authtrack:
max_attempts: 4
EDIT: some logs
reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
[Solved] alarm() in global expression throws error in log.
Posters
5.9k
Views
Watching
It's not mentioned in a substitution somewhere?
New variable, another entity but same error with
alarm()
There must be something off in my system then.[latest-25310]2025-11-07T17:14:14.037Z <Engine:NOTICE> Engine#1 creating global expression neverusedbeforevariable [latest-25310]2025-11-07T17:14:14.039Z <Engine:CRIT> Engine#1 alarm() scheduled neverusedbeforevariable tick for 1762535669039<2025-11-07 18:14:29> = now 1762535654039<2025-11-07 18:14:14> + delay 15000 [latest-25310]2025-11-07T17:14:22.195Z <Engine:ERR> Engine#1: error evaluating expression neverusedbeforevariable: [ReferenceError] alarm() can only be used in global expressions [-] [latest-25310]2025-11-07T17:14:22.195Z <Engine:ERR> Engine#1: expression: alarm(15), getEntity( "vera>device_56" ).attributes.x_vera_svc_micasaverde_com_EnergyMetering1.momentary_active_import [latest-25310]2025-11-07T17:14:22.195Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-] ReferenceError: alarm() can only be used in global expressions at /home/homebridge/reactor/server/lib/Engine.js:1455:23 at _run (/home/homebridge/reactor/common/lexp.js:1704:34) at /home/homebridge/reactor/common/lexp.js:1426:29 at Array.forEach (<anonymous>) at _run (/home/homebridge/reactor/common/lexp.js:1425:28) at Object.run (/home/homebridge/reactor/common/lexp.js:1855:24) at Engine._eval_expr (/home/homebridge/reactor/server/lib/Engine.js:1170:141) at Engine._expr_dependency (/home/homebridge/reactor/server/lib/Engine.js:1555:82) at /home/homebridge/reactor/server/lib/MessageBus.js:114:195 at Array.forEach (<anonymous>) [latest-25310]2025-11-07T17:14:27.526Z <Rule:INFO> Notifiering - Auto off laddning poolrobot (rule-md7japbd in Notifieringar) starting rule state evaluation; because entity-changed Switch#mosquitto-mqtt>laddning_poolrobot [latest-25310]2025-11-07T17:14:29.039Z <Engine:CRIT> Engine#1 neverusedbeforevariable alarm() tick [latest-25310]2025-11-07T17:14:29.039Z <Engine:CRIT> Engine#1 alarm() scheduled neverusedbeforevariable tick for 1762535684039<2025-11-07 18:14:44> = now 1762535669039<2025-11-07 18:14:29> + delay 15000 [latest-25310]2025-11-07T17:14:30.681Z <Engine:ERR> Engine#1: error evaluating expression neverusedbeforevariable: [ReferenceError] alarm() can only be used in global expressions [-] [latest-25310]2025-11-07T17:14:30.681Z <Engine:ERR> Engine#1: expression: alarm(15), getEntity( "vera>device_56" ).attributes.x_vera_svc_micasaverde_com_EnergyMetering1.momentary_active_import [latest-25310]2025-11-07T17:14:30.681Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-] ReferenceError: alarm() can only be used in global expressions at /home/homebridge/reactor/server/lib/Engine.js:1455:23 at _run (/home/homebridge/reactor/common/lexp.js:1704:34) at /home/homebridge/reactor/common/lexp.js:1426:29 at Array.forEach (<anonymous>) at _run (/home/homebridge/reactor/common/lexp.js:1425:28) at Object.run (/home/homebridge/reactor/common/lexp.js:1855:24) at Engine._eval_expr (/home/homebridge/reactor/server/lib/Engine.js:1170:141) at Engine._expr_dependency (/home/homebridge/reactor/server/lib/Engine.js:1555:82) at /home/homebridge/reactor/server/lib/MessageBus.js:114:195 at Array.forEach (<anonymous>) -
OK. I think I've got it. Pull it once again and restart... this time for sure!!!
Whew! If that was anything, it was the work of an aging magician.
Thanks for sticking with it and supplying good info.
