  4. HA 2025.9.4 Supported Yet?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
2 Posts 2 Posters 910 Views
This topic was forked from The reaction stopped working (Google Nest max playing a video) toggledbits
    Tangentially did I miss 2025.9.4 getting blessed in MSR? I've been holding off
    Cheers
      Cheers
      @CatmanV2 said in The reaction stopped working (Google Nest max playing a video):
      Generally, if 2025.9.0 or .1 is blessed, the remaining releases are going to contain only small tweaks and bug fixes, and will likely be OK to install (just ignore the warning alert). The biggest risk there is the first release (e.g. 202x.y.0) changing behavior that required me to adapt to in HassController, and a later minor release (e.g. 202x.y.2) addresses some error they made in that first cut and changes/fixes that behavior in a way that's now incompatible with the new HassController changes. Historically, that's pretty rare. The biggest risks are always the first of their monthly releases, where there are long lists of big behavior changes and usually many potentially breaking changes.
      And yes, please keep the threads on-topic. 🙂
        163.9k
