  4. Issue with MSR UI becoming unresponsive
7 Posts 2 Posters 1.2k Views 2 Watching
    sethlampman
    I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all.
    From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only.
    Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again...
    Installation method
    Home Assistant Container
    Core
    2025.7.3
    Frontend
    20250702.3
    nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR
    Any help would be greatly appreciated
    Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config
    NODE_PATH /opt/reactor:/opt/reactor/node_modules
    [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node
    [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined)
    [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage
    [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules
    [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300
    [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141
    [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8
    [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US
    [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM"
    [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326
    [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312
    [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141
    [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279
    [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314
    [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251
    [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253
    [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318
    [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283
    [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141
    [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258
    [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328
    [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323
    [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292
    [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325
    [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328
    [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328
    [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138
    [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141
    [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325
    [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268
    [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323
    [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092
    [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason:  [-]
    FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason:
        at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11)
       at ClientRequest.emit (node:events:508:28)
        at ClientRequest.emit (node:domain:489:12)
        at emitErrorEvent (node:_http_client:108:11)
        at TLSSocket.socketErrorListener (node:_http_client:575:5)
        at TLSSocket.emit (node:events:508:28)
        at TLSSocket.emit (node:domain:489:12)
        at emitErrorNT (node:internal/streams/destroy:170:8)
        at emitErrorCloseNT (node:internal/streams/destroy:129:3)
        at processTicksAndRejections (node:internal/process/task_queues:89:21
      Don't worry about the OpenWeatherMap messages, that's just the occasional query failing, and Reactor will retry the query to get what it needs.
      Since it's UI side, the best thing to do is to press F12 or whatever key opens up the Developer Tools on the browser you are using. You can usually find it on the browser's menu with a little digging. From there, there is a console where there will be messages for the UI side of things, and just copy-paste that as you've done with the log entries. HTOP on the host... just for my own clarification, that to me means you are running it on the server side, and if it's the UI that's bogging down for some reason, I expect that to not tell us more. If you are on Windows, open Task Manager and look at the browser's performance stats and memory consumption. If Mac, I'm sure there's an equivalent tool.
      I would also be curious to hear if the problem resolves (even just temporarily) if you do a refresh on the browser.
      Please don't make any big changes (like moving off docker) — I'm almost 100% certain we will find this issue on the UI side and moving Reactor around won't matter, just make unnecessary work for you and a moving target for me. Stay with me, and we'll get to the bottom of this.
        sethlampman
        thanks, The only console error I see while recreating the issue is:
        ClientAPI.js:957 API: ignoring unsupported message
        MessageEvent {isTrusted: true, data: '{"type":"goodbye","reason":"missed ping(s)"}', origin: 'ws://192.168.12.37:8111', lastEventId: '', source: null, …}
        isTrusted
        true
        bubbles
        false
        cancelBubble
        false
        cancelable
        false
        composed
        false
        currentTarget
        WebSocket {url: 'ws://192.168.12.37:8111/wsapi', readyState: 3, bufferedAmount: 0, onopen: ƒ, onerror: ƒ, …}
        data
        "{"type":"goodbye","reason":"missed ping(s)"}"
        defaultPrevented
        false
        eventPhase
        lastEventId
        origin
        "ws://192.168.12.37:8111"
        ports
        returnValue
        true
        source
        null
        srcElement
        target
        timeStamp
        85696
        type
        "message"
        userActivation
        null
        [[Prototype]]
        MessageEvent
          sethlampman
          just for Sh*t's and giggles, I tried doing a restore on a non docker bare metal environment and you are 100% right, the issues followed. Back to the original env... Is there a way to disable live search? that would help a lot I'm guessing. I start typing and the ui is very responsive. Then I start pressing the backspace key and the live search responds until i get to 1 letter and then she freezes for 30 seconds to a minute or longer. Thinking back I used to have this issue while trying to manage MSR on my phone browser sometimes. I would just move to a computer browser and all would be fine. would the logs be helpful? I posted all that I could, for some reason I cannot upload a file
          [latest-25328]2025-12-01T18:03:50.905Z <Rule:INFO> Closed - Right Shade - L (rule-grp13yiveal in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10161
          [latest-25328]2025-12-01T18:03:50.905Z <Rule:INFO> Open - Right Shade - L (rule-grp13yjkbak in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10161
          [latest-25328]2025-12-01T18:03:50.905Z <Rule:INFO> Shades - Center Open (rule-94 in Sunroom) starting rule state evaluation; because entity-changed Cover#vera>device_10165, entity-changed Cover#vera>device_10441
          [latest-25328]2025-12-01T18:03:50.906Z <Rule:INFO> Shades - Center Closed (rule-98 in Sunroom) starting rule state evaluation; because entity-changed Cover#vera>device_10165, entity-changed Cover#vera>device_10167, entity-changed Cover#vera>device_10441
          [latest-25328]2025-12-01T18:03:50.907Z <Rule:INFO> Shades - Center Right Shade Partially Closed (rule-m29j3nwf in Sunroom) starting rule state evaluation; because entity-changed Cover#vera>device_10165, entity-changed Cover#vera>device_10167, entity-changed Cover#vera>device_10441
          [latest-25328]2025-12-01T18:03:50.909Z <Rule:INFO> Closed - Center Shade - CL (rule-grp13x7waga in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10165
          [latest-25328]2025-12-01T18:03:50.909Z <Rule:INFO> Open - Center Shade - CL (rule-grp13x8479w in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10165
          [latest-25328]2025-12-01T18:03:50.909Z <Rule:INFO> Closed - Center Shade - R (rule-grp13x7yauz in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10167
          [latest-25328]2025-12-01T18:03:50.909Z <Rule:INFO> Open - Center Shade - R (rule-grp13x86vl5 in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10167
          [latest-25328]2025-12-01T18:03:50.909Z <Rule:INFO> Left Shades Open (rule-91 in Sunroom) starting rule state evaluation; because entity-changed Cover#vera>device_10444, entity-changed Cover#vera>device_10160, entity-changed Cover#vera>device_10451
          [latest-25328]2025-12-01T18:03:50.910Z <Rule:INFO> Closed - Left Shade - L (rule-grp13x60f0y in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10444
          [latest-25328]2025-12-01T18:03:50.911Z <Rule:INFO> Open - Left Shade - L (rule-grp13x7bvkl in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10444
          [latest-25328]2025-12-01T18:03:50.911Z <Rule:INFO> Closed - Right Shade - R (rule-grp13yjieiy in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10445
          [latest-25328]2025-12-01T18:03:50.911Z <Rule:INFO> Open - Right Shade - R (rule-grp13yjnsd4 in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10445
          [latest-25328]2025-12-01T18:03:50.911Z <Rule:INFO> BI ~Global~ Profile Night @ Civil Dusk (rule-grp1indyjrw in Security - Blue Iris) starting rule state evaluation; because entity-changed SecuritySensor#vera>device_10237
          [latest-25328]2025-12-01T18:03:50.911Z <Rule:INFO> MBR - Minimote - Button 1 - All Lights On + Temp XMAS (rule-grpx8pim5l in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10024
          [latest-25328]2025-12-01T18:03:50.912Z <Rule:INFO> MBR - Minimote - Button 2 - MBR Dim + Temp XMAS (rule-ljuf4mxu in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10024
          [latest-25328]2025-12-01T18:03:50.912Z <Rule:INFO> MBR - Minimote - Button 3 - MBR Off + Security Lighting + Temp XMAS (rule-ljuf65hu in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10024
          [latest-25328]2025-12-01T18:03:50.912Z <Rule:INFO> MBR - Minimote - Button 4 - Really DIM + Temp XMAS (rule-grpxen1h3w in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10024
          [latest-25328]2025-12-01T18:03:50.912Z <Rule:INFO> Kitchen Minimote - Button 1 tap - Downstairs On (rule-grpxan4n87 in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:50.912Z <Rule:INFO> Kitchen Minimote - Button 2 tap - Dim Downstairs (rule-grpxanakbk in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:50.913Z <Rule:INFO> Kitchen Minimote - Button 3 tap - Kitchen On (rule-grpxam8jfz in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:50.913Z <Rule:INFO> Kitchen Minimote - Button 3 hold - Kitchen On Bright (rule-m0hnaif4 in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:50.913Z <Rule:INFO> Kitchen Minimote - Button 4 tap - Kitchen Off (rule-grpxam8lmi in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:50.913Z <Rule:INFO> Kitchen Minimote - Button 4 hold - Kitchen Evening (rule-m0ki8muh in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:50.913Z <Rule:INFO> Minimote - Button 1 tap - Brenda's Office ON (rule-ls2drjuo in Brendas Office) starting rule state evaluation; because entity-changed Entity#vera>device_10056
          [latest-25328]2025-12-01T18:03:50.914Z <Rule:INFO> Minimote - Button 2 tap - Brenda's Office OFF (rule-ls2drnb6 in Brendas Office) starting rule state evaluation; because entity-changed Entity#vera>device_10056
          [latest-25328]2025-12-01T18:03:50.914Z <Rule:INFO> Minimote - Button 3 tap - Brenda's Office Med Dim (rule-ls2drtzw in Brendas Office) starting rule state evaluation; because entity-changed Entity#vera>device_10056
          [latest-25328]2025-12-01T18:03:50.915Z <Rule:INFO> Minimote - Button 4 tap - Brenda's Office Very Dim (rule-ls2drxo1 in Brendas Office) starting rule state evaluation; because entity-changed Entity#vera>device_10056
          [latest-25328]2025-12-01T18:03:50.915Z <Rule:INFO> Garage Worklight ON - Motion (rule-lss1u12y in Garage) starting rule state evaluation; because entity-changed SecuritySensor#vera>device_10365
          [latest-25328]2025-12-01T18:03:50.915Z <Rule:INFO> Garage Light ON - Interior Door, External garage door, PIR (rule-lrn2n18a in Garage) starting rule state evaluation; because entity-changed SecuritySensor#vera>device_10365
          [latest-25328]2025-12-01T18:03:50.915Z <Rule:INFO> Garage Light OFF - No Motion for 10min (rule-lrn2i4ih in Garage) starting rule state evaluation; because entity-changed SecuritySensor#vera>device_10365
          [latest-25328]2025-12-01T18:03:50.916Z <Rule:INFO> BI ~Garage Cameras Motion ON - No Motion inside Garage (rule-lr5yb2a0 in Security - Blue Iris) starting rule state evaluation; because entity-changed SecuritySensor#vera>device_10365
          [latest-25328]2025-12-01T18:03:50.916Z <Rule:INFO> BL - Minimote - Button 1 - Bedtime (no company) + Temp XMAS (rule-grpxacwh5h in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10134
          [latest-25328]2025-12-01T18:03:50.916Z <Rule:INFO> BL - Minimote - Button 2 - MBR Dim + Temp XMAS (rule-grpxadoh2y in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10134
          [latest-25328]2025-12-01T18:03:50.916Z <Rule:INFO> BL - Minimote - Button 3 - MBR Off + Safety Lighting + Temp XMAS (rule-grpxaduapm in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10134
          [latest-25328]2025-12-01T18:03:50.917Z <Rule:INFO> BL - Minimote - Button 4 - Bedroom Really Dim + Temp XMAS (rule-grpxady4ip in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10134
          [latest-25328]2025-12-01T18:03:50.917Z <Rule:INFO> Remote - Button 1 ON // Left Shades Open (rule-grpy7qw8qm in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:50.917Z <Rule:INFO> Remote - Button 1 OFF // Left Shades Closed (rule-grpy7qxwc8 in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:50.917Z <Rule:INFO> Remote - Button 2 ON // Center Shades Open (rule-grpyegg15i in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:50.918Z <Rule:INFO> Remote - Button 2 OFF // Center Shades Closed (rule-grpyeghilp in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:50.918Z <Rule:INFO> Remote - Button 3 ON // Right Shades Open (rule-grpyegkz7s in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:50.918Z <Rule:INFO> Remote - Button 3 OFF // Right Shades Closed (rule-grpyegmlme in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:50.918Z <Rule:INFO> Remote - Button 4 ON // Landsdcape Lights On (rule-grpy6ykcsl in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:50.918Z <Rule:INFO> Remote - Button 4 OFF // Landscape Lights Off (rule-grpy6ykenn in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:50.918Z <Rule:INFO> Closed - Left Shade - R (rule-grp13x75942 in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10160
          [latest-25328]2025-12-01T18:03:50.919Z <Rule:INFO> Open - Left Shade - R (rule-grp13x7hjq0 in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10160
          [latest-25328]2025-12-01T18:03:50.919Z <Rule:INFO> Closed - Center Shade - L (rule-grp13x7rd3o in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10441
          [latest-25328]2025-12-01T18:03:50.919Z <Rule:INFO> Open - Center Shade - L (rule-grp13x82q9h in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10441
          [latest-25328]2025-12-01T18:03:50.919Z <Rule:INFO> Closed - Left Shade - C (rule-grp13x66th4 in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10451
          [latest-25328]2025-12-01T18:03:50.919Z <Rule:INFO> Open - Left Shade - C (rule-grp13x7fsdh in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10451
          [latest-25328]2025-12-01T18:03:50.919Z <Rule:INFO> Rule#rule-lo4s7vnz rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:50.919Z <Rule:INFO> Rule#rule-l3p3k82u rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:50.919Z <Rule:INFO> Rule#rule-mb3xi9ku rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:50.920Z <Rule:INFO> Rule#rule-101 rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:50.920Z <Rule:INFO> Rule#rule-l1totlyh rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:50.920Z <Rule:INFO> Rule#rule-94 rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:50.920Z <Rule:INFO> Rule#rule-98 rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:50.920Z <Rule:INFO> Rule#rule-m29j3nwf rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:50.920Z <Rule:INFO> Rule#rule-91 rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:50.920Z <Rule:INFO> Pool - Camera IR ON // Sunroom Shades Closed (rule-lo4s7vnz in Security) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:50.921Z <Rule:INFO> Shades - Right Open (rule-l3p3k82u in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:50.922Z <Rule:INFO> Shades - Right Open - 8AM (rule-mb3xi9ku in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:50.922Z <Rule:INFO> Shades - Right Closed (rule-101 in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:50.923Z <Rule:INFO> Landscape - Lighting Off // Sunroom shades closed late evening (rule-l1totlyh in Outside) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:50.924Z <Rule:INFO> Shades - Center Open (rule-94 in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:50.925Z <Rule:INFO> Shades - Center Closed (rule-98 in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:50.926Z <Rule:INFO> Shades - Center Right Shade Partially Closed (rule-m29j3nwf in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:50.927Z <Rule:INFO> Left Shades Open (rule-91 in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:54.220Z <Rule:INFO> Seths Office Minimote - Button 1 tap - Lights ON (rule-lhb27vur in Seth's Office) starting rule state evaluation; because entity-changed Entity#vera>device_10051
          [latest-25328]2025-12-01T18:03:54.220Z <Rule:INFO> Seths Office Minimote - Button 2 tap - All OFF (rule-grpxf30nws in Seth's Office) starting rule state evaluation; because entity-changed Entity#vera>device_10051
          [latest-25328]2025-12-01T18:03:54.221Z <Rule:INFO> Seths Office Minimote - Button 3 tap - DIM (rule-grpxf30pf6 in Seth's Office) starting rule state evaluation; because entity-changed Entity#vera>device_10051
          [latest-25328]2025-12-01T18:03:54.221Z <Rule:INFO> Pool - Camera IR ON // Sunroom Shades Closed (rule-lo4s7vnz in Security) starting rule state evaluation; because entity-changed Cover#vera>device_10336, entity-changed Cover#vera>device_10161, entity-changed Cover#vera>device_10165, entity-changed Cover#vera>device_10167, entity-changed Cover#vera>device_10444, entity-changed Cover#vera>device_10445, entity-changed Cover#vera>device_10160, entity-changed Cover#vera>device_10441, entity-changed Cover#vera>device_10451
          [latest-25328]2025-12-01T18:03:54.222Z <Rule:INFO> Shades - Right Open (rule-l3p3k82u in Sunroom) starting rule state evaluation; because entity-changed Cover#vera>device_10336, entity-changed Cover#vera>device_10161, entity-changed Cover#vera>device_10445
          [latest-25328]2025-12-01T18:03:54.224Z <Rule:INFO> Shades - Right Open - 8AM (rule-mb3xi9ku in Sunroom) starting rule state evaluation; because entity-changed Cover#vera>device_10336, entity-changed Cover#vera>device_10161, entity-changed Cover#vera>device_10445
          [latest-25328]2025-12-01T18:03:54.225Z <Rule:INFO> Shades - Right Closed (rule-101 in Sunroom) starting rule state evaluation; because entity-changed Cover#vera>device_10336, entity-changed Cover#vera>device_10161, entity-changed Cover#vera>device_10445
          [latest-25328]2025-12-01T18:03:54.226Z <Rule:INFO> Closed - Right Shade - C (rule-grp13yjgb9b in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10336
          [latest-25328]2025-12-01T18:03:54.227Z <Rule:INFO> Open - Right Shade - C (rule-grp13yjm4dq in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10336
          [latest-25328]2025-12-01T18:03:54.227Z <Rule:INFO> Landscape - Lighting Off // Sunroom shades closed late evening (rule-l1totlyh in Outside) starting rule state evaluation; because entity-changed Cover#vera>device_10336, entity-changed Cover#vera>device_10161, entity-changed Cover#vera>device_10165, entity-changed Cover#vera>device_10167, entity-changed Cover#vera>device_10444, entity-changed Cover#vera>device_10445, entity-changed Cover#vera>device_10160, entity-changed Cover#vera>device_10441, entity-changed Cover#vera>device_10451
          [latest-25328]2025-12-01T18:03:54.227Z <Rule:INFO> Closed - Right Shade - L (rule-grp13yiveal in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10161
          [latest-25328]2025-12-01T18:03:54.228Z <Rule:INFO> Open - Right Shade - L (rule-grp13yjkbak in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10161
          [latest-25328]2025-12-01T18:03:54.229Z <Rule:INFO> Shades - Center Open (rule-94 in Sunroom) starting rule state evaluation; because entity-changed Cover#vera>device_10165, entity-changed Cover#vera>device_10441
          [latest-25328]2025-12-01T18:03:54.230Z <Rule:INFO> Shades - Center Closed (rule-98 in Sunroom) starting rule state evaluation; because entity-changed Cover#vera>device_10165, entity-changed Cover#vera>device_10167, entity-changed Cover#vera>device_10441
          [latest-25328]2025-12-01T18:03:54.232Z <Rule:INFO> Shades - Center Right Shade Partially Closed (rule-m29j3nwf in Sunroom) starting rule state evaluation; because entity-changed Cover#vera>device_10165, entity-changed Cover#vera>device_10167, entity-changed Cover#vera>device_10441
          [latest-25328]2025-12-01T18:03:54.233Z <Rule:INFO> Closed - Center Shade - CL (rule-grp13x7waga in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10165
          [latest-25328]2025-12-01T18:03:54.234Z <Rule:INFO> Open - Center Shade - CL (rule-grp13x8479w in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10165
          [latest-25328]2025-12-01T18:03:54.234Z <Rule:INFO> Closed - Center Shade - R (rule-grp13x7yauz in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10167
          [latest-25328]2025-12-01T18:03:54.234Z <Rule:INFO> Open - Center Shade - R (rule-grp13x86vl5 in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10167
          [latest-25328]2025-12-01T18:03:54.235Z <Rule:INFO> Left Shades Open (rule-91 in Sunroom) starting rule state evaluation; because entity-changed Cover#vera>device_10444, entity-changed Cover#vera>device_10160, entity-changed Cover#vera>device_10451
          [latest-25328]2025-12-01T18:03:54.236Z <Rule:INFO> Closed - Left Shade - L (rule-grp13x60f0y in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10444
          [latest-25328]2025-12-01T18:03:54.237Z <Rule:INFO> Open - Left Shade - L (rule-grp13x7bvkl in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10444
          [latest-25328]2025-12-01T18:03:54.237Z <Rule:INFO> Closed - Right Shade - R (rule-grp13yjieiy in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10445
          [latest-25328]2025-12-01T18:03:54.237Z <Rule:INFO> Open - Right Shade - R (rule-grp13yjnsd4 in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10445
          [latest-25328]2025-12-01T18:03:54.237Z <Rule:INFO> BI ~Global~ Profile Night @ Civil Dusk (rule-grp1indyjrw in Security - Blue Iris) starting rule state evaluation; because entity-changed SecuritySensor#vera>device_10237
          [latest-25328]2025-12-01T18:03:54.237Z <Rule:INFO> MBR - Minimote - Button 1 - All Lights On + Temp XMAS (rule-grpx8pim5l in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10024
          [latest-25328]2025-12-01T18:03:54.238Z <Rule:INFO> MBR - Minimote - Button 2 - MBR Dim + Temp XMAS (rule-ljuf4mxu in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10024
          [latest-25328]2025-12-01T18:03:54.238Z <Rule:INFO> MBR - Minimote - Button 3 - MBR Off + Security Lighting + Temp XMAS (rule-ljuf65hu in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10024
          [latest-25328]2025-12-01T18:03:54.238Z <Rule:INFO> MBR - Minimote - Button 4 - Really DIM + Temp XMAS (rule-grpxen1h3w in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10024
          [latest-25328]2025-12-01T18:03:54.239Z <Rule:INFO> Kitchen Minimote - Button 1 tap - Downstairs On (rule-grpxan4n87 in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:54.239Z <Rule:INFO> Kitchen Minimote - Button 2 tap - Dim Downstairs (rule-grpxanakbk in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:54.239Z <Rule:INFO> Kitchen Minimote - Button 3 tap - Kitchen On (rule-grpxam8jfz in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:54.239Z <Rule:INFO> Kitchen Minimote - Button 3 hold - Kitchen On Bright (rule-m0hnaif4 in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:54.240Z <Rule:INFO> Kitchen Minimote - Button 4 tap - Kitchen Off (rule-grpxam8lmi in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:54.240Z <Rule:INFO> Kitchen Minimote - Button 4 hold - Kitchen Evening (rule-m0ki8muh in Kitchen) starting rule state evaluation; because entity-changed Entity#vera>device_10036
          [latest-25328]2025-12-01T18:03:54.240Z <Rule:INFO> Minimote - Button 1 tap - Brenda's Office ON (rule-ls2drjuo in Brendas Office) starting rule state evaluation; because entity-changed Entity#vera>device_10056
          [latest-25328]2025-12-01T18:03:54.241Z <Rule:INFO> Minimote - Button 2 tap - Brenda's Office OFF (rule-ls2drnb6 in Brendas Office) starting rule state evaluation; because entity-changed Entity#vera>device_10056
          [latest-25328]2025-12-01T18:03:54.241Z <Rule:INFO> Minimote - Button 3 tap - Brenda's Office Med Dim (rule-ls2drtzw in Brendas Office) starting rule state evaluation; because entity-changed Entity#vera>device_10056
          [latest-25328]2025-12-01T18:03:54.241Z <Rule:INFO> Minimote - Button 4 tap - Brenda's Office Very Dim (rule-ls2drxo1 in Brendas Office) starting rule state evaluation; because entity-changed Entity#vera>device_10056
          [latest-25328]2025-12-01T18:03:54.241Z <Rule:INFO> Garage Worklight ON - Motion (rule-lss1u12y in Garage) starting rule state evaluation; because entity-changed SecuritySensor#vera>device_10365
          [latest-25328]2025-12-01T18:03:54.242Z <Rule:INFO> Garage Light ON - Interior Door, External garage door, PIR (rule-lrn2n18a in Garage) starting rule state evaluation; because entity-changed SecuritySensor#vera>device_10365
          [latest-25328]2025-12-01T18:03:54.243Z <Rule:INFO> Garage Light OFF - No Motion for 10min (rule-lrn2i4ih in Garage) starting rule state evaluation; because entity-changed SecuritySensor#vera>device_10365
          [latest-25328]2025-12-01T18:03:54.243Z <Rule:INFO> BI ~Garage Cameras Motion ON - No Motion inside Garage (rule-lr5yb2a0 in Security - Blue Iris) starting rule state evaluation; because entity-changed SecuritySensor#vera>device_10365
          [latest-25328]2025-12-01T18:03:54.243Z <Rule:INFO> BL - Minimote - Button 1 - Bedtime (no company) + Temp XMAS (rule-grpxacwh5h in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10134
          [latest-25328]2025-12-01T18:03:54.243Z <Rule:INFO> BL - Minimote - Button 2 - MBR Dim + Temp XMAS (rule-grpxadoh2y in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10134
          [latest-25328]2025-12-01T18:03:54.244Z <Rule:INFO> BL - Minimote - Button 3 - MBR Off + Safety Lighting + Temp XMAS (rule-grpxaduapm in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10134
          [latest-25328]2025-12-01T18:03:54.244Z <Rule:INFO> BL - Minimote - Button 4 - Bedroom Really Dim + Temp XMAS (rule-grpxady4ip in MBR Lighting) starting rule state evaluation; because entity-changed Entity#vera>device_10134
          [latest-25328]2025-12-01T18:03:54.244Z <Rule:INFO> Remote - Button 1 ON // Left Shades Open (rule-grpy7qw8qm in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:54.244Z <Rule:INFO> Remote - Button 1 OFF // Left Shades Closed (rule-grpy7qxwc8 in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:54.245Z <Rule:INFO> Remote - Button 2 ON // Center Shades Open (rule-grpyegg15i in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:54.245Z <Rule:INFO> Remote - Button 2 OFF // Center Shades Closed (rule-grpyeghilp in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:54.245Z <Rule:INFO> Remote - Button 3 ON // Right Shades Open (rule-grpyegkz7s in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:54.246Z <Rule:INFO> Remote - Button 3 OFF // Right Shades Closed (rule-grpyegmlme in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:54.246Z <Rule:INFO> Remote - Button 4 ON // Landsdcape Lights On (rule-grpy6ykcsl in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:54.246Z <Rule:INFO> Remote - Button 4 OFF // Landscape Lights Off (rule-grpy6ykenn in Sunroom) starting rule state evaluation; because entity-changed Entity#vera>device_10150
          [latest-25328]2025-12-01T18:03:54.246Z <Rule:INFO> Closed - Left Shade - R (rule-grp13x75942 in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10160
          [latest-25328]2025-12-01T18:03:54.246Z <Rule:INFO> Open - Left Shade - R (rule-grp13x7hjq0 in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10160
          [latest-25328]2025-12-01T18:03:54.247Z <Rule:INFO> Closed - Center Shade - L (rule-grp13x7rd3o in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10441
          [latest-25328]2025-12-01T18:03:54.247Z <Rule:INFO> Open - Center Shade - L (rule-grp13x82q9h in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10441
          [latest-25328]2025-12-01T18:03:54.247Z <Rule:INFO> Closed - Left Shade - C (rule-grp13x66th4 in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10451
          [latest-25328]2025-12-01T18:03:54.247Z <Rule:INFO> Open - Left Shade - C (rule-grp13x7fsdh in Sunroom Shade Watchdog) starting rule state evaluation; because entity-changed Cover#vera>device_10451
          [latest-25328]2025-12-01T18:03:54.247Z <Rule:INFO> Rule#rule-lo4s7vnz rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:54.248Z <Rule:INFO> Rule#rule-l3p3k82u rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:54.248Z <Rule:INFO> Rule#rule-mb3xi9ku rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:54.248Z <Rule:INFO> Rule#rule-101 rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:54.248Z <Rule:INFO> Rule#rule-l1totlyh rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:54.248Z <Rule:INFO> Rule#rule-94 rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:54.248Z <Rule:INFO> Rule#rule-98 rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:54.248Z <Rule:INFO> Rule#rule-m29j3nwf rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:54.248Z <Rule:INFO> Rule#rule-91 rule state evaluation(s) pending, will start after release of semaphore
          [latest-25328]2025-12-01T18:03:54.248Z <Rule:INFO> Pool - Camera IR ON // Sunroom Shades Closed (rule-lo4s7vnz in Security) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:54.249Z <Rule:INFO> Shades - Right Open (rule-l3p3k82u in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:54.251Z <Rule:INFO> Shades - Right Open - 8AM (rule-mb3xi9ku in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:54.252Z <Rule:INFO> Shades - Right Closed (rule-101 in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:54.254Z <Rule:INFO> Landscape - Lighting Off // Sunroom shades closed late evening (rule-l1totlyh in Outside) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:54.254Z <Rule:INFO> Shades - Center Open (rule-94 in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:54.257Z <Rule:INFO> Shades - Center Closed (rule-98 in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:54.258Z <Rule:INFO> Shades - Center Right Shade Partially Closed (rule-m29j3nwf in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:54.260Z <Rule:INFO> Left Shades Open (rule-91 in Sunroom) starting rule state evaluation
          [latest-25328]2025-12-01T18:03:54.430Z <Rule:INFO> Turn On House Lights After Dark (rule-grptyruxy6 in House Auto Lighting) starting rule state evaluation; because expression-state-changed GlobalExpression#SRAdjustedLuxLevelR
          [latest-25328]2025-12-01T18:03:54.431Z <Rule:INFO> Shades - Right Open (rule-l3p3k82u in Sunroom) starting rule state evaluation; because expression-state-changed GlobalExpression#SRAdjustedLuxLevelR
          [latest-25328]2025-12-01T18:03:54.433Z <Rule:INFO> Shades - Right Closed (rule-101 in Sunroom) starting rule state evaluation; because entity-changed ValueSensor#hass>sensor_sr_right_shade_4in1_illuminance
          [latest-25328]2025-12-01T18:03:54.435Z <Rule:INFO> Landscape - Lighting On // Shade LUX below 100 (rule-l1tnl5yf in Outside) starting rule state evaluation; because entity-changed ValueSensor#hass>sensor_sr_right_shade_4in1_illuminance
          [latest-25328]2025-12-01T18:03:55.783Z <Rule:INFO> Turn On House Lights After Dark (rule-grptyruxy6 in House Auto Lighting) starting rule state evaluation; because expression-state-changed GlobalExpression#SRAdjustedLuxLevelR
          [latest-25328]2025-12-01T18:03:55.783Z <Rule:INFO> Shades - Right Open (rule-l3p3k82u in Sunroom) starting rule state evaluation; because expression-state-changed GlobalExpression#SRAdjustedLuxLevelR
          [latest-25328]2025-12-01T18:03:55.785Z <Rule:INFO> Shades - Right Closed (rule-101 in Sunroom) starting rule state evaluation; because entity-changed ValueSensor#hass>sensor_sr_right_shade_4in1_illuminance
          [latest-25328]2025-12-01T18:03:55.787Z <Rule:INFO> Landscape - Lighting On // Shade LUX below 100 (rule-l1tnl5yf in Outside) starting rule state evaluation; because entity-changed ValueSensor#hass>sensor_sr_right_shade_4in1_illuminance
            sethlampman
            wrote on last edited by sethlampman
            Also I literally have over 1000 of these, could that be causing an issue? The only think I can think of is I enabled Opnsense data gathering in Home assistant (i've since disabled). I dont mind deleting them but right now it appears as if I have to do it one by one which would be tedious.
            edit I found them in /storage/entities/hass and there were 50k of them. I deleted and going to see if that had any bearing on this.
              sethlampman
              sorry for all the replies here but.. I deleted the device trackers and they all just reappear. They are coming from HA even though I have removed Opnsense integration. So I added this to my reactor.yaml
                    filter_entity:
                      - "/^device_tracker_/"
              Deleted the tracker jsons, restarted docker and the problem is 100% resolved. I am now trying to figure out how to get rid of these in HA. very annoying....
              • S sethlampman
                Installation method
                Core
                2025.7.3
                Frontend
                20250702.3
                  157.7k
