  2. Hardware
  3. Zigbee
  4. Deconz
Genuinely impressed with Zigbee and HA / Reactor
Just for the record, in case anyone is following, I'm really rather impressed. I have installed one of these: https://www.amazon.co.uk/dp/B0B6P22YJC?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 That's connected (physically) to the VM running on my Synology, with a 2m USB extension. The same host also runs Openluup, Mosquito, HA Bridge. Yesterday I installed Zigbee2mqtt. That was a bit of a PITA but mostly because of ports and permissions. Once up and running, and the correct boxes ticked, immediately visible in Home Assistant via the MQTT integration, and thence into Reactor I've only got two devices. I bought the cheapest sensor I could find, which is a door sensor. Dead easy to add to ZIgbee2mqtt and again, immediately visible in HA. https://www.amazon.co.uk/dp/B0FPQLWRW1?ref=ppx_yo2ov_dt_b_fed_asin_title The dongle is on the top floor of the house, and I wanted the sensor on the back door (just about as far apart as it's possible to get short of going into the garage) When I moved the sensor downstairs it dropped out pretty instantly (which wasn't a huge surprise) so quick bit of research found out that smart plugs will act as routers so... https://www.amazon.co.uk/dp/B0FDQDPGBB?ref=ppx_yo2ov_dt_b_fed_asin_title Took me about 30 seconds to connect. Updated the name. Instantly visible in Reactor with the new name pushed over from Zigbee2mqtt. And lo, the door sensor now has a signal of 140 and works as far as I can tell perfectly and instantly (unlike my z-wave one). A few more of those will be purchased and used to replace the Tuya wifi cloud devices and the (continually failing) Z-wave plugs (yeah, they were TKB so....) Commended to the house. Thanks for everyone that got me on the right lines. C
Zigbee
Zigbee2mqtt installed! sytemctl not happy :(
Hello oh great ones. After a couple of hours messing with ports and permissions I have Zigbee2mqtt installed and running on my virtual pi Can connect to the front end and everything Odd one though, simply cannot get systemctl to work and the error is, well, unhelpful. The service file is this: [Unit] Description=zigbee2mqtt After=network.target [Service] Environment=NODE_ENV=production Type=notify ExecStart=/usr/local/bin/node index.js WorkingDirectory=/opt/zigbee2mqtt StandardOutput=inherit # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5) StandardError=inherit WatchdogSec=10s Restart=always RestartSec=10s User=pi [Install] WantedBy=multi-user.target Straight out of the docs with the change to point to my local node install (which we know works as it's the same as the very fine Reactor is using. Running manually pnpm start in /opt/zigbee2mqtt works fine However: catman@openluup:/etc/systemd/system$ sudo systemctl start zigbee2mqtt.service Job for zigbee2mqtt.service failed because the control process exited with error code. See "systemctl status zigbee2mqtt.service" and "journalctl -xe" for details. Which I have catman@openluup:/etc/systemd/system$ sudo systemctl status zigbee2mqtt.service ● zigbee2mqtt.service - zigbee2mqtt Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; disabled; vendor preset: enabled) Active: activating (auto-restart) (Result: exit-code) since Tue 2025-12-16 12:32:42 GMT; 4s ago Process: 3093 ExecStart=/usr/local/bin/node index.js (code=exited, status=217/USER) Main PID: 3093 (code=exited, status=217/USER) and -- A start job for unit zigbee2mqtt.service has begun execution. -- -- The job identifier is 17477. Dec 16 12:35:16 openluup systemd[3178]: zigbee2mqtt.service: Failed to determine user credentials: No such process Dec 16 12:35:16 openluup systemd[3178]: zigbee2mqtt.service: Failed at step USER spawning /usr/local/bin/node: No such process -- Subject: Process /usr/local/bin/node could not be executed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The process /usr/local/bin/node could not be executed and failed. -- -- The error number returned by this process is ERRNO. Dec 16 12:35:16 openluup systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=217/USER -- Subject: Unit process exited -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- An ExecStart= process belonging to unit zigbee2mqtt.service has exited. -- -- The process' exit code is 'exited' and its exit status is 217. Dec 16 12:35:16 openluup systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'. -- Subject: Unit failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The unit zigbee2mqtt.service has entered the 'failed' state with result 'exit-code'. Dec 16 12:35:16 openluup systemd[1]: Failed to start zigbee2mqtt. -- Subject: A start job for unit zigbee2mqtt.service has failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- A start job for unit zigbee2mqtt.service has finished with a failure. Which strikes me as very odd. Any blindingly obvious things I'm missing? TIA! C
Zigbee
Any thoughts on which is better
Obviously a quiet forum, but perhaps it's time I'm looking at rolling Zigbee into my system, in large part for the Aqara FP300 presence sensors which seem to finally provide a solution to if the wasp is actually in the box. My current set up is as follows: One Debian VM on Synology NAS running: Z-wave Server Open Luup Multi system reactor HA bridge Mosquito MQQT broker This machine has a UZB Z-wave stick connected via the USB port on the NAS Another HAOS VM on the same NAS running HAOS I've got some older Z-wave stuff that I keep around until it fails. I have some Tuya stuff integrated in HA My thought was to get either a SMLIGHT SLZB-06M or an Aqara Hub M2 Integrate them via Zigbee2MQQT (running on the Debian machine) and then expose them in HA so I can continue to automate in MSR. Thoughts on which of those devices wold be preferable long term. Both are POE capable which is good. It also appears I could add a USB dongle to the NAS and expose it to the HAOS machine. Any thoughts from the assembled experts here? TIA C
Zigbee
High temperature sensor for Zigbee
I have an oven that I need to manage the temperature of, keeping it in the neighborhood of 600° C (1100° F). I have not been able to find a Zigbee-enabled solution to measure temps that high. Does anyone know if such a thing exists? If not, any ideas for how to roll a custom solution that I could integrate into a Sonoff ihost controller? I have no trouble finding high temperature probes, but none of them interface with my automation stack.
Zigbee
Hue Tap Dial compatible online switch
I have got mainly hue bulbs around the house, apart from a couple of places where it wasn't practical or pretty enough. In those cases I put in sonoff in line switches so I can control them remotely. But now I'm wanting to further upgrade by replacing most of my light switches with Hue Tap dials (and add some fittings in where I tend to not want lots of light, but will need it some time). Then I can easily switch between different profiles and have guests do the same. Does anyone know if I can get a replacement for the sonoffs that can be recognised in Hue so that I can control it with the Tap Dials? Or alternatively any good alternatives to replacing the light switches with smart controllers? Thanks
Zigbee
Zigbee Smart bridge
I'm looking for a zigbee smart bridge recommendation. I need something I can hide in the ceiling as want to use for downlights. I don't want a pairing button, I'm looking for another idea as don't want to pull out the ceiling to re-pair. Must work with Amazon hub, as I don't want to use manufacturers hub. Any recommendations? Thanks,
Zigbee
Silvercrest (LiDL) WiFi plug
Does anyone know if it is possible to use my old Silvercrest SWS-A1 plugs with the Link2Home app or the TCP (Aldi) app?
Zigbee
Sonoff zbmini-l and philips hue
L
Hello! I have recently begun making my home smarter, and I've run into some trouble while trying to get my Sonoff zbmini-l, which is connected to my Philips Hue bridge, to work properly. I am able to control it individually, but not through scenes or with the Google Home app. Has anyone else encountered this problem and know of a fix? Additionally, I have another Zigbee bridge, but I am unable to find the Sonoff device on it. Thank you in advance for your help! PS: I am very new to this.
Zigbee
Sudden offset in temperature reading
PerHP
Zigbee
Deconz
After researching a number of various Zigbee solutions, I have come to the conclusion that Deconz with a ConbeeII is probably the best one available, covering the two HA1.2 stacks and ZLL stacks with the widest compatibility range, even better than the ZHA or Zigbee2MQTT components of Home Assistant, and also the best maintained with regurlar firmware updates. It is really an equivalent to z-way but for zigbee. It has a rest API so I am dreaming awake of a bridge for openLuup here... https://dresden-elektronik.github.io/deconz-rest-doc/ Could be a good project? I may get one to play with... It could potentially enable unifying the hue devices into one network.
Zigbee
2.4Ghz band Zigbee, WIFI, BT, Microwave, Cordless Phones Interferences. What Zigbee channel to pick?
Kicking off this section with a quick write up on Zigbee 2.4GHz channel utilization. Zigbee has become a very popular protocol over the past few years mostly due to its low power consumption, low chip cost (not being proprietary like z-wave was) and ease of inclusion. It does come with a couple of downsides however ranging from single controller topography (aka single PAN coordinator) to what the title says: It uses the 2.4GHz (ISM) band which is possibly ultra saturated by other wireless protocols and even a variety of other more or less proprietary zigbee stacks. (i.e philips hue, Ikea Tradfi, Xiaomi, Plantlink etc...) It is therefore important to make sure they don't interfere with one another. This is a good article showing the correspondence between Zigbee and WIFI. https://support.metageek.com/hc/en-us/articles/203845040-ZigBee-and-WiFi-Coexistence Interferences lead to range reduction, dropped packets, more retries and lags. I have a 2.4GHz spectrum analyzer I can post some results from. I read through the zigbee alliance presentation claiming low interference but my experience demonstrates quite the opposite. When I was using SonosNET and Hue at the same time on neighboring channels, playing SONOS would kill the philips hue network.
Zigbee
Deconz
Scheduled Pinned Locked Moved Zigbee
13 Posts 5 Posters 4.7k Views 5 Watching
    sender
    Have deconz on hass, with conbee2 works like charm! Beatifull interface in hass and with vnc. Only downturn is philips_hue firmware updates, thats not easy due to lack of firmware files.
      Alright after now well over 6 months using the vera zigbee chip, I have decided to bite the bullet and move to conbee2.
      I found it interesting while shopping that Aeotec is selling the razberryII for less than $18 and that there is a deconz equivalent with the raspbee II sold for the same price as the usb version. Let's see how this goes. Not giving up on the idea of a bridge for openLuup.
        @rafale77 said in Deconz:
        Currently I’m working on new concepts for plugin implementations, taking Shelly as an exemplar. If successful, this could be a framework for other protocols.
        Unlike the other place, I’m looking for a seamless evolution of API and capability. The BIG IDEA is to implement ‘plugins’ as CGI files which could be run under almost any web server. A significant part of openLuup’s extended functionality is already implemented in this way (Historian, Console, ...) For a complete transition, I would need to wrap some existing parts (Luup requests, bridges, ...) as CGIs. This would, eventually allow me to lose the weakest part of openLuup, which is its own web server...
        • therealdbT Online
          therealdbT Online
          @rafale77 I've not invested so much into Zigbee, but count me in if you want help. I could afford a controller+some devices 🙂
          @akboer this sounds great. I was toying with the ability to explicitly implement ha bridgefeatures in LUA and offer Alexa's support natively. in general, this could help the addition of different APIs to openLuup and this sounds great!
            I have not invested a whole lot in zigbee either. The device/mesh management is much easier than zwave on one hand but the controller implementation and stack complexity are big downsides.
            Thanks for the support guys! I am trying to get away from having this done in home assistant. In spite of the evolution they have made, I am finding the configuration/entity setup they implemented very cumbersome and vastly prefer a z-way bridge type integration into openLuup.
              My only Zigbee experience is through the Hue bridge and @amg0's excellent AltHUE bridge. I have installed some LED strips with compatible drivers, and they (surprise!) actually compatible, so they work fine too. Current lighting strategy is Hue for individual bulbs/strips and Shelly for relay-controlled clusters. The only other Zigbee device I have is actually a Hue motion sensor, and that seems to work well, but I have no real plans to extend the Hue network (a bit expensive.)
              Shelly forever! (well, for a while, at least.)
              S 1 Reply Last reply
                sender
                @akbooer said in Deconz:
                Have a look at esphome.io
                And also google at tuya convert.
                Very reliable and cheap!
                  Yup, same technology.
                    RHCPNG
                    I was thinking of getting myself a conbee and try some zigbee. So a bridge for openluup would be very welcome! I will be monitoring this!
                      I went the lazy way for now for lack of time and just dropped in the conbee directly to replace the vera plus into home assistant using the zha component then into openLuup instead of using deconz. I would have to pick up another conbee and really start from a deconz installation to get going on a bridge...
                        158.7k
