  3. Docker
  4. Grafana on Docker
Moving to Docker
A number of folk are running openLuup on Docker... ...and I'm about to try the same. There are a couple of epic threads in the old place: https://community.getvera.com/t/openluup-on-synology-via-docker/190108 https://community.getvera.com/t/openluup-on-docker-hub/199649 Much of the heavy lifting appears to have been done by @vwout there (and I've asked if they'll join us here!) There's a great GitHub repository: https://github.com/vwout/docker-openluup Hoping to get a conversation going here (and a new special openLuup/Docker section) not least because I know I'm going to need some help!
Docker
Openluup docker filling up disk space?
I've been doing other projects the past weeks, and now started seeing sluggish behaviour in the system.. SSH'ed in, and noticed that the harddrive was completely full! I had some other issues as well that caused it to fill up, but i noticed that when I removed the openluup container, that freed up 1.5GB! This is obviously not the persistent storage folder (cmh-ludl), what else can do this? On the base system, it showed as a massive sized /overlay2 folder in the /var/lib/docker/.. Mabye @vwout knows some docker-hints on this?
Docker
InfluxDB 1.x in docker
I've now gotten most of my applications/components into the docker system, only one left is influxdb. I allready have the database files on an external SSD, and the plan was to have a volume for the influxDB (which holds the .conf file), and a bind mount to the database folder. This is however not the only files of influxdb that needs to be persistent, when i load up the docker, influx has no information about the databases, even when i know the database folder is available. Anyone here know where influxDB stores database setup info? influxdb.conf just enables stuff and sets folders, the info on existing databases and settings is stored elsewhere. (should the docker forum be under software, not openluup?)
Docker
Grafana on Docker
As part of my hardware infrastructure revamp (a move away from 'hobby' platforms to something a bit more solid) I've just switched from running Grafana (a very old version) on a BeagleBone Black (similar to RPi) to my Synology NAS under docker. Despite the old system being on the same platform as my main openLuup instance (or, perhaps, because of this) and now with the new system the data has to be shipped across my LAN, this all seems to work much faster. I had been running Grafana v3.1.1, because I couldn't upgrade on the old system, but now at 7.3.7, which seems to be the latest Docker version. It's a bit different UI from the old one, and needed next to no configuration, apart from importing the old dashboard settings. One thing I'm missing is that the old system had a pull-down menu to switch between dashboards, but the new one doesn't seem to have that, since it switches to a whole new page with a list of dashboards. This doesn't work too well on an iPad, since it brings up the keyboard and obscures half the choices. Am I missing something obvious here? Thanks for any suggestions.
Docker
Grafana on Docker
Scheduled Pinned Locked Moved Docker
5 Posts 3 Posters 2.0k Views 3 Watching
      I'm on 6.3.6, and that still has the pulldown..
      I'm thinking of putting all the different programs on my NUC in dockers, as they seem so have some conflicting dependencies.. One for OpenLuup, one for Z-Way, one for InfluxDB and perhaps grafana in the same? Is it a good idea?
        I've certainly run all those things on different physical machines successfully. I'm warming to the docker approach: although stopping short of creating any docker images myself, I have been playing with a simple Alpine linux and using it to load up openLuup. I'm still struggling with external volumes since the Synology Docker UI doesn't let you access that, and I've not yet bothered with SSH-ing into it to do it from the command line. The thought of everything disappearing if you delete the Docker image is not very appealing.
          ArcherS
          @akbooer I am on 7.3.1 and what I have done is to add links on the top of the pages to navigate between them.
          The link buttons work pretty well also on an iPad or even on the phone.
          //ArcherS
          • A ArcherS
            //ArcherS
            @archers
            Yes, thanks for that, which I was considering, but I already have a fair few links which are URLs to other UIs like AltUI, openLuup, ...
            ...just seems a bit of a shame to lose such a basic and effective tool.
              472
              151.9k
