Synology Docker installation
The docker container is slightly different in that the data folder does not live within the container, it lives on a volume that the container mounts separately. This is so that the container can read and write data as needed and it is not destroyed when the image or container is replaced (e.g. you would otherwise lose your config and all your rules and reactions), and so you can edit your config without having to breach the walls of the container.
The install steps for the docker container has a step for you to create a directory that would become this volume. To confirm you are looking in the right place, open Docker via the package manager. Go to Container, then click the Reactor container. Hit the Details button, and then the Volume tab. The line that shows the mount path "/var/reactor" is the place where your config and data are stored (not /var/reactor, the path to the left of that under File/Folder. So check that to make sure you are looking in the right place. You should see
config,logsandstorageat a minimum, and possibly alsolocalandsys. -
config,logsandstorageat a minimum, and possibly alsolocalandsys.@toggledbits said in Multi-System Reactor Developer Preview AVAILABLE:
You should see config, logs and storage at a minimum, and possibly also local and sys
In that folder (which in my case happens to be Reactor/Data, I only see the following subfolders:
config
storage -
OK, then somehow the initial data didn't get copied. If you haven't already, open a PR for that on Mantis, and I'll post the two files so you can put them into the folder yourself, and I'll hunt down why it didn't copy them in the first place.
FYI, I can move them also.
No job too big or too small. If it needs to get done, I'm happy to do it.
Strictly FYI, I've gone ahead and installed NODE.JS v12 on my Synology NAS in anticipation of attempting the Reactor backup conversion to MSR Rulesets. In my Linux-challenged mind, that's a step in the right direction. Next, I'll need to (re-)learn how to SSH into the NAS for executing Terminal commands. Will let you know if this gets me further along that trajectory.
EDIT: Nope, I was clearly jumping the gun. Will have to take another tack.
I've also rolled 21062 (today's daily build) into a docker container for Synology. Link is in PR #58 on the bug tracker.
We can both thank @kfxo for those instructions!
Hi! this is for asking an help to correct time zone.
MSR is now installed (1.0.0-21200-16a604f) on my Synology NAS (DS 720+ with DSM 7) and Docker running on it. With my previous DS119j impossible to do anything with it.All entities from Vera Lite are imported ok .
Trying to import also entities from Ezlo Plus without success.
So looking in the "reactor.log" I notice TZ offset with something like this:
2021-08-03T20:46:16.212Z wsapi:NOTICE wsapi: starting version 21196
2021-08-03T20:46:16.286Z Engine:INFO Engine#1 master timer tick, local time "8/3/2021, 10:46:16 PM" (TZ offset 120 mins from UTC)
2021-08-03T20:46:16.560Z wsapi:INFO wsapi: connection from ::ffff:172.17.0.1In reactor container, going on LOG tab, I have something like this:
time = 23.00.05
and log
2021-08-03T23:00:05.001Z Engine:INFO Engine#1 master timer tick, local time "8/4/2021, 1:00:05 AM" (TZ offset 120 mins from UTC)TZ variable for reactor container is: Europe/Rome
On nas control Panel, server NTP is on time.google.com
in Docker LOG tab, time is correct
Browser time and host Time in MSR GUI are correctdoes anyone have any advice?
Seems like everything is correct. The log timestamps are always UTC. The master timer tick log entry looks correct for about the time of your posting and the time zone you show set below.
I was not able to import entities from Ezlo Plus and I was thinking about a problem between time zone and access token.
Now I have also ezlo entities imported ok but only after putting both “offlineAnonymousAccess” and “offlineInsecureAccess” set to true with API call.In all this ways nothing:
config:username: "somebody" # put your username here betw quotes password: "????????" # and passwordthen config
set_anonymous_access: true <--- add this line, same indent as previousthen with
“offlineInsecureAccess” enabled:truethe log was:
2021-08-04T00:08:25.648Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000/" } 2021-08-04T00:08:25.648Z <EzloController:null> EzloController#ezlo instance log level (null) (4) 2021-08-04T00:08:25.667Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure 2021-08-04T00:08:25.669Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication; hub.offline.insecure_access must be enabled! 2021-08-04T00:08:25.696Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. 2021-08-04T00:08:25.743Z <Controller:INFO> EzloController#ezlo opening local hub connection to (undefined) at wss://10.0.4.119:17000/ 2021-08-04T00:08:25.743Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ((undefined)) certificate 2021-08-04T00:08:25.744Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000/ 2021-08-04T00:08:25.750Z <app:INFO> Structure running; pausing for controllers' initial ready 2021-08-04T00:08:25.856Z <Controller:INFO> EzloController#ezlo hub websocket connected; inventory hub... 2021-08-04T00:08:25.905Z <Controller:ERR> EzloController#ezlo stopping; hub's offline insecure access is disabled, and cloud auth info is not configured 2021-08-04T00:08:25.906Z <Controller:ERR> EzloController#ezlo failed to complete inventory: Error: hub offline anonymous access is disabled, and cloud auth info is not configured 2021-08-04T00:08:25.907Z <Controller:CRIT> Error: hub offline anonymous access is disabled, and cloud auth info is not configured Error: hub offline anonymous access is disabled, and cloud auth info is not configured at /opt/reactor/server/lib/EzloController.js:895:27 at processTicksAndRejections (internal/process/task_queues.js:95:5) 2021-08-04T00:08:25.915Z <Controller:NOTICE> EzloController#ezlo websocket closing, 1002After putting both “offlineAnonymousAccess” and “offlineInsecureAccess” set to true with API call, all entities are imported OK. The problem was hub.offline.insecure_access . This is now the log:
2021-08-04T01:01:18.564Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000/" } 2021-08-04T01:01:18.564Z <EzloController:null> EzloController#ezlo instance log level (null) (4) 2021-08-04T01:01:18.593Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure 2021-08-04T01:01:18.596Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication; hub.offline.insecure_access must be enabled! 2021-08-04T01:01:18.626Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. 2021-08-04T01:01:18.675Z <Controller:INFO> EzloController#ezlo opening local hub connection to (undefined) at wss://10.0.4.119:17000/ 2021-08-04T01:01:18.675Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ((undefined)) certificate 2021-08-04T01:01:18.677Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000/ 2021-08-04T01:01:18.682Z <app:INFO> Structure running; pausing for controllers' initial ready 2021-08-04T01:01:18.790Z <Controller:INFO> EzloController#ezlo hub websocket connected; inventory hub... 2021-08-04T01:01:18.896Z <Controller:INFO> EzloController#ezlo data load complete; 2 devices received, 7 entities registered; 12 items. 2021-08-04T01:01:18.897Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 105ms 2021-08-04T01:01:18.897Z <Controller:NOTICE> Controller EzloController#ezlo is now online. 2021-08-04T01:01:19.152Z <VeraController:WARN> VeraController#vera ignoring geotag ({ "iduser": 1520131, "geotags": [ { "PK_User": 0, "id": 1, "accuracy": 0, "ishome": 1, "notify": 1, "radius": 100, "address": "Via , fi", "color": "006e45", "latitude": "437930", "longitude": "11210", "name": "testi, fi", "status": --null-- } ] }) for user 1520131, user not in user list 2021-08-04T01:01:20.388Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online. 2021-08-04T01:01:22.993Z <VeraController:NOTICE> Controller VeraController#vera is now online. -
OK. So first, you need to learn to post code correctly on this site so I can actually see what you're posting. Any code that you post here (including config and log snippets) should have ``` on a line by itself both before and after.
Please repost your controller config, from the
- id:line to the end of the section, just XXX out your username and password. It looks like your config isn't (and wasn't to start) correctly set up. -
thanks for your advice.
Now seems I'm able to import entities from EzloPlus and to access token.
I put the ezlo plus again with previous API set and did some test againmodel: "h2.1" offlineAnonymousAccess: false offlineInsecureAccess: false serial: "90000XXX"in config
controllers: - id: vera enabled: true implementation: VeraController name: My Vera Lite Hub config: source: 'http://10.0.4.44:3480' - id: ezlo enabled: true implementation: EzloController name: My Ezlo Hub config: source: "wss://10.0.4.119:17000" # change the IP address serial: "90000xxx" # put your hub's serial # here username: "xxx" # put your username here betw quotes password: "xxx" # and passwordin the log:
2021-08-05T18:00:23.085Z <app:null> Reactor "1.0.0-21200-16a604f" starting on v14.17.3 2021-08-05T18:00:23.086Z <app:INFO> Process ID 1; platform linux/x64 #41890 SMP Thu Jul 15 03:37:40 CST 2021 2021-08-05T18:00:23.086Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage 2021-08-05T18:00:23.131Z <Plugin:null> Module Plugin v21173 2021-08-05T18:00:23.138Z <default:INFO> Module Entity v21177 2021-08-05T18:00:23.141Z <Controller:null> Module Controller v21191 2021-08-05T18:00:23.141Z <default:null> Module Structure v21196 2021-08-05T18:00:23.148Z <default:null> Module Ruleset v21096 2021-08-05T18:00:23.148Z <default:null> Module Rulesets v21096 2021-08-05T18:00:23.166Z <default:null> Module Rule v21168 2021-08-05T18:00:23.173Z <default:null> Module Engine v21197 2021-08-05T18:00:23.173Z <default:null> Module httpapi v21197 2021-08-05T18:00:23.175Z <default:null> Module httpproxy v21054 2021-08-05T18:00:23.187Z <default:null> Module wsapi v21196 2021-08-05T18:00:23.212Z <app:NOTICE> Starting Structure... 2021-08-05T18:00:23.216Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping 2021-08-05T18:00:23.217Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController) 2021-08-05T18:00:23.221Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController) 2021-08-05T18:00:23.222Z <Structure:INFO> Structure#1 starting controller interface weather (OWMWeatherController) 2021-08-05T18:00:23.223Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController) 2021-08-05T18:00:23.265Z <default:null> Module VeraController v21195 2021-08-05T18:00:23.269Z <default:null> Module EzloController v21199 2021-08-05T18:00:23.272Z <default:null> Module OWMWeatherController v21140 2021-08-05T18:00:23.273Z <default:null> Module SystemController v21102 2021-08-05T18:00:23.277Z <VeraController:NOTICE> VeraController#vera starting 2021-08-05T18:00:23.326Z <VeraController:INFO> VeraController#vera loaded mapping ver 21177 rev 1 format 1 notice 2021-08-05T18:00:23.339Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000", "serial": "90000xxx", "username": "xxx", "password": "xxx" } 2021-08-05T18:00:23.339Z <EzloController:null> EzloController#ezlo instance log level (null) (4) 2021-08-05T18:00:23.360Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure 2021-08-05T18:00:23.362Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token 2021-08-05T18:00:23.458Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. 2021-08-05T18:00:23.505Z <app:INFO> Structure running; pausing for controllers' initial ready 2021-08-05T18:00:23.945Z <VeraController:WARN> VeraController#vera ignoring geotag ({ "iduser": 1520131, "geotags": [ { "PK_User": 0, "id": 1, "accuracy": 0, "ishome": 1, "notify": 1, "radius": 100, "address": "Via xxx, xxx", "color": "006e45", "latitude": "43xxx", "longitude": "11xxx", "name": "xxx, xxx", "status": --null-- } ] }) for user 1520131, user not in user list 2021-08-05T18:00:25.770Z <Controller:INFO> EzloController#ezlo cloud auth phase complete (local access token acquired) 2021-08-05T18:00:25.770Z <Controller:INFO> EzloController#ezlo opening local hub connection to "90000464" at wss://10.0.4.119:17000 2021-08-05T18:00:25.771Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ("90000464") certificate 2021-08-05T18:00:25.772Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000 2021-08-05T18:00:25.886Z <Controller:NOTICE> EzloController#ezlo successful hub login; performing inventory 2021-08-05T18:00:25.969Z <Controller:INFO> EzloController#ezlo data load complete; 2 devices received, 7 entities registered; 12 items. 2021-08-05T18:00:25.970Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 83ms 2021-08-05T18:00:25.972Z <Controller:NOTICE> Controller EzloController#ezlo is now online. 2021-08-05T18:00:27.923Z <VeraController:NOTICE> Controller VeraController#vera is now online. 2021-08-05T18:00:33.533Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online. 2021-08-05T18:00:33.534Z <app:NOTICE> Starting Reaction Engine... 2021-08-05T18:00:33.535Z <Engine:INFO> Reaction Engine starting 2021-08-05T18:00:33.535Z <Engine:INFO> Checking rule sets... 2021-08-05T18:00:33.537Z <Engine:INFO> Checking rules... 2021-08-05T18:00:33.537Z <Engine:INFO> Data check complete; no corrections. 2021-08-05T18:00:33.539Z <Engine:5:Engine.js:1081> _process_reaction_queue() entry 628 2021-08-05T18:00:33.540Z <Engine:NOTICE> Reaction Engine running! 2021-08-05T18:00:33.540Z <app:NOTICE> Starting HTTP server and API... 2021-08-05T18:00:33.545Z <app:NOTICE> Startup complete 2021-08-05T18:00:33.546Z <Engine:5:Engine.js:1144> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting 2021-08-05T18:00:33.548Z <httpapi:NOTICE> HTTP API v1 21197 base URL http://10.0.4.71:8111; listening 2021-08-05T18:00:33.568Z <app:NOTICE> HTTP server running; registering proxy endpoints. 2021-08-05T18:00:33.568Z <app:NOTICE> Starting WSAPI... 2021-08-05T18:00:33.569Z <wsapi:NOTICE> wsapi: starting version 21196 2021-08-05T18:00:33.639Z <Engine:INFO> Engine#1 master timer tick, local time "8/5/2021, 8:00:33 PM" (TZ offset 120 mins from UTC) 2021-08-05T18:00:35.984Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1 2021-08-05T18:00:36.874Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1 2021-08-05T18:08:33.852Z <wsapi:INFO> client "172.17.0.1#2" closed, code=1001, reason= 2021-08-05T18:08:34.228Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1 2021-08-05T18:35:24.207Z <wsapi:INFO> client "172.17.0.1#3" closed, code=1006, reason= 2021-08-05T18:35:24.208Z <wsapi:INFO> client "172.17.0.1#1" closed, code=1006, reason= 2021-08-05T18:49:28.209Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1 2021-08-05T18:49:38.215Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1 2021-08-05T19:00:05.004Z <Engine:INFO> Engine#1 master timer tick, local time "8/5/2021, 9:00:05 PM" (TZ offset 120 mins from UTC)and the dashboard is so fluid and immediate! I love it!
just to ask, Is there Importing ReactorSensors from Vera Reactor in synology docker method?
