  4. Synology Docker installation
31 Posts 5 Posters 13.1k Views 5 Watching
  • N Offline
    N Offline
    Hi! this is for asking an help to correct time zone.
    MSR is now installed (1.0.0-21200-16a604f) on my Synology NAS (DS 720+ with DSM 7) and Docker running on it. With my previous DS119j impossible to do anything with it.
    All entities from Vera Lite are imported ok .
    Trying to import also entities from Ezlo Plus without success.
    So looking in the "reactor.log" I notice TZ offset with something like this:
    2021-08-03T20:46:16.212Z wsapi:NOTICE wsapi: starting version 21196
    2021-08-03T20:46:16.286Z Engine:INFO Engine#1 master timer tick, local time "8/3/2021, 10:46:16 PM" (TZ offset 120 mins from UTC)
    2021-08-03T20:46:16.560Z wsapi:INFO wsapi: connection from ::ffff:172.17.0.1
    In reactor container, going on LOG tab, I have something like this:
    time = 23.00.05
    and log
    2021-08-03T23:00:05.001Z Engine:INFO Engine#1 master timer tick, local time "8/4/2021, 1:00:05 AM" (TZ offset 120 mins from UTC)
    TZ variable for reactor container is: Europe/Rome
    On nas control Panel, server NTP is on time.google.com
    in Docker LOG tab, time is correct
    Browser time and host Time in MSR GUI are correct
    does anyone have any advice?
      Seems like everything is correct. The log timestamps are always UTC. The master timer tick log entry looks correct for about the time of your posting and the time zone you show set below.
      • N Offline
        N Offline
        wrote on last edited by noelab
        #23
        I was not able to import entities from Ezlo Plus and I was thinking about a problem between time zone and access token.
        Now I have also ezlo entities imported ok but only after putting both “offlineAnonymousAccess” and “offlineInsecureAccess” set to true with API call.
        In all this ways nothing:
        config:
        username: "somebody"  # put your username here betw quotes
           password: "????????"  # and password
        then config
        set_anonymous_access: true   <--- add this line, same indent as previous
        then with
        “offlineInsecureAccess” enabled:true
        the log was:
        2021-08-04T00:08:25.648Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000/" }
        2021-08-04T00:08:25.648Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
        2021-08-04T00:08:25.667Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure
        2021-08-04T00:08:25.669Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication; hub.offline.insecure_access must be enabled!
        2021-08-04T00:08:25.696Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
        2021-08-04T00:08:25.743Z <Controller:INFO> EzloController#ezlo opening local hub connection to (undefined) at wss://10.0.4.119:17000/
        2021-08-04T00:08:25.743Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ((undefined)) certificate
        2021-08-04T00:08:25.744Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000/
        2021-08-04T00:08:25.750Z <app:INFO> Structure running; pausing for controllers' initial ready
        2021-08-04T00:08:25.856Z <Controller:INFO> EzloController#ezlo hub websocket connected; inventory hub...
        2021-08-04T00:08:25.905Z <Controller:ERR> EzloController#ezlo stopping; hub's offline insecure access is disabled, and cloud auth info is not configured
        2021-08-04T00:08:25.906Z <Controller:ERR> EzloController#ezlo failed to complete inventory: Error: hub offline anonymous access is disabled, and cloud auth info is not configured
        2021-08-04T00:08:25.907Z <Controller:CRIT> Error: hub offline anonymous access is disabled, and cloud auth info is not configured
            at /opt/reactor/server/lib/EzloController.js:895:27
            at processTicksAndRejections (internal/process/task_queues.js:95:5)
        2021-08-04T00:08:25.915Z <Controller:NOTICE> EzloController#ezlo websocket closing, 1002
        After putting both “offlineAnonymousAccess” and “offlineInsecureAccess” set to true with API call, all entities are imported OK. The problem was hub.offline.insecure_access . This is now the log:
        2021-08-04T01:01:18.564Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000/" }
        2021-08-04T01:01:18.564Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
        2021-08-04T01:01:18.593Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure
        2021-08-04T01:01:18.596Z <Controller:INFO> EzloController#ezlo performing hub login without cloud authentication; hub.offline.insecure_access must be enabled!
        2021-08-04T01:01:18.626Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
        2021-08-04T01:01:18.675Z <Controller:INFO> EzloController#ezlo opening local hub connection to (undefined) at wss://10.0.4.119:17000/
        2021-08-04T01:01:18.675Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ((undefined)) certificate
        2021-08-04T01:01:18.677Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000/
        2021-08-04T01:01:18.682Z <app:INFO> Structure running; pausing for controllers' initial ready
        2021-08-04T01:01:18.790Z <Controller:INFO> EzloController#ezlo hub websocket connected; inventory hub...
        2021-08-04T01:01:18.896Z <Controller:INFO> EzloController#ezlo data load complete; 2 devices received, 7 entities registered; 12 items.
        2021-08-04T01:01:18.897Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 105ms
        2021-08-04T01:01:18.897Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
        2021-08-04T01:01:19.152Z <VeraController:WARN> VeraController#vera ignoring geotag ({ "iduser": 1520131, "geotags": [ { "PK_User": 0, "id": 1, "accuracy": 0, "ishome": 1, "notify": 1, "radius": 100, "address": "Via , fi", "color": "006e45", "latitude": "437930", "longitude": "11210", "name": "testi, fi", "status": --null-- } ] }) for user 1520131, user not in user list
        2021-08-04T01:01:20.388Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
        2021-08-04T01:01:22.993Z <VeraController:NOTICE> Controller VeraController#vera is now online.
          OK. So first, you need to learn to post code correctly on this site so I can actually see what you're posting. Any code that you post here (including config and log snippets) should have ``` on a line by itself both before and after.
          Please repost your controller config, from the - id: line to the end of the section, just XXX out your username and password. It looks like your config isn't (and wasn't to start) correctly set up.
          • N Offline
            N Offline
            thanks for your advice.
            Now seems I'm able to import entities from EzloPlus and to access token.
            I put the ezlo plus again with previous API set and did some test again
            model: "h2.1"
            offlineAnonymousAccess: false
            offlineInsecureAccess: false
            serial: "90000XXX"
            in config
            controllers:
              - id: vera
                enabled: true
                implementation: VeraController
                name: My Vera Lite Hub
                config:
                  source: 'http://10.0.4.44:3480'
              - id: ezlo
                enabled: true
                implementation: EzloController
                name: My Ezlo Hub
                config:
                  source: "wss://10.0.4.119:17000"  # change the IP address
                  serial: "90000xxx"    # put your hub's serial # here
                  username: "xxx"  # put your username here betw quotes
                  password: "xxx"  # and password
            in the log:
            2021-08-05T18:00:23.085Z <app:null> Reactor "1.0.0-21200-16a604f" starting on v14.17.3
            2021-08-05T18:00:23.086Z <app:INFO> Process ID 1; platform linux/x64 #41890 SMP Thu Jul 15 03:37:40 CST 2021
            2021-08-05T18:00:23.086Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage
            2021-08-05T18:00:23.131Z <Plugin:null> Module Plugin v21173
            2021-08-05T18:00:23.138Z <default:INFO> Module Entity v21177
            2021-08-05T18:00:23.141Z <Controller:null> Module Controller v21191
            2021-08-05T18:00:23.141Z <default:null> Module Structure v21196
            2021-08-05T18:00:23.148Z <default:null> Module Ruleset v21096
            2021-08-05T18:00:23.148Z <default:null> Module Rulesets v21096
            2021-08-05T18:00:23.166Z <default:null> Module Rule v21168
            2021-08-05T18:00:23.173Z <default:null> Module Engine v21197
            2021-08-05T18:00:23.173Z <default:null> Module httpapi v21197
            2021-08-05T18:00:23.175Z <default:null> Module httpproxy v21054
            2021-08-05T18:00:23.187Z <default:null> Module wsapi v21196
            2021-08-05T18:00:23.212Z <app:NOTICE> Starting Structure...
            2021-08-05T18:00:23.216Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
            2021-08-05T18:00:23.217Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
            2021-08-05T18:00:23.221Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController)
            2021-08-05T18:00:23.222Z <Structure:INFO> Structure#1 starting controller interface weather (OWMWeatherController)
            2021-08-05T18:00:23.223Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
            2021-08-05T18:00:23.265Z <default:null> Module VeraController v21195
            2021-08-05T18:00:23.269Z <default:null> Module EzloController v21199
            2021-08-05T18:00:23.272Z <default:null> Module OWMWeatherController v21140
            2021-08-05T18:00:23.273Z <default:null> Module SystemController v21102
            2021-08-05T18:00:23.277Z <VeraController:NOTICE> VeraController#vera starting
            2021-08-05T18:00:23.326Z <VeraController:INFO> VeraController#vera loaded mapping ver 21177 rev 1 format 1 notice
            2021-08-05T18:00:23.339Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000", "serial": "90000xxx", "username": "xxx", "password": "xxx" }
            2021-08-05T18:00:23.339Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
            2021-08-05T18:00:23.360Z <Controller:INFO> EzloController#ezlo device data loaded; checking structure
            2021-08-05T18:00:23.362Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token
            2021-08-05T18:00:23.458Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
            2021-08-05T18:00:23.505Z <app:INFO> Structure running; pausing for controllers' initial ready
            2021-08-05T18:00:23.945Z <VeraController:WARN> VeraController#vera ignoring geotag ({ "iduser": 1520131, "geotags": [ { "PK_User": 0, "id": 1, "accuracy": 0, "ishome": 1, "notify": 1, "radius": 100, "address": "Via xxx, xxx", "color": "006e45", "latitude": "43xxx", "longitude": "11xxx", "name": "xxx, xxx", "status": --null-- } ] }) for user 1520131, user not in user list
            2021-08-05T18:00:25.770Z <Controller:INFO> EzloController#ezlo cloud auth phase complete (local access token acquired)
            2021-08-05T18:00:25.770Z <Controller:INFO> EzloController#ezlo opening local hub connection to "90000464" at wss://10.0.4.119:17000
            2021-08-05T18:00:25.771Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ("90000464") certificate
            2021-08-05T18:00:25.772Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
            2021-08-05T18:00:25.886Z <Controller:NOTICE> EzloController#ezlo successful hub login; performing inventory
            2021-08-05T18:00:25.969Z <Controller:INFO> EzloController#ezlo data load complete; 2 devices received, 7 entities registered; 12 items.
            2021-08-05T18:00:25.970Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 83ms
            2021-08-05T18:00:25.972Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
            2021-08-05T18:00:27.923Z <VeraController:NOTICE> Controller VeraController#vera is now online.
            2021-08-05T18:00:33.533Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
            2021-08-05T18:00:33.534Z <app:NOTICE> Starting Reaction Engine...
            2021-08-05T18:00:33.535Z <Engine:INFO> Reaction Engine starting
            2021-08-05T18:00:33.535Z <Engine:INFO> Checking rule sets...
            2021-08-05T18:00:33.537Z <Engine:INFO> Checking rules...
            2021-08-05T18:00:33.537Z <Engine:INFO> Data check complete; no corrections.
            2021-08-05T18:00:33.539Z <Engine:5:Engine.js:1081> _process_reaction_queue() entry 628
            2021-08-05T18:00:33.540Z <Engine:NOTICE> Reaction Engine running!
            2021-08-05T18:00:33.540Z <app:NOTICE> Starting HTTP server and API...
            2021-08-05T18:00:33.545Z <app:NOTICE> Startup complete
            2021-08-05T18:00:33.546Z <Engine:5:Engine.js:1144> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting
            2021-08-05T18:00:33.548Z <httpapi:NOTICE> HTTP API v1 21197 base URL http://10.0.4.71:8111; listening
            2021-08-05T18:00:33.568Z <app:NOTICE> HTTP server running; registering proxy endpoints.
            2021-08-05T18:00:33.568Z <app:NOTICE> Starting WSAPI...
            2021-08-05T18:00:33.569Z <wsapi:NOTICE> wsapi: starting version 21196
            2021-08-05T18:00:33.639Z <Engine:INFO> Engine#1 master timer tick, local time "8/5/2021, 8:00:33 PM" (TZ offset 120 mins from UTC)
            2021-08-05T18:00:35.984Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
            2021-08-05T18:00:36.874Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
            2021-08-05T18:08:33.852Z <wsapi:INFO> client "172.17.0.1#2" closed, code=1001, reason=
            2021-08-05T18:08:34.228Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
            2021-08-05T18:35:24.207Z <wsapi:INFO> client "172.17.0.1#3" closed, code=1006, reason=
            2021-08-05T18:35:24.208Z <wsapi:INFO> client "172.17.0.1#1" closed, code=1006, reason=
            2021-08-05T18:49:28.209Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
            2021-08-05T18:49:38.215Z <wsapi:INFO> wsapi: connection from ::ffff:172.17.0.1
            2021-08-05T19:00:05.004Z <Engine:INFO> Engine#1 master timer tick, local time "8/5/2021, 9:00:05 PM" (TZ offset 120 mins from UTC)
            and the dashboard is so fluid and immediate! I love it!
            • N Offline
              N Offline
              just to ask, Is there Importing ReactorSensors from Vera Reactor in synology docker method?
              How To: Migrate Rules from the Reactor Vera Plugin - Reactor - Multi-Hub Automation
              LibraSunL 1 Reply Last reply
              • N noelab
                @noelab said in Synology Docker installation:
                So far as I know, the answer is "Yes" - because that's a built-in feature of MSR, and not dependent on the platform on which it is installed.
                Coincidentally, I never used the "Import" feature despite having dozens of rather involved Rules back on Reactor for Vera. My reasoning was, (a) I will likely build them better from scratch, (b) this is my chance to re-think a lot of my logic, and (c) with MSR being immensely more powerful, it was a good excuse to learn lexpjs and contribute (as I wound up doing far more than anticipated) to the bug/suggestion log along the way.
                MSR 1.0.0 is a masterpiece. Hope you enjoy the transition.
                N 1 Reply Last reply
                • N Offline
                  N Offline
                  • LibraSunL LibraSun
                    N Offline
                    N Offline
                    @librasun yes, of course I agree with you. In Vera I based my logic using a virtual dimmer (Switchboard Plugin) per room to interact with Alexa commands behind conditions/rules in a Reactorsensor per room and only some global reactor for the house. In this way it is possible to have until 100 voice commands per room associated to 100 preset rules per dimmer, controlling them in web gui, in mobile app or alexa. So at the moment trying to understand if there is a new approach in MSR to emulate virtual devices or to find another way.
                    • N noelab
                      model: "h2.1"
                      serial: "90000XXX"
                      in config
                      controllers:
                        - id: vera
                          enabled: true
                          config:
                        - id: ezlo
                          enabled: true
                          name: My Ezlo Hub
                          config:
                      in the log:
                      OK. Now that you have a successful cloud authentication, you can enable anonymous access if you wish on the hub using the procedure described here:
                      Getting Rid of the Ezlo Cloud Login Requirement
                      Follow the directions carefully -- they will guide you through telling MSR to set the hub flags for you, and then how to reconfigure MSR so that it stops using cloud authentication for access. Also read the warning about the risks of using anonymous access. The risks of not using it are also described; only you can judge which is the right path for you.
                        For the record, I'm using "Hyper Backup" - a native Synology NAS app - to backup my entire /REACTOR folder structure to a folder in my Google Drive cloud account. Suggest other MSR users consider doing something similar, in the event of a local NAS drive malfunction.
                          161.3k
                          1.3k
