reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Home Assistant 2025.11.2 and latest-25315
Posters
Views
Watching
Heads up!
It might be just my system or it might be a good idea to wait for HASSController to bless 2025.11.2 before you update HASS.
@toggledbits can you confirm?[latest-25315]2025-11-17T14:05:05.818Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.180:8123/api/websocket [latest-25315]2025-11-17T14:05:05.820Z <HassController:NOTICE> HassController#hass connected, starting protocol [latest-25315]2025-11-17T14:05:05.821Z <HassController:INFO> HassController#hass successful authentication with ws://192.168.1.180:8123; fetching initial data... [latest-25315]2025-11-17T14:05:05.822Z <HassController:INFO> HassController#hass HA reports version "2025.11.2" location Hem timezone Europe/Stockholm state RUNNING safe_mode false [latest-25315]2025-11-17T14:05:05.822Z <HassController:ERR> HassController#hass error while attempting config dump: [TypeError] Cannot read properties of undefined (reading 'tag') [-] [latest-25315]2025-11-17T14:05:05.823Z <HassController:ERR> HassController#hass failed to complete startup: [TypeError] Cannot read properties of undefined (reading 'tag') [-] [latest-25315]2025-11-17T14:05:05.823Z <HassController:CRIT> TypeError: Cannot read properties of undefined (reading 'tag') [-] TypeError: Cannot read properties of undefined (reading 'tag') at /home/homebridge/reactor/server/lib/AlertManager.js:141:144 at Array.findIndex (<anonymous>) at AlertManager.addAlert (/home/homebridge/reactor/server/lib/AlertManager.js:141:114) at /home/homebridge/reactor/server/lib/HassController.js:1464:367 at process.processTicksAndRejections (node:internal/process/task_queues:103:5) [latest-25315]2025-11-17T14:05:05.825Z <HassController:NOTICE> HassController#hass websocket closing, 1000 -
Try build 25321 that I just pushed. I think I already had a fix for that.
Yes, solved. Thank you! Next time I will remember to do a manual backup of HASS before upgrading
@Crille 11.2 has some... issues... I rolled back to 11.1, tbh. ZWJSUI and my iblinds weren't playing nice at all.
@gwp1, stay at zwave-js-ui: 11.3.1, zwave-js: 15.14.0 (5.2.1) They broke iBlinds after that. It's' been reported and it's being worked, the last I saw. HAAS 2025.11.2 is working fine without upgrade ZwaveJs-UI.
