  4. Synology Docker installation
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
31 Posts 5 Posters 13.5k Views 5 Watching
    I don't have any docker containers yet. The bug list is looking pretty quiet for things urgent at the moment, so maybe I'll spend an hour or two seeing what I can get built. I also have a Synology NAS, so I have a ready test platform. The image/container itself is easy, but I'm still figuring out the correct (Synology) way to do the volumes (or bind mounts, whatever they use) for the config and data.
    @toggledbits I followed to the letter your excellent step-by-step guide on launching a Docker container from the image I fetched from PR #58 this morning.
    All proceeded swimmingly – folder creation, image upload, settings & parameters, etc. – until the moment of actual Launch.
    Whereupon, Docker threw up the following on-screen "Stopped Unexpectedly" warning (which repeated every 30 seconds or so until I Stop'ped the container from running/restarting):
    Concurrently, every attempt to access http://<mySynNAS_IP>:8111/ resulted in a "This site can't be reached" error page in Chrome (under Windows, mind you).
    Immediately, I took the liberty of inspecting and Export'ing the logfile (Container ► Details ► Log) as an HTML file, which I attach below (oops, no attachment feature in this forum, so here is the direct link) for your inspection.
    Hope you find some clues, because I'm not at all sure where things went wrong. (The only facet of setup where I expressly deviated from your typed notes involved creating a "Shared" (i.e. top-level, rather than under /home) folder called "Reactor" with r/w access, under which I created a subfolder named "Data", to which I pointed /var/reactor during container creation.)
    Excellent write-up and thanks for the chance to test this out!!
    • Libra
    FOLLOW-UP NOTES
    I do see where Container ► Edit ► Environment ► variable PATH has a value of "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin" which strikes me as odd, but maybe that's normal nomenclature? (By contract, Windows and DOS always use semicolons, not colons, to separate PATH variable entries.)
    RESOLVED
    Noting that the Log displayed an error message related to /var/reactor/config, I went and created a folder named 'config' (all lowercase) under the NAS's top-level Reactor\Data folder, then restarted the container. It's running fine now, and I'm able to access the :8111 interface for the first time.
    Log ► "Configuration path: /var/reactor/config resolved /var/reactor/config"
    SUGGEST
    Please add explicit declaration in your How-To regarding the need for a /config underneath the data folder.
      If someone smarter than me wishes to volunteer a simple write-up on the exact steps required to get MSR up and running on my Synology NAS (with Docker installed and active), I'd be delighted to give it a try. I realize a dedicated Docker-ized version of MSR is perhaps ideal -- and I'm happy to wait for that to manifest -- but if, in the meantime, someone out there can propose a build-your-own solution with minimal footprint, I'm game.
      Unspoken here is how much I cringe when dealing with anything Linux, because for me it's like reading Chinese. But I can follow written instructions very well and provide meticulous feedback. 😉 So thanks in advance...
      • Libra
        LibraSunL 1 Reply Last reply
          @LibraSun
          I would encourage you to open a new thread? I will fork it if you don't mind.
            Concur, and let's get @toggledbits ' earlier Docker-related notes copied into this thread as well. Dunno if they were higher up in the "MSR Available" thread?
              Hopefully not about to ask the world's dumbest question, but here goes...
              I'm stumped at Step 1 of the "Getting Started" docs (https://reactor.toggledbits.com/docs/Getting-Started/), since I'm unable to locate the referenced reactor.yaml file.
              The only files I see under my <reactor-data>/config folder are:
              all-json.out (2 bytes)
              all-yaml.out (3 bytes)
              IMPORTANT NOTE: I'm running MSR under Docker on my Synology NAS, but I believe it behaves identically in all respects to bare metal (Linux) installs. I'm wondering if it's possible that the desired YAML file exists within the distributed image, but is not being exposed yet by the container running MSR.
              Will not proceed until advised by someone more knowledgeable. Until then, I have no "Hub/HA" defined, so cannot do anything, really, with MSR. (Makes me kinda wish these settings lived within MSR's panels and not a YAML file, LOL!)
              Thanks - Libra
                The docker container is slightly different in that the data folder does not live within the container, it lives on a volume that the container mounts separately. This is so that the container can read and write data as needed and it is not destroyed when the image or container is replaced (e.g. you would otherwise lose your config and all your rules and reactions), and so you can edit your config without having to breach the walls of the container.
                The install steps for the docker container has a step for you to create a directory that would become this volume. To confirm you are looking in the right place, open Docker via the package manager. Go to Container, then click the Reactor container. Hit the Details button, and then the Volume tab. The line that shows the mount path "/var/reactor" is the place where your config and data are stored (not /var/reactor, the path to the left of that under File/Folder. So check that to make sure you are looking in the right place. You should see config, logs and storage at a minimum, and possibly also local and sys.
                  @toggledbits said in Multi-System Reactor Developer Preview AVAILABLE:
                  In that folder (which in my case happens to be Reactor/Data, I only see the following subfolders:
                  config
                  storage
                    (Dang it, I should have posted this latest question under the "Synology Docker" thread... @rafale77 can you please bump us over??)
                      OK, then somehow the initial data didn't get copied. If you haven't already, open a PR for that on Mantis, and I'll post the two files so you can put them into the folder yourself, and I'll hunt down why it didn't copy them in the first place.
                        @LibraSun
                        sitôt dit, sitôt fait. (sorry I don't know the equivalent in english)
                        • ElcidE Offline
                          ElcidE Offline
                          Elcid
                          "no sooner said than done" I believe.
                            I like, "Your wish is my command." ✌
                              FYI, I can move them also.
                                Beneath your pay grade sir.
                                  No job too big or too small. If it needs to get done, I'm happy to do it.
                                    Strictly FYI, I've gone ahead and installed NODE.JS v12 on my Synology NAS in anticipation of attempting the Reactor backup conversion to MSR Rulesets. In my Linux-challenged mind, that's a step in the right direction. Next, I'll need to (re-)learn how to SSH into the NAS for executing Terminal commands. Will let you know if this gets me further along that trajectory.
                                    EDIT: Nope, I was clearly jumping the gun. Will have to take another tack.
                                      I've also rolled 21062 (today's daily build) into a docker container for Synology. Link is in PR #58 on the bug tracker.
                                        Installed. Works like a charm. Your instructions were spot on, as per usual.
                                          We can both thank @kfxo for those instructions!
                                            164.6k
