  4. Need help with sequence
3 Posts 3 Posters 494 Views 3 Watching
    Good evening all,
    For about the past week or so, I've been having problems with a specific rule in my home automation that controls when my home goes from an Away mode to Home mode. One of the conditions it checked for was my alarm panel, when it changed from Armed Away to Disarmed. There seems to have been a firmware update on the panel that added an intermittent step of "pending", and I can't say for certain it happens 100% of the time.
    Is there a way to write a condition that so it changes from one condition, to the next, and then another condition? As in, Home alarm changes from armed_away to pending to disarmed.
    • T tamorgen
      Good evening all,
      @tamorgen just spitballing here but could you add a delay = 5 and then a second step in your Set Reaction that does a "changes from pending > disarmed"? Shrink down the delay time if the "pending" period is shorter.
      Again - just a first thought.
        I will change my logic to just check for your state to be disarmed (so, no changes) for at least 5 secs, or as already suggested, just use OR with all the possible variations you’d get.
