  3. Zigbee
  4. Deconz
Zigbee
Hello oh great ones. After a couple of hours messing with ports and permissions I have Zigbee2mqtt installed and running on my virtual pi Can connect to the front end and everything Odd one though, simply cannot get systemctl to work and the error is, well, unhelpful. The service file is this: [Unit] Description=zigbee2mqtt After=network.target [Service] Environment=NODE_ENV=production Type=notify ExecStart=/usr/local/bin/node index.js WorkingDirectory=/opt/zigbee2mqtt StandardOutput=inherit # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5) StandardError=inherit WatchdogSec=10s Restart=always RestartSec=10s User=pi [Install] WantedBy=multi-user.target Straight out of the docs with the change to point to my local node install (which we know works as it's the same as the very fine Reactor is using. Running manually pnpm start in /opt/zigbee2mqtt works fine However: catman@openluup:/etc/systemd/system$ sudo systemctl start zigbee2mqtt.service Job for zigbee2mqtt.service failed because the control process exited with error code. See "systemctl status zigbee2mqtt.service" and "journalctl -xe" for details. Which I have catman@openluup:/etc/systemd/system$ sudo systemctl status zigbee2mqtt.service ● zigbee2mqtt.service - zigbee2mqtt Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; disabled; vendor preset: enabled) Active: activating (auto-restart) (Result: exit-code) since Tue 2025-12-16 12:32:42 GMT; 4s ago Process: 3093 ExecStart=/usr/local/bin/node index.js (code=exited, status=217/USER) Main PID: 3093 (code=exited, status=217/USER) and -- A start job for unit zigbee2mqtt.service has begun execution. -- -- The job identifier is 17477. Dec 16 12:35:16 openluup systemd[3178]: zigbee2mqtt.service: Failed to determine user credentials: No such process Dec 16 12:35:16 openluup systemd[3178]: zigbee2mqtt.service: Failed at step USER spawning /usr/local/bin/node: No such process -- Subject: Process /usr/local/bin/node could not be executed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The process /usr/local/bin/node could not be executed and failed. -- -- The error number returned by this process is ERRNO. Dec 16 12:35:16 openluup systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=217/USER -- Subject: Unit process exited -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- An ExecStart= process belonging to unit zigbee2mqtt.service has exited. -- -- The process' exit code is 'exited' and its exit status is 217. Dec 16 12:35:16 openluup systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'. -- Subject: Unit failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The unit zigbee2mqtt.service has entered the 'failed' state with result 'exit-code'. Dec 16 12:35:16 openluup systemd[1]: Failed to start zigbee2mqtt. -- Subject: A start job for unit zigbee2mqtt.service has failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- A start job for unit zigbee2mqtt.service has finished with a failure. Which strikes me as very odd. Any blindingly obvious things I'm missing? TIA! C
Zigbee
Zigbee
Zigbee
Zigbee
Zigbee Smart bridge
Zigbee
Silvercrest (LiDL) WiFi plug
Zigbee
L
Zigbee
Zigbee
Deconz
Zigbee
Zigbee
Deconz
13 Posts 5 Posters 4.8k Views 5 Watching
    Introduction - deCONZ REST-API
      I could probably help, as I already said to @akbooer 😆 but because of the fun involved, nothing more. I don't have the hardware, but I see a summer in my future with no beach and a lot of stay-at-home.
        After thinking hard about it, I will be putting this one on the back burner... I have a working solution with the ZHA component of Home assistant for now and have no intention of expanding my zigbee network. The only significant advantage for my setup was to get rid of the hue hub and consolidate all zigbee networks into one for the future. Zigbee is just a mess with too many semi proprietary stacks and I will try to stay away from it as much as I can.
          sender
          Have deconz on hass, with conbee2 works like charm! Beatifull interface in hass and with vnc. Only downturn is philips_hue firmware updates, thats not easy due to lack of firmware files.
            Alright after now well over 6 months using the vera zigbee chip, I have decided to bite the bullet and move to conbee2.
            I found it interesting while shopping that Aeotec is selling the razberryII for less than $18 and that there is a deconz equivalent with the raspbee II sold for the same price as the usb version. Let's see how this goes. Not giving up on the idea of a bridge for openLuup.
              @rafale77 said in Deconz:
              Currently I’m working on new concepts for plugin implementations, taking Shelly as an exemplar. If successful, this could be a framework for other protocols.
              Unlike the other place, I’m looking for a seamless evolution of API and capability. The BIG IDEA is to implement ‘plugins’ as CGI files which could be run under almost any web server. A significant part of openLuup’s extended functionality is already implemented in this way (Historian, Console, ...) For a complete transition, I would need to wrap some existing parts (Luup requests, bridges, ...) as CGIs. This would, eventually allow me to lose the weakest part of openLuup, which is its own web server...
                @rafale77 I've not invested so much into Zigbee, but count me in if you want help. I could afford a controller+some devices 🙂
                @akboer this sounds great. I was toying with the ability to explicitly implement ha bridgefeatures in LUA and offer Alexa's support natively. in general, this could help the addition of different APIs to openLuup and this sounds great!
                  I have not invested a whole lot in zigbee either. The device/mesh management is much easier than zwave on one hand but the controller implementation and stack complexity are big downsides.
                  Thanks for the support guys! I am trying to get away from having this done in home assistant. In spite of the evolution they have made, I am finding the configuration/entity setup they implemented very cumbersome and vastly prefer a z-way bridge type integration into openLuup.
                    My only Zigbee experience is through the Hue bridge and @amg0's excellent AltHUE bridge. I have installed some LED strips with compatible drivers, and they (surprise!) actually compatible, so they work fine too. Current lighting strategy is Hue for individual bulbs/strips and Shelly for relay-controlled clusters. The only other Zigbee device I have is actually a Hue motion sensor, and that seems to work well, but I have no real plans to extend the Hue network (a bit expensive.)
                    Shelly forever! (well, for a while, at least.)
                    S 1 Reply Last reply
                      sender
                      @akbooer said in Deconz:
                      Have a look at esphome.io
                      And also google at tuya convert.
                      Very reliable and cheap!
                        Yup, same technology.
                          RHCPNG
                          I was thinking of getting myself a conbee and try some zigbee. So a bridge for openluup would be very welcome! I will be monitoring this!
                            I went the lazy way for now for lack of time and just dropped in the conbee directly to replace the vera plus into home assistant using the zha component then into openLuup instead of using deconz. I would have to pick up another conbee and really start from a deconz installation to get going on a bridge...
                              162.4k
