  4. Rule Set UI bug - SOLUTION
The reaction stopped working (Google Nest max playing a video)
[Reactor] Variables not updating correctly in latest-25201-2aa18550
[Reactor] Copy&Paste of Rules
I don't know if I'm the only one, but managing more than one Reactor installs, the need to have some sort of copy&paste for rules has grown on me. While I understand the technical challenges, I'm wondering if a "god mode" where I could copy the raw JSON rule and paste it into another rule could be an advanced, flag only feature that could benefit power users. I know I can copy the JSON file and proceed, but I must stop Reactor and when doing maintenance, it's more clicks to do. Just an idea
[MSR] reactor-mqtt-contrib package for additional MQTT templates
I'm slowly migrating all my stuff to MQTT under MSR, so I have a central place to integrate everything (and, in a not-so-distant future, to remove virtual devices from my Vera and leave it running zwave only). Anyway, here's my reactor-mqtt-contrib package: https://github.com/dbochicchio/reactor-mqtt-contrib Simply download yaml files (everything or just the ones you need) and you're good to go. I have mapped my most useful devices, but I'll add others soon. Feel free to ask for specific templates, since I've worked a lot in the last weeks to understand and operate them. The templates are supporting both init and query, so you have always up-to-date devices at startup, and the ability to poll them. Online status is supported as well, so you can get disconnected devices with a simple expression. Many-many thanks to @toggledbits for its dedication, support, and patience with me and my requests
[Reactor] Help with screne controller cycling logic
I’ve added a couple of Shelly Wave i4 as scene controllers and I’m planning to add more, since I can just use standard buttons instead of battery-powered scene controllers, which also looks better aesthetically. That said, I’m struggling to figure out how to write a simple rule that cycles between states every time I press a button. Example: Light 1 ON → OFF, then Light 2 ON → OFF. The part I can’t get right is handling the case where Light 1 or Light 2 might already be ON independently of the rule. Maybe it’s just too much sun and relaxation clouding my brain, but any hint would be appreciated.
Stop the MSR by an external switch on Hubitat.
Use case: When performing home maintenance, such as air conditioning, I want all rules involving air conditioning to be disabled. To do this, to day, I have a virtual switch that I placed within all rules involving air conditioning, meaning that if I turn it off, none of them work. Then another situation: the water pump system and garden irrigation, another switch. In short, I had to create several virtual switches in Hubitat to disable rules in MSR. Unfortunately, however, I was unable to cover all scenarios, so I wondered if it would be possible for MSR to support a virtual MSR switch, which, when configured in the reactor settings, would function as a general on/off switch for MSR. If it is configured and turned off, the entire rules and actions in MSR stops working, except for the status change reading process, specifically for this switch, which, when turned on, would restart the MSR. Would it be possible to do something like this? Any recommendations from the experts?
Expose MSR entities
Probably a really dumb question. Currently I am using the owntracks_sensor for tracking phones being in region in MSR and it works great. Digging around with Home Assistant and toying with some dashboards, is there any way of exposing that sensor to HA trivially? I could set MSR to trip a virtual switch in OpenLuup which can then be exposed to HA (with all my other Vera devices) but that feels a bit in-elegant if I can do it directly. Any thoughts? Apologies if the ask is not clear/ TIA C
Comment in Globa Expressions
Tom_DT
I have several Global Expressions that are set by a rule so the definition area is blank. I'd like to add a comment in this area that explains what is setting the value. Commenting in this area breaks the remote setting. Any way to document what is setting the GE?
Gradually turn on lights.
Tom_DT
I have several lights that I would like to turn on very gradually over 15 or 20 seconds. from 0 to .25 in .01 increments. I have tried a few things that came nowhere near working, so here I am.
Can't customize home page
I foolishly let my system wipe all cookies this morning and with it my settings for my MSR home page. Once logged back in I can no longer remove errant panes nor is the + available to add new ones. Brave Browser v1.80.122 (Jul 16, 2025) What have I done?! Will check other browsers on my M1. UPDATE: Safari exhibits same behaviour. I've tried both sans last-four public key entry and with - no change.
Error After Upgrade
Reset attribute value of entity in event handler
Need help figuring out how to delay a reset on reaction
Way to search for rules (rule state) in other rules
@toggledbits, not sure if this is a feature request or I'm using the search tool wrong. You have a "Search for rule" in the Rules Set tab in MSR. It works nicely to find a rule and bring up said rule, but can it/could it be used for as a "where used?" global search? For instance, I have a fairly large set of rules, divided up into 10 different rulesets. There's easily a hundred individual rules, and many of the rules have Rule State triggers, which of course refer to other rules. Amongst my troubleshooting today, I came across what may have been a duplicate or troubleshooting attempt, but I can't tell if it's actually used as a Rule State in another rule without opening each rule that I suspect it may be a part of. Thanks.
Links to MSR from HA
Tom_DT
I am using Home Assistant a lot recently. On a dashboard showing the devices, I would like to show a link to the MSR rule that controls the devices. Is there a way to link directly into MSR?
Set Reaction > Script Action
Errors after updating to MQTTController build 25139
I'm running MSR build 25139 on Docker, using MQTT controller 24293, and everything working as expected. But if I try to upgrade to MQTTController build 25139, I'm getting the following errors on MSR UI: An Entity Attribute condition in "Lay-Z-Spa auto heating off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.god Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa auto heating off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute temperature_sensor.green Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa filter pump auto off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute temperature_sensor.red Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa filter pump auto run" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.pump Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa watchdog" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.status Last 11:20:37 My MQTT configuration (local_mqtt_devices.yaml) for the related entity is: layzspa_message: type: ValueSensor capabilities: ["temperature_sensor", "value_sensor", "power_sensor"] primary_attribute: power_sensor.value events: "layzspa/message": "power_sensor.value": json_payload: true if_expr: '! isnull( payload?.PWR )' expr: "float(payload.PWR)" "value_sensor.air": json_payload: true if_expr: '! isnull( payload?.AIR )' expr: "float(payload.AIR)" "value_sensor.pump": json_payload: true if_expr: '! isnull( payload?.FLT )' expr: "float(payload.FLT)" "value_sensor.god": json_payload: true if_expr: '! isnull( payload?.GOD )' expr: "float(payload.GOD)" "value_sensor.lock": json_payload: true if_expr: '! isnull( payload?.LCK )' expr: "float(payload.LCK)" "value_sensor.unit": json_payload: true if_expr: '! isnull( payload?.UNT )' expr: "float(payload.UNT)" "value_sensor.error": json_payload: true if_expr: '! isnull( payload?.ERR )' expr: "float(payload.ERR)" "temperature_sensor.green": json_payload: true if_expr: '! isnull( payload?.GRN )' expr: "float(payload.GRN)" "temperature_sensor.red": json_payload: true if_expr: '! isnull( payload?.RED )' expr: "float(payload.RED)" "temperature_sensor.target": json_payload: true if_expr: '! isnull( payload?.TGT )' expr: "float(payload.TGT)" "temperature_sensor.value": json_payload: true if_expr: '! isnull( payload?.TMP )' expr: "float(payload.TMP)" "temperature_sensor.virtual": json_payload: true if_expr: '! isnull( payload?.VTM )' expr: "round(float(payload.VTM), 1)" "temperature_sensor.ambient": json_payload: true if_expr: '! isnull( payload?.AMB )' expr: "float(payload.AMB)" "layzspa/Status": "value_sensor.status": if_expr: '! isnull( payload )' expr: "payload" "layzspa/button": "value_sensor.button": if_expr: '! isnull( payload )' expr: "payload" and in reactor.yaml I have: "layzspa_states": name: "Lay-Z-Spa States" friendly_name: 'Lay-Z-Spa States' include: layzspa_message I realize my MQTT configuration might be a bit unorthodox, but could there still be something unintentional in the latest MQTTController build? If needed, I can provide detailed logs.
2 Posts 2 Posters 101 Views 2 Watching
  • 3 Offline
    3 Offline
    wrote last edited by 3rdStng
    Docker image "latest-25264-2fbe9217" running on unRAID.
    Running this in Chrome Version 140.0.7339.[128 or 208] with the same results in Edge.
    The UI, when searching within the Rule Set, does not reset/self clear when you click outside of the rule set area.
    To reproduce the issue:
    Click on Rule Sets and type in something within the Search window that does not exist for a rule name. "french" in my example.
    12295a06-0fc3-444d-94c9-9522b26dad42-image.png 397bdea2-670c-4600-8c09-03c169b8b5d9-image.png
    Click outside of the gray area, where my mouse is in the screen grabs, which will close the Rule Sets pop over.
    Click on Rule Sets again and none of the rules will appear. The search term isn't sticky either.
    The rules won't appear again until you type any character, or press the backspace, in the "Search for rule" field.
      Great report. Thank you! Will be fixed in next build.
      • The reaction stopped working (Google Nest max playing a video)
      • [Reactor] Variables not updating correctly in latest-25201-2aa18550
        3.0k
      • Rule Set UI bug - SOLUTION
      • [Reactor] Copy&Paste of Rules
      • [MSR] reactor-mqtt-contrib package for additional MQTT templates
        7.5k
      • [Reactor] Help with screne controller cycling logic
      • Stop the MSR by an external switch on Hubitat.
        Tom_DT
        Tom_D
      • Expose MSR entities
      • Comment in Globa Expressions
      • Little Bobby tables...
      • Home Assistant Voice TTS is Easy
      • Play Audio through Home Assistant Voice Unit
