  4. Access to log file viewer denied
6 Posts 2 Posters 1.9k Views 2 Watching
    I have the following ACL defined:
    groups:
      admin:
        users:
          - admin
        applications: true
    api_acls:
      # This ACL allows users in the "admin" group to access the API
      - url: "/api"
        group: admin
        allow: true
        log: true
      # This ACL allows anyone/thing to access the /api/v1/alive API endpoint
      - url: "/api/v1/alive"
        allow: true
    And I have authenticated to MSR as "admin" user. However, I'm getting "access denied" when trying to access http://*******:8111/api/v1/log
    So what I'm missing, is my ACL incorrectly defined?
    Using build 24302 on Docker.
      groups:
        admin:
          users:
            - admin
          applications: true
      api_acls:
        - url: "/api"
          group: admin
          allow: true
          log: true
          allow: true
      @tunnus said in Access to log file viewer denied:
      ...for the Reactor UI. That login doesn't apply to the API, or to the dashboard, which have separate access paths and therefore require separate authentication.
      There are several methods described in the docs for providing auth on API requests. See Access Control.
        @toggledbits the same ACL configuration works for the dashboard, if I'm authenticated to "general" UI, it does not ask for a new authentication. But if needed, it (dashboard) will redirect to login screen whereas this (log viewer) won't.
          There's an authentication taking place there, you just don't see it. It is also managed by the applications, not by the browser. The API is a separate beast, and the Reactor UI and dashboard do not use the API to do any work, they have their own channel. There's a reason the ACL section you are working in is called api_acls and not just acls.
            Could you help me to fix my ACL configuration so that admin user would also authenticate to this log viewer?
              1. If you change nothing in the ACL configuration, you can add the username and password for access to the query URL as request parameters. The specifics of this are described in the documentation (under Access Control).
              2. You can modify the ACL to allow anonymous access but restrict the source IP address to whatever host(s) you use.
                154.4k
