  4. Date/time condition
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
Date/time condition
3 Posts 2 Posters 1.0k Views 2 Watching
    Consider the following example:
    This is always true, which is not always evident (e.g. when used within Reactions or there are a lot of other conditions and you miss this one being "green").
    Manual says there's no "at" operator, but I was thinking could this behaviour be changed so that when date/time is specified like in my example, it would behave like "at" instead of being always true?
      You don't need an "at" because an "after" will trigger at the set time. It also has the advantage that if the system is down when the set time arrives, it will trigger as soon as the system comes up (when used in a Rule's trigger conditions; any time until midnight), so the event is less likely missed. If you want to make sure something only happens at the set time or within a smaller error, set a between <time> and <time+minutes> (there are other clever things you can do as well, exercise for the reader).
      Between 1300 and 1300 means between 1300 today and 1300 tomorrow. That won't change.
      BTW, this behavior (and explanation) goes back to the Reactor plugin for Vera.
        Ok, I'm aware of "after" operator, and in this case didn't want to use "between 13:00 and 13:05"
          162.8k
