  4. Trouble Configuring Multi-System Reactor Logic Across Devices
4 Posts 4 Posters 1.3k Views 4 Watching
    gregbowers
    wrote on last edited by gregbowers
    Hello
    I am trying to set up Multi System Reactor to automate routines across multiple smart home devices & platforms (e.g., Home Assistant, SmartThings, and Hubitat). While I have successfully linked the systems; I am facing issues with:
    -Delays in triggering actions on secondary devices.
    -Inconsistent execution of complex logic conditions.
    -Synchronization of states between devices when one system updates.
    Is there a recommended way to optimize performance & confirm seamless state sharing across systems?
    I have checked https://smarthome.community/category/22/multi-system-reactor-[msbi](https://www.igmguru.com/data-science-bi/msbi-certification-training) guide for reference but still need advice.
    Any tips on debugging or log analysis to pinpoint where the issue arises would also be appreciated.
    Thank you !
      First I would check MSR logs to see if any errors are showing up and check. I would also check your controller logs as well
      • G gregbowers
        Hello
        Thank you !
        @gregbowers I'm not sure how the ad for Power Apps pertains to MSR even though the two links were cleverly framed to look like a single link.
        *Hubitat C-7 2.5.2.135
        Core 2026.10.1
        MSR: latest-26287-0a7107d5
          @gwp1 I removed the link. Let's see if @gregbowers is a bot or not 🙂
            147.1k
