And then MSR...
My first issue: I'm logged into the msr CT as reactor (I used the suggested username just to keep things simple as this is new space for me and I was high off my success of migrating HA over).
When I run
docker pull toggledbits/reactor:latest-amd64... it assigns the \reactor\ subdirectory where installed root ownership. I am absolutely logged in with the correct non-root user.
Second issue: I copied over the following folders:
When MSR loads, all of my Global Expressions are missing.
Third issue:
All controllers connect wonderfully (Hubitat, etc)... except HA.
After changing ownership of the logs to reactor again I can see this when MSR calls HA:
Yes, I created a fresh new long-lived access token for the MSR containerized install and updated the reactor.yaml config file correctly.
Honestly, all-in-all, for my total lack of expertise here I'm very pleased that I only have these three issues. But they are def blockers atm.
My RPi bare metal install of MSR hooked right up to the new HA and is humming along just fine (I used hostnames were possible and shuffled some IPs in other places so I wouldn't run into things later that were mapped incorrectly that I'd forgotten about.)
Proxmox 8.3.2 MSR lives in an Ubuntu 24.04 Proxmox container MSR is latest docker versionWhat else can I provide to those smarter than me here?
Hi
I was looking at an old rule and I wanted to edit it, to add another Constraint, however I cannot seem to do it.
On this screen shot you can see an existing entry in the Constraints and on its pull down menu the "Changes" option is available.
However on the new line I just added I have no changes option in its pull down menu.
Here is the original now locked post about this topic.
https://smarthome.community/topic/395/contact-sensor-opened-1-minute-ago-how?_=1736354690742
If you look on the old screen shots on that post, I was using the "changes" operator. Like this:
However today when I edited this rule the operators are showing as == and not as changes on all the entries in the Constraints area.
Also the old entries now say -- and the value is blank. But on the new line I just added it says that is not valid, so not sure how the old lines are like that.
So I am a bit confused what happened.
Home Assistant up to version 2021.8.6 supported; the online version of the manual will now state the current supported versions; Fix an error in OWMWeatherController that could cause it to stop updating; Unify the approach to entity filtering on all hub interface classes (controllers); this works for device entities only; it may be extended to other entities later; Improve error detail in messages for EzloController during auth phase; Add isRuleSet() and isRuleEnabled() functions to expressions extensions; Implement set action for lock and passage capabilities (makes them more easily scriptable in some cases); Fix a place in the UI where 24-hour time was not being displayed.@toggledbits I understand that you do not perform testing on Mac computers but thought I'd share the following with you in case something can be done.
I started seeing these errors with version 24302. I thought that upgrading to 24343 would have fixed the issue but unfortunately not. I either have to close the browser or clear the cache for the errors to stop popping-up but they slowly come back.
I see these errors on the following browsers:
Safari 16.6.1 on macOS Big Sur Safari 18.1.1 on MacOS Sonoma DuckDuckGo 1.118.0 on macOS Big Sur and Sonoma Firefox 133.0.3 on macOS Big Sur Chrome 131.0.6778 on macOS Big SurHere are the errors
Safari while creating/updating an expression
@http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:543:91 makeExprMenu@http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:537:28 @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:92:64 @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:89:68 each@http://192.168.0.13:8111/node_modules/jquery/dist/jquery.min.js:2:3133 @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:89:35 @http://192.168.0.13:8111/client/MessageBus.js:98:44 forEach@[native code] @http://192.168.0.13:8111/client/MessageBus.js:95:54 @http://192.168.0.13:8111/client/MessageBus.js:106:44 @http://192.168.0.13:8111/client/Observable.js:78:28 signalModified@http://192.168.0.13:8111/reactor/en-ca/lib/js/ee.js:146:21 signalModified@http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:40:29 reindexExpressions@http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:71:32 @http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:608:40 dispatch@http://192.168.0.13:8111/node_modules/jquery/dist/jquery.min.js:2:40040DuckDuckGo while clicking on status
http://192.168.0.13:8111/reactor/en-ca/lib/js/reactor-ui-status.js:789:44 asyncFunctionResume@[native code] saveGridLayout@[native code] dispatchEvent@[native code] _triggerEvent@http://192.168.0.13:8111/node_modules/gridstack/dist/gridstack.js:1401:30 _triggerAddEvent@http://192.168.0.13:8111/node_modules/gridstack/dist/gridstack.js:1383:31 makeWidget@http://192.168.0.13:8111/node_modules/gridstack/dist/gridstack.js:968:30 addWidget@http://192.168.0.13:8111/node_modules/gridstack/dist/gridstack.js:388:24 placeWidgetAdder@http://192.168.0.13:8111/reactor/en-ca/lib/js/reactor-ui-status.js:183:44Firefox while updating a rule
@http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:543:91 makeExprMenu@http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:537:28 @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:92:64 @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:89:68 each@http://192.168.0.13:8111/node_modules/jquery/dist/jquery.min.js:2:3133 @http://192.168.0.13:8111/reactor/en-ca/lib/js/reaction-editor.js:89:35 @http://192.168.0.13:8111/client/MessageBus.js:98:44 forEach@[native code] @http://192.168.0.13:8111/client/MessageBus.js:95:54 @http://192.168.0.13:8111/client/MessageBus.js:106:44 @http://192.168.0.13:8111/client/Observable.js:78:28 notifySaved@http://192.168.0.13:8111/reactor/en-ca/lib/js/ee.js:82:21 notifySaved@http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:47:26 @http://192.168.0.13:8111/reactor/en-ca/lib/js/reactor-ui-rules.js:1460:39 forEach@[native code] @http://192.168.0.13:8111/reactor/en-ca/lib/js/reactor-ui-rules.js:1459:58Chrome while creating/updating an expression
TypeError: Cannot read properties of undefined (reading 'getEditor') at RuleEditor.makeExprMenu (http://192.168.0.13:8111/reactor/en-ca/lib/js/rule-editor.js:1788:86) at Object.handler (http://192.168.0.13:8111/reactor/en-ca/lib/js/rule-editor.js:2174:54) at http://192.168.0.13:8111/client/MessageBus.js:98:44 at Array.forEach (<anonymous>) at MessageBus._sendToBus (http://192.168.0.13:8111/client/MessageBus.js:95:54) at MessageBus.send (http://192.168.0.13:8111/client/MessageBus.js:106:44) at ExpressionEditor.publish (http://192.168.0.13:8111/client/Observable.js:78:28) at ExpressionEditor.signalModified (http://192.168.0.13:8111/reactor/en-ca/lib/js/ee.js:146:14) at ExpressionEditor.signalModified (http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:40:15) at ExpressionEditor.reindexExpressions (http://192.168.0.13:8111/reactor/en-ca/lib/js/expression-editor.js:71:18) ``Not sure that it is the same issue but just got this on built 24302 when running a reaction for testing purpose. Despite the error message, the reaction ran properly.
Error: Command timeout (195 start_reaction)
at _ClientAPI._commandTimeout (http://192.168.2.163:8111/client/ClientAPI.js:552:136)
Thanks to @toggledbits for adding a custom CSS. I've started doing a darker Reactor style.
Here's the file: https://gist.github.com/dbochicchio/825098ac13b7f8cac22012eae37ff7ce
A couple of things are still too bright and I'll eventually catch-up. Just place it under your /config directory, naming the file as customstyles.css. Hard refresh your browser.
Hi
Having to rebuild my Linux Debian box as the SSD failed. And I have forgotten exactly what I did the first time to get it all setup.
I have Debian 12 up and running on the new SSD, I only have console no Desktop GUI.
I am trying to do the bare metal install for MSR. However I am not sure if I am meant to install nodejs whlist logged in as the root user or as the none root user with my name ?
I used putty and connected via SSH and logged in as root and I installed nodejs but I think this was wrong as when logged in as my user name and I do a node -v command it says node is not installed or doesn't show any version number anyway.
But when logged in as root and I do a node -v command it does show me its installed and displays the version number. maybe its a path issue for my username and he can't see node is installed?
So now I am thinking I should of installed node whilst logged in as my user name and not as the root user.
This is how I installed nodejs as whilst logged in as root
Thanks in advance.
As the title says, here's my OpenAI Controller for Reactor:
OpenAI Controller per Reactor. Contribute to dbochicchio/reactor-openai development by creating an account on GitHub.
It supports both OpenAI and Azure OpenAI endpoints. You'll need keys/endpoints, according to each service.
The controller supports multiple models, and each one could be mapped as an entity.
It's quite easy to use, and responses can be stored in variables, for easy access. Or sent to another action (Text To Speech, another endpoint, etc).
Have fun with LLM into your scenes!
In Home Assistant I have an integration that if I add entities to it, I will get the following error in MSR as certain entity values I'm using in expressions are null for a moment. This is more or less cosmetic issue and happens very rarely as I rarely modify that integration on the hass side.
And the expression is
Could I "wrap" hass-entity shown above somewhat differently to prevent this error from happening? Using build 24302.
Hello
I am trying to set up Multi System Reactor to automate routines across multiple smart home devices & platforms (e.g., Home Assistant, SmartThings, and Hubitat). While I have successfully linked the systems; I am facing issues with:
-Delays in triggering actions on secondary devices.
-Inconsistent execution of complex logic conditions.
-Synchronization of states between devices when one system updates.
Is there a recommended way to optimize performance & confirm seamless state sharing across systems?
I have checked https://smarthome.community/category/22/multi-system-reactor-msbi guide for reference but still need advice.
Any tips on debugging or log analysis to pinpoint where the issue arises would also be appreciated.
Thank you !
I've managed to use MSR UI on iOS devices to some degree*, so that although UI elements (e.g. rule sets) are not visible in portrait mode, you've seen them in landscape. Now with recents builds (24302) this does not work anymore, elements (rule sets, entities) are not anymore visible in landscape mode.
Does anyone have similar experiences? Using iOS 18 and Safari/Chrome browser.
( *Drag & drop of rule conditions have never worked on a mobile)
@toggledbits Since I have upgraded ZWaveJSController to 24293 from 24257 I am seeing entries related to registering action set_volume, but action is not defined by the capability 143 every time I restart Reactor.
The Siren seems to be doing what it is supposed to do. The volume levels are fine. Should I worry about it?
Reactor version 24302
ZWaveJSController version 24293
Z-Wave JS UI version 9.27.4
zwave-js version 14.3.4
I have the following ACL defined:
groups: admin: users: - admin applications: true api_acls: # This ACL allows users in the "admin" group to access the API - url: "/api" group: admin allow: true log: true # This ACL allows anyone/thing to access the /api/v1/alive API endpoint - url: "/api/v1/alive" allow: trueAnd I have authenticated to MSR as "admin" user. However, I'm getting "access denied" when trying to access http://*******:8111/api/v1/log
So what I'm missing, is my ACL incorrectly defined?
Using build 24302 on Docker.
Hi
I have just connected a bunch of EzloPi controllers to MSR to import some ESP based devices etc.
They all seemed to have worked and imported in to MSR apart from I have one missing device. It is a Digital Gas Sensor device.
This is how that device looks in the Ezlo API.
Devices Info:
_id: "10696001" deviceTypeId: "ezlopi" parentDeviceId: "10696000" category: "level_sensor" subcategory: "" gatewayId: "457a5069" batteryPowered: false name: "Gas Sensor Digital" type: "sensor" reachable: true persistent: true serviceNotification: false armed: false roomId: "" security: "no" ready: true status: "idle" parentRoom: true protectConfig: "default"Items Info:
_id: "20696001" deviceId: "10696001" hasGetter: true hasSetter: false name: "smoke_density" show: true valueType: "substance_amount" scale: "parts_per_million" value: 2.7472610473632812 valueFormatted: "2.75" status: "idle"There is also an Analog Gas sensor that one did import in to MSR OK.
Devices Info:
_id: "10696000" deviceTypeId: "ezlopi" parentDeviceId: "10696000" category: "security_sensor" subcategory: "gas" gatewayId: "457a5069" batteryPowered: false name: "Gas Sensor Analog" type: "sensor" reachable: true persistent: true serviceNotification: false armed: false roomId: "" security: "no" ready: true status: "idle" parentRoom: true protectConfig: "default"Items Info:
_id: "20696000" deviceId: "10696000" hasGetter: true hasSetter: false name: "gas_alarm" show: true valueType: "token" enum: 0: "no_gas" 1: "combustible_gas_detected" 2: "toxic_gas_detected" 3: "unknown" valueFormatted: "no_gas" value: "no_gas" status: "idle"And this is how this MQ2 Gas Sensor looks like on their dashboard:
Digital
Analog
They have an EzloPi website here you can create your own sensor projects using ESP boards, which is very interesting stuff!
And I just wrote on the Ezlo forum here, how to connect an EzloPi controller to MSR.
THANKS.
A couple of things for you @toggledbits, since you mentioned that this release has new features and some tweaks are expected.
Local expressions cannot be deleted. Pushing the X button has no effect for me.
When cloning an entity action, the result is strange (first is cloned one, second is the original action):
When changing the action on the cloned element, the params are added to the original one. See screenshot:
Dark theme has a couple of strange contrasts. One is visible in the previous screenshots (white text on yellow background). Another one is in groups (blue text on blue background):
Overall, I found blue, yellow, red and green (in buttons and forms) to be too bright.
On the bright side:
I love the new script action: thank you! The dark theme is a great start to avoid getting blinded at night I promise I'll try very soon the new features around actions. Thanks!Migrating MSR to Docker on Proxmox
- Zero issues installing Proxmox on a new MiniPC.
- Zero issues migrating my HA instance over to the new hotness (I know, I was surprised, too!)
And then MSR...
msr
CT asreactor
(I used the suggested username just to keep things simple as this is new space for me and I was high off my success of migrating HA over).When I run
root
When MSR loads, all of my Global Expressions are missing.Third issue:
After changing ownership of the logs toreactor
again I can see this when MSR calls HA:[latest-24366]2025-01-12T00:03:43.128Z <HubitatController:INFO> HubitatController#hubitat successful connection to ws://192.168.1.214/eventsocket [latest-24366]2025-01-12T00:03:43.151Z <HubitatController:NOTICE> HubitatController#hubitat current mode is Evening (2) [latest-24366]2025-01-12T00:03:43.212Z <HubitatController:NOTICE> HubitatController#hubitat HSM status is disarmed [latest-24366]2025-01-12T00:03:43.214Z <Controller:NOTICE> Controller HubitatController#hubitat is now online. [latest-24366]2025-01-12T00:03:43.255Z <MQTTController:INFO> MQTTController#mqtt2 connected; opening subscriptions [latest-24366]2025-01-12T00:03:43.371Z <MQTTController:INFO> MQTTController#mqtt2 sending inits and going online! [latest-24366]2025-01-12T00:03:43.373Z <Controller:NOTICE> Controller MQTTController#mqtt2 is now online. [latest-24366]2025-01-12T00:03:47.179Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.123:8123/api/websocket [latest-24366]2025-01-12T00:03:47.180Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error] connect ECONNREFUSED 192.168.1.123:8123 [-] [latest-24366]2025-01-12T00:03:47.180Z <HassController:WARN> HassController#hass ws error code ECONNREFUSED [latest-24366]2025-01-12T00:03:47.180Z <HassController:NOTICE> HassController#hass websocket to ws://192.168.1.123:8123/api/websocket closed during open/negotiation [latest-24366]2025-01-12T00:03:47.180Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error] connect ECONNREFUSED 192.168.1.123:8123 [-] [latest-24366]2025-01-12T00:03:52.181Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.123:8123/api/websocket [latest-24366]2025-01-12T00:03:52.183Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error] connect ECONNREFUSED 192.168.1.123:8123 [-] [latest-24366]2025-01-12T00:03:52.183Z <HassController:WARN> HassController#hass ws error code ECONNREFUSED [latest-24366]2025-01-12T00:03:52.183Z <HassController:NOTICE> HassController#hass websocket to ws://192.168.1.123:8123/api/websocket closed during open/negotiation [latest-24366]2025-01-12T00:03:52.183Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error] connect ECONNREFUSED 192.168.1.123:8123 [-]
reactor.yaml
config file correctly.Honestly, all-in-all, for my total lack of expertise here I'm very pleased that I only have these three issues. But they are def blockers atm.
- Proxmox 8.3.2
- MSR lives in an Ubuntu 24.04 Proxmox container
- MSR is latest docker version
