reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Rule stopped working
Hi
I have a quite simple rule to turn on/off a wall plug (for an amplifier) depending if a sonos device is playing or not.
Everything worked as expected. For two days.
Tonight nothing happened, and after checking HA and Sonos i clicked the reset button in reactor and in a few seconds it was working again.Is a bug that I shall report, or more likley, have I missed something in my rule?
Reactor 0.1.21058 installed on Win10. -
I would always upgrade to the latest build and retest before opening a PR
