  4. Synology Docker installation
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
31 Posts 5 Posters 13.5k Views 5 Watching
    "no sooner said than done" I believe.
      I like, "Your wish is my command." ✌
        FYI, I can move them also.
          Beneath your pay grade sir.
            No job too big or too small. If it needs to get done, I'm happy to do it.
              Strictly FYI, I've gone ahead and installed NODE.JS v12 on my Synology NAS in anticipation of attempting the Reactor backup conversion to MSR Rulesets. In my Linux-challenged mind, that's a step in the right direction. Next, I'll need to (re-)learn how to SSH into the NAS for executing Terminal commands. Will let you know if this gets me further along that trajectory.
              EDIT: Nope, I was clearly jumping the gun. Will have to take another tack.
                I've also rolled 21062 (today's daily build) into a docker container for Synology. Link is in PR #58 on the bug tracker.
                  Installed. Works like a charm. Your instructions were spot on, as per usual.
                    We can both thank @kfxo for those instructions!
                    • N Offline
                      N Offline
                      Hi! this is for asking an help to correct time zone.
                      MSR is now installed (1.0.0-21200-16a604f) on my Synology NAS (DS 720+ with DSM 7) and Docker running on it. With my previous DS119j impossible to do anything with it.
                      All entities from Vera Lite are imported ok .
                      Trying to import also entities from Ezlo Plus without success.
                      So looking in the "reactor.log" I notice TZ offset with something like this:
                      2021-08-03T20:46:16.212Z wsapi:NOTICE wsapi: starting version 21196
                      2021-08-03T20:46:16.286Z Engine:INFO Engine#1 master timer tick, local time "8/3/2021, 10:46:16 PM" (TZ offset 120 mins from UTC)
                      2021-08-03T20:46:16.560Z wsapi:INFO wsapi: connection from ::ffff:172.17.0.1
                      In reactor container, going on LOG tab, I have something like this:
                      time = 23.00.05
                      and log
                      2021-08-03T23:00:05.001Z Engine:INFO Engine#1 master timer tick, local time "8/4/2021, 1:00:05 AM" (TZ offset 120 mins from UTC)
                      TZ variable for reactor container is: Europe/Rome
                      On nas control Panel, server NTP is on time.google.com
                      in Docker LOG tab, time is correct
                      Browser time and host Time in MSR GUI are correct
                      does anyone have any advice?
                        Seems like everything is correct. The log timestamps are always UTC. The master timer tick log entry looks correct for about the time of your posting and the time zone you show set below.
                        • N Offline
                          N Offline
                          wrote on last edited by noelab
                          #23
                          I was not able to import entities from Ezlo Plus and I was thinking about a problem between time zone and access token.
                          Now I have also ezlo entities imported ok but only after putting both “offlineAnonymousAccess” and “offlineInsecureAccess” set to true with API call.
                          In all this ways nothing:
                          username: "somebody"  # put your username here betw quotes
                             password: "????????"  # and password
                          then config
                          set_anonymous_access: true   <--- add this line, same indent as previous
                          then with
                          “offlineInsecureAccess” enabled:true
                          the log was:
                          2021-08-04T00:08:25.648Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000/" }
                          2021-08-04T00:08:25.648Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
                          2021-08-04T00:08:25.667Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure
                          2021-08-04T00:08:25.669Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication; hub.offline.insecure_access must be enabled!
                          2021-08-04T00:08:25.696Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                          2021-08-04T00:08:25.743Z <Controller:INFO> EzloController#ezlo opening local hub connection to (undefined) at wss://10.0.4.119:17000/
                          2021-08-04T00:08:25.743Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ((undefined)) certificate
                          2021-08-04T00:08:25.744Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000/
                          2021-08-04T00:08:25.750Z <app:INFO> Structure running; pausing for controllers' initial ready
                          2021-08-04T00:08:25.856Z <Controller:INFO> EzloController#ezlo hub websocket connected; inventory hub...
                          2021-08-04T00:08:25.905Z <Controller:ERR> EzloController#ezlo stopping; hub's offline insecure access is disabled, and cloud auth info is not configured
                          2021-08-04T00:08:25.906Z <Controller:ERR> EzloController#ezlo failed to complete inventory: Error: hub offline anonymous access is disabled, and cloud auth info is not configured
                          2021-08-04T00:08:25.907Z <Controller:CRIT> Error: hub offline anonymous access is disabled, and cloud auth info is not configured
                              at /opt/reactor/server/lib/EzloController.js:895:27
                              at processTicksAndRejections (internal/process/task_queues.js:95:5)
                          2021-08-04T00:08:25.915Z <Controller:NOTICE> EzloController#ezlo websocket closing, 1002
                          After putting both “offlineAnonymousAccess” and “offlineInsecureAccess” set to true with API call, all entities are imported OK. The problem was hub.offline.insecure_access . This is now the log:
                          2021-08-04T01:01:18.564Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000/" }
                          2021-08-04T01:01:18.564Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
                          2021-08-04T01:01:18.593Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure
                          2021-08-04T01:01:18.596Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication; hub.offline.insecure_access must be enabled!
                          2021-08-04T01:01:18.626Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                          2021-08-04T01:01:18.675Z <Controller:INFO> EzloController#ezlo opening local hub connection to (undefined) at wss://10.0.4.119:17000/
                          2021-08-04T01:01:18.675Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ((undefined)) certificate
                          2021-08-04T01:01:18.677Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000/
                          2021-08-04T01:01:18.682Z <app:INFO> Structure running; pausing for controllers' initial ready
                          2021-08-04T01:01:18.790Z <Controller:INFO> EzloController#ezlo hub websocket connected; inventory hub...
                          2021-08-04T01:01:18.896Z <Controller:INFO> EzloController#ezlo data load complete; 2 devices received, 7 entities registered; 12 items.
                          2021-08-04T01:01:18.897Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 105ms
                          2021-08-04T01:01:18.897Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
                          2021-08-04T01:01:19.152Z <VeraController:WARN> VeraController#vera ignoring geotag ({ "iduser": 1520131, "geotags": [ { "PK_User": 0, "id": 1, "accuracy": 0, "ishome": 1, "notify": 1, "radius": 100, "address": "Via , fi", "color": "006e45", "latitude": "437930", "longitude": "11210", "name": "testi, fi", "status": --null-- } ] }) for user 1520131, user not in user list
                          2021-08-04T01:01:20.388Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
                          2021-08-04T01:01:22.993Z <VeraController:NOTICE> Controller VeraController#vera is now online.
                            OK. So first, you need to learn to post code correctly on this site so I can actually see what you're posting. Any code that you post here (including config and log snippets) should have ``` on a line by itself both before and after.
                            Please repost your controller config, from the - id: line to the end of the section, just XXX out your username and password. It looks like your config isn't (and wasn't to start) correctly set up.
                            • N Offline
                              N Offline
                              thanks for your advice.
                              Now seems I'm able to import entities from EzloPlus and to access token.
                              I put the ezlo plus again with previous API set and did some test again
                              model: "h2.1"
                              offlineAnonymousAccess: false
                              offlineInsecureAccess: false
                              serial: "90000XXX"
                              in config
                              controllers:
                                - id: vera
                                  enabled: true
                                  implementation: VeraController
                                  name: My Vera Lite Hub
                                    source: 'http://10.0.4.44:3480'
                                - id: ezlo
                                  enabled: true
                                  implementation: EzloController
                                  name: My Ezlo Hub
                                    source: "wss://10.0.4.119:17000"  # change the IP address
                                    serial: "90000xxx"    # put your hub's serial # here
                                    username: "xxx"  # put your username here betw quotes
                                    password: "xxx"  # and password
                              in the log:
                              2021-08-05T18:00:23.085Z <app:null> Reactor "1.0.0-21200-16a604f" starting on v14.17.3
                              2021-08-05T18:00:23.086Z <app:INFO> Process ID 1; platform linux/x64 #41890 SMP Thu Jul 15 03:37:40 CST 2021
                              2021-08-05T18:00:23.086Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage
                              2021-08-05T18:00:23.131Z <Plugin:null> Module Plugin v21173
                              2021-08-05T18:00:23.138Z <default:INFO> Module Entity v21177
                              2021-08-05T18:00:23.141Z <Controller:null> Module Controller v21191
                              2021-08-05T18:00:23.141Z <default:null> Module Structure v21196
                              2021-08-05T18:00:23.148Z <default:null> Module Ruleset v21096
                              2021-08-05T18:00:23.148Z <default:null> Module Rulesets v21096
                              2021-08-05T18:00:23.166Z <default:null> Module Rule v21168
                              2021-08-05T18:00:23.173Z <default:null> Module Engine v21197
                              2021-08-05T18:00:23.173Z <default:null> Module httpapi v21197
                              2021-08-05T18:00:23.175Z <default:null> Module httpproxy v21054
                              2021-08-05T18:00:23.187Z <default:null> Module wsapi v21196
                              2021-08-05T18:00:23.212Z <app:NOTICE> Starting Structure...
                              2021-08-05T18:00:23.216Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
                              2021-08-05T18:00:23.217Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
                              2021-08-05T18:00:23.221Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController)
                              2021-08-05T18:00:23.222Z <Structure:INFO> Structure#1 starting controller interface weather (OWMWeatherController)
                              2021-08-05T18:00:23.223Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
                              2021-08-05T18:00:23.265Z <default:null> Module VeraController v21195
                              2021-08-05T18:00:23.269Z <default:null> Module EzloController v21199
                              2021-08-05T18:00:23.272Z <default:null> Module OWMWeatherController v21140
                              2021-08-05T18:00:23.273Z <default:null> Module SystemController v21102
                              2021-08-05T18:00:23.277Z <VeraController:NOTICE> VeraController#vera starting
                              2021-08-05T18:00:23.326Z <VeraController:INFO> VeraController#vera loaded mapping ver 21177 rev 1 format 1 notice
                              2021-08-05T18:00:23.339Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000", "serial": "90000xxx", "username": "xxx", "password": "xxx" }
                              2021-08-05T18:00:23.339Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
                              2021-08-05T18:00:23.360Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure
                              2021-08-05T18:00:23.362Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token
                              2021-08-05T18:00:23.458Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                              2021-08-05T18:00:23.505Z <app:INFO> Structure running; pausing for controllers' initial ready
                              2021-08-05T18:00:23.945Z <VeraController:WARN> VeraController#vera ignoring geotag ({ "iduser": 1520131, "geotags": [ { "PK_User": 0, "id": 1, "accuracy": 0, "ishome": 1, "notify": 1, "radius": 100, "address": "Via xxx, xxx", "color": "006e45", "latitude": "43xxx", "longitude": "11xxx", "name": "xxx, xxx", "status": --null-- } ] }) for user 1520131, user not in user list
                              2021-08-05T18:00:25.770Z <Controller:INFO> EzloController#ezlo cloud auth phase complete (local access token acquired)
                              2021-08-05T18:00:25.770Z <Controller:INFO> EzloController#ezlo opening local hub connection to "90000464" at wss://10.0.4.119:17000
                              2021-08-05T18:00:25.771Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ("90000464") certificate
                              2021-08-05T18:00:25.772Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                              2021-08-05T18:00:25.886Z <Controller:NOTICE> EzloController#ezlo successful hub login; performing inventory
                              2021-08-05T18:00:25.969Z <Controller:INFO> EzloController#ezlo data load complete; 2 devices received, 7 entities registered; 12 items.
                              2021-08-05T18:00:25.970Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 83ms
                              2021-08-05T18:00:25.972Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
                              2021-08-05T18:00:27.923Z <VeraController:NOTICE> Controller VeraController#vera is now online.
                              2021-08-05T18:00:33.533Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
                              2021-08-05T18:00:33.534Z <app:NOTICE> Starting Reaction Engine...
                              2021-08-05T18:00:33.535Z <Engine:INFO> Reaction Engine starting
                              2021-08-05T18:00:33.535Z <Engine:INFO> Checking rule sets...
                              2021-08-05T18:00:33.537Z <Engine:INFO> Checking rules...
                              2021-08-05T18:00:33.537Z <Engine:INFO> Data check complete; no corrections.
                              2021-08-05T18:00:33.539Z <Engine:5:Engine.js:1081> _process_reaction_queue() entry 628
                              2021-08-05T18:00:33.540Z <Engine:NOTICE> Reaction Engine running!
                              2021-08-05T18:00:33.540Z <app:NOTICE> Starting HTTP server and API...
                              2021-08-05T18:00:33.545Z <app:NOTICE> Startup complete
                              2021-08-05T18:00:33.546Z <Engine:5:Engine.js:1144> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting
                              2021-08-05T18:00:33.548Z <httpapi:NOTICE> HTTP API v1 21197 base URL http://10.0.4.71:8111; listening
                              2021-08-05T18:00:33.568Z <app:NOTICE> HTTP server running; registering proxy endpoints.
                              2021-08-05T18:00:33.568Z <app:NOTICE> Starting WSAPI...
                              2021-08-05T18:00:33.569Z <wsapi:NOTICE> wsapi: starting version 21196
                              2021-08-05T18:00:33.639Z <Engine:INFO> Engine#1 master timer tick, local time "8/5/2021, 8:00:33 PM" (TZ offset 120 mins from UTC)
                              2021-08-05T18:00:35.984Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                              2021-08-05T18:00:36.874Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                              2021-08-05T18:08:33.852Z <wsapi:INFO> client "172.17.0.1#2" closed, code=1001, reason=
                              2021-08-05T18:08:34.228Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                              2021-08-05T18:35:24.207Z <wsapi:INFO> client "172.17.0.1#3" closed, code=1006, reason=
                              2021-08-05T18:35:24.208Z <wsapi:INFO> client "172.17.0.1#1" closed, code=1006, reason=
                              2021-08-05T18:49:28.209Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                              2021-08-05T18:49:38.215Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
                              2021-08-05T19:00:05.004Z <Engine:INFO> Engine#1 master timer tick, local time "8/5/2021, 9:00:05 PM" (TZ offset 120 mins from UTC)
                              and the dashboard is so fluid and immediate! I love it!
                              • N Offline
                                N Offline
                                just to ask, Is there Importing ReactorSensors from Vera Reactor in synology docker method?
                                How To: Migrate Rules from the Reactor Vera Plugin - Reactor - Multi-Hub Automation
                                LibraSunL 1 Reply Last reply
                                • N noelab
                                  @noelab said in Synology Docker installation:
                                  So far as I know, the answer is "Yes" - because that's a built-in feature of MSR, and not dependent on the platform on which it is installed.
                                  Coincidentally, I never used the "Import" feature despite having dozens of rather involved Rules back on Reactor for Vera. My reasoning was, (a) I will likely build them better from scratch, (b) this is my chance to re-think a lot of my logic, and (c) with MSR being immensely more powerful, it was a good excuse to learn lexpjs and contribute (as I wound up doing far more than anticipated) to the bug/suggestion log along the way.
                                  MSR 1.0.0 is a masterpiece. Hope you enjoy the transition.
                                  N 1 Reply Last reply
                                  • N Offline
                                    N Offline
                                      N Offline
                                      N Offline
                                      @librasun yes, of course I agree with you. In Vera I based my logic using a virtual dimmer (Switchboard Plugin) per room to interact with Alexa commands behind conditions/rules in a Reactorsensor per room and only some global reactor for the house. In this way it is possible to have until 100 voice commands per room associated to 100 preset rules per dimmer, controlling them in web gui, in mobile app or alexa. So at the moment trying to understand if there is a new approach in MSR to emulate virtual devices or to find another way.
                                      • N noelab
                                        model: "h2.1"
                                        serial: "90000XXX"
                                        in config
                                        controllers:
                                          - id: vera
                                            enabled: true
                                          - id: ezlo
                                            enabled: true
                                            name: My Ezlo Hub
                                        in the log:
                                        OK. Now that you have a successful cloud authentication, you can enable anonymous access if you wish on the hub using the procedure described here:
                                        Getting Rid of the Ezlo Cloud Login Requirement
                                        Follow the directions carefully -- they will guide you through telling MSR to set the hub flags for you, and then how to reconfigure MSR so that it stops using cloud authentication for access. Also read the warning about the risks of using anonymous access. The risks of not using it are also described; only you can judge which is the right path for you.
                                          For the record, I'm using "Hyper Backup" - a native Synology NAS app - to backup my entire /REACTOR folder structure to a folder in my Google Drive cloud account. Suggest other MSR users consider doing something similar, in the event of a local NAS drive malfunction.
                                            165.3k
