Bare metal latest-26318.
I tried to add the group "ArmedSensors" but it would not show in UI.
"ArmedSensors":
- include_capability: arming
filter_expression: entity.attributes.arming.state
The log:
[latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-]
[latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-]
at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18)
at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43)
at process.processTicksAndRejections (node:internal/process/task_queues:104:5)
at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13)
at async Promise.allSettled (index 3)
Nothing related before or after that I could find.
I then copied an existing group to exclude type errors in the new group.
"OKforLarm":
name: OK för Larm
"OKforLarm2":
name: "OK för Larm 2"
Same error in log.
[latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-]
[latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-]
[latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-]
[latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-]
Let me know if I missed something or you need more info.
authtrack:
max_attempts: 4
EDIT: some logs
reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
OpenAI Controller for Reactor
As the title says, here's my OpenAI Controller for Reactor:
It supports both OpenAI and Azure OpenAI endpoints. You'll need keys/endpoints, according to each service.
The controller supports multiple models, and each one could be mapped as an entity.- id: openai name: OpenAI implementation: OpenAIController enabled: true config: models: - id: openai name: OpenAI GPT-4 model: gpt-4 service: openai api_key: xxxxx # taken from your OpenAI dashboard max_tokens: 2000 # default temperature: 0.5 # default top_p: 1 # default frequency_penalty: 0 # default presence_penalty: 0 # default stop: null # default - id: azure name: Azure GPT-4 model: gpt-4 service: azure endpoint: "https://XXX.openai.azure.com/openai/deployments/gpt-4o/chat/completions?api-version=2023-03-15-preview" # taken from your Azure GPT-4 service api_key: xxxx # taken from Azure max_tokens: 2000 # default temperature: "0.5" # default top_p: 1 # default frequency_penalty: 0 # default presence_penalty: 0 # default stop: null # defaultIt's quite easy to use, and responses can be stored in variables, for easy access. Or sent to another action (Text To Speech, another endpoint, etc).
Have fun with LLM into your scenes!
Thanks to @toggledbits for guidance and the new option to capture response from actions into variables. It was quite fun to write this controller!
T toggledbits unlocked this topic on
