed a couple of cams because better definition and I've found tha Reolink has a couple of cams that have spotlights. While the spotlights are driven by motion (so the cam could record in color), I wanted to drive them directly, so in case of any "security" event, like alarm on, door open, etc, I could use the lights to have a better video and make - you know - light. So, if you want to use HTTP actions in VirtualController, just go to config, entities under your VirtualEntityController section in reactor.yaml, and add this: - id: cams_retro_spotlights name: "Retro Cam - Spotlights" template: Binary Switch # update the status at interval http_request: interval: 900 # 15m url: "http://192.168.1.31/cgi-bin/api.cgi?user=foo&password=foo" method: "POST" force_json: true headers: "Content-Type": "application/json" "Accept": "application/json" body: '[{"cmd": "GetWhiteLed", "action": 0 , "param": { "channel": 0 }}]' capabilities: power_switch: attributes: state: expr: "isnull( response ) ? null : response[0]?.value?.WhiteLed?.state == 1" default: false actions: "on": http_request: url: "http://192.168.1.31/cgi-bin/api.cgi?user=foo&password=foo" method: "POST" force_json: true headers: "Content-Type": "application/json" "Accept": "application/json" body: '[{"cmd": "SetWhiteLed", "param": { "WhiteLed": {"bright" : 100, "channel": 0, "mode": 1, "state": 1}}}]' target: state expr: "isnull( response ) ? null: response[0]?.value?.rspCode == '200'" "off": http_request: url: "http://192.168.1.31/cgi-bin/api.cgi?user=foo&password=foo" method: "POST" force_json: true headers: "Content-Type": "application/json" "Accept": "application/json" body: '[{"cmd": "SetWhiteLed", "param": { "WhiteLed": {"bright" : 100, "channel": 0, "mode": 1, "state": 0}}}]' target: state expr: "isnull( response ) ? null : response[0]?.value?.rspCode == '200' ? false : null" Reolink has API where you have to post a JSON and the response will give you a JSON (in theory). It's not really JSON, so force_json: true will do the trick for you. I'm lefting this as an example of cool things you could do with the new capabilites added/documented in 24343. HTH.
So, it was time for me to move from Vera to something modern. It served me well, but I have new devices I want to add and old that I want to fully use. I have 3 weeks off in August, so plenty of times to tweak things. Long story short, I moved and turned off my two Veras (one prod, one dev). Hardware: Zwave.me controller, updated to FW 5.39, SDK 6.28.1 (it is necessary, since my Veras have the latest FW available). I opted for a 500 controller because of all the drama with 700/800 and the need to stay on something stable. I have 60 Zwave devices, so starting from scratch was a big no for me. I started from this famous guide, after taking a backup from the Vera Prod to the Vera Dev: https://github.com/rafale77/Z-Way But it was not working. So, the route I went is: Go the Vera UI and go under Settings/Z-wave settings, take a screenshot (HouseId in particular). take a backup from the prod system extract the file /etc/cmh/user_data.json.lzo from the backup move the file to the /tmp directory of your dev system execute pluto-lzo d /tmp/user_data.json.lzo /tmp/user_data.json open and edit the file, looking for a port node with something like /dev.. and put /dev/ttyACM0 inside. save the file. run pluto-lzo c /tmp/user_data.json /tmp/user_data.json.lzo copy the .lzo file to the backup, in the same position insert the Zwave key into the USB of your dev Vera reboot the dev Vera wait a lot for it to finish ️ it will probably say that it cannot start ZWave, don't worry Go the Vera UI and go under Settings/Z-wave settings, you should see the old HouseId. Anyway, double check with the screenshot you took previously: if it matches, you've moved your Zwave Network to the new controller! Shutdown the Veras, take the USB Key with your ZWave network and move it to ZwaveJS! I've installed it via Docker, very easy. Go for ZwaveJS UI, so you got the UI as well. Interview the nodes, have patience. Some battery nodes will need wake-ups, others will complete automatically. I had to re-pair a couple of devices because of incorrect pairing with Vera (security and non-security mixed together). In this case, pro tip: reset the device, and then use the replace function from ZWave JS, to have the same node id. Now, if you're already running under Reactor, you'll need to rewrite all your logic. I asked ChatGPT to write me a Powershell script to get the device from the Veras and build the new naming convention. The logic is that AltId in Vera is in fact the ZWave Node ID, and on Reactor you'll get device like zwavejs>nodeid-endpoint (ie: 95-0, 95-1, etc). So, I built a script that replaced all the occurrences from the storage of Reactor (did I mentioned to do a lot of backups?) and set the name via ZwaveJS MQTT apis. Then, I build an Excel file (thanks ChatGPT!) and renamed all the endpoints in Reactor (manually, no APIs to do so). It took me about an hour. Now, no more trip/untrip lost along the radios, and a blazing fast ZWave network to enjoy. Since a couple of devices are recognized in a different way, I had to re-write a couple of rules (and wait a couple of fix here and there by @toggledbits for devices not properly recognized, thanks!), but I was OK in a couple of days, and ready to run by the first afternoon, so I maintained an high WAF. Now, I could experiment the joy of SmartStart and proprietary commands. Thanks to the people that moved before me, inspired me and to @toggledbits for the incredible platform that has built in the latest years! Feel free to ask question if you need help.
HTTPS
X
Car integration
5 Posts 5 Posters 2.0k Views 5 Watching
    amnd
    PerHP 1 Reply Last reply
    • A amnd
      Hello amnd,
      It seems to me that the appropriate "assistant" for you is "Home Assistant". 😉
      HA is an automation system that has integrations for a lot of IoT devices, and the latest versions is getting much easier to set up as well.
      It is however an open source project, which means that it may be a challenge to get going if you have no experience with things like raspberry Pi's or Linux.
      HA is also working on their own controller, but as of now people mostly run it on mini-PC's or similar.
      if you're completely green on electronics and coding, perhaps Homey is a better bet.
      when you have a system like this, you can connect to appliances and IoT in different ways, it all depends on how smart the devices are, and how the company that makes them integrates to other systems.
      Regarding speakers, you get all kinds of wifi speaker systems, depending on where an how you want it.
      Most automation controllers can be reached from outside the home through an app. This system can in practice be your alarm system if you connect motion and door/window sensors. 🙂
        Concur on all points.
          Welcome to the forum!
          Before you start buying stuff, it might be best to be clear in your own mind exactly what you want to be able to achieve. You've clearly done some thinking already, but lack of any actual experience may well lead you down the wrong path. So start with a modest set of requirements: let's say, lighting. This will allow you to experiment and experience some of the Home Automation issues that you may run across without spending a huge amount of money.
          Do you have existing infrastructure which needs to be compatible? Are you, perhaps, in an Apple ecosystem? Or more of an Android guy?
          There are, indeed, choices to be made. Even lighting, which sounds simple, isn't. Do you have clusters of lights the ceilings, controlled by one switch currently, or perhaps also a number of separate single work lights in several areas? They each demand a different approach. Wall switches may allow WiFi controlled relays be placed behind wall plates. Separate bulbs are perhaps more amenable to being replaced by radio-controlled bulbs such as Philips Hue, or equivalent.
          Then you have to think about how to integrate these things, and there are many options. By experimenting in a relatively small way you will find out what suits you and then be in a position to scale up.
          Good luck. There is lots of expertise here which is best tapped by asking specific questions, so it helps if you can provide details about your location, constraints, and your own expertise.
          • L Offline
            L Offline
            LouisBoles
            well have you ever thought about hiring someone to save your life? 😄
              162.2k
              1.3k
