  4. Play buttons on the Set Reaction area
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
9 Posts 4 Posters 2.3k Views 4 Watching
    Hi
    The button I have highlighted in Red doesn't seem to work ?
    The lamps are not turned on when I press that play button.
    However the other play button I have not highlighted on the left hand side, that one when I press it runs both actions OK.
    So the lamps turn on and the HTTP request is sent out to node-red OK.
      And this one neither play button works and my curtains do not open.
        Open a bug in the tracker, please?
          @toggledbits Yes I can do that, but as I don't know what I am doing with Reactor or MSR, I am not sure what is actually a bug or me not knowing what I am doing LOL.
            Understood, but that, too, is useful information! 🙂 Helps me with documentation, at least.
            FYI, the issue is that cover.open hasn't been implemented yet (for the individual action, the right-side button on the same row as the action). That's an easy fix... I have a long list of actions I need to implement for every platform. I tried to hit the most common/most used, and let the community tell me what others are needed and with what priority. But the intention is to catch everything, at least for the basic/intrinsic devices and the actively-supported plugins (on the Vera side).
            K 1 Reply Last reply
              K Offline
              K Offline
              kfxo
              @toggledbits said in Play buttons on the Set Reaction area:
              Do you have a list of what is implemented and what is on the list to implement? Where should we let you know what is needed? Top of my list thermostats and alarm panels.
                I also tried to use position.set with a value of 1 which I believe is 100% aka Opened.
                But that didn't work either. I thought I was doing something wrong, but if its not been implemented as yet then that obviously explains it.
                Cheers.
                • K kfxo
                  @kfxo said in Play buttons on the Set Reaction area:
                  I briefly looked at code and it's obfuscated, but that's a vera_devices.json file and alarms are indeed missing from this. my partition is recognized, and I could use its raw variables:
                  I didn't tried actions, but I guess an HTTP request could do it in the meantime.
                  EDIT: actions are not shown, in fact.
                    @therealdb said in Play buttons on the Set Reaction area:
                    Right, if it doesn't know the capabilities of the device, it can't show actions because it doesn't know what they are. But it can copy existing attributes, which is the "x_vera" stuff.
                    It exists today that you can write your own rules for defining a device (for all HA controllers types, not just Vera). I'm not releasing this as a documented feature yet because I still have much other work to do, and I'm trying to keep the number of variables down for the moment until things stabilize. It's also the case that if you have a local device definition and later a system definition is added, your local config would hide the system config and make debugging more difficult: for any device problem, I first have to investigate if you've made a local override or not. There are many administrative/logistical issues that go beyond just what's possible in the code.
                    For things like thermostats, though, very necessary for you to be able to self-configure, because Vera itself does not provide sufficient information. You really can't reliably tell from looking at a Vera thermostat device if it's auto-changeover, dual setpoint or single with differential (or not), has fan control or not, what fan modes it has, has humidifer, has dehumidifier, etc. I don't see not relying on local user intelligence to get this done, at least for Vera. But that's slightly different from defining a device class. Overrides for a single device are planned as well, so that will encompass not just defining what capabilities the device has, but other convenience things like giving the device a nicer or more distinct name than the source controller uses (no 20 char limits!).
                      164.0k
