  3. Zigbee
  4. Zigbee2mqtt installed! sytemctl not happy :(
Zigbee
Hello oh great ones. After a couple of hours messing with ports and permissions I have Zigbee2mqtt installed and running on my virtual pi Can connect to the front end and everything Odd one though, simply cannot get systemctl to work and the error is, well, unhelpful. The service file is this: [Unit] Description=zigbee2mqtt After=network.target [Service] Environment=NODE_ENV=production Type=notify ExecStart=/usr/local/bin/node index.js WorkingDirectory=/opt/zigbee2mqtt StandardOutput=inherit # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5) StandardError=inherit WatchdogSec=10s Restart=always RestartSec=10s User=pi [Install] WantedBy=multi-user.target Straight out of the docs with the change to point to my local node install (which we know works as it's the same as the very fine Reactor is using. Running manually pnpm start in /opt/zigbee2mqtt works fine However: catman@openluup:/etc/systemd/system$ sudo systemctl start zigbee2mqtt.service Job for zigbee2mqtt.service failed because the control process exited with error code. See "systemctl status zigbee2mqtt.service" and "journalctl -xe" for details. Which I have catman@openluup:/etc/systemd/system$ sudo systemctl status zigbee2mqtt.service ● zigbee2mqtt.service - zigbee2mqtt Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; disabled; vendor preset: enabled) Active: activating (auto-restart) (Result: exit-code) since Tue 2025-12-16 12:32:42 GMT; 4s ago Process: 3093 ExecStart=/usr/local/bin/node index.js (code=exited, status=217/USER) Main PID: 3093 (code=exited, status=217/USER) and -- A start job for unit zigbee2mqtt.service has begun execution. -- -- The job identifier is 17477. Dec 16 12:35:16 openluup systemd[3178]: zigbee2mqtt.service: Failed to determine user credentials: No such process Dec 16 12:35:16 openluup systemd[3178]: zigbee2mqtt.service: Failed at step USER spawning /usr/local/bin/node: No such process -- Subject: Process /usr/local/bin/node could not be executed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The process /usr/local/bin/node could not be executed and failed. -- -- The error number returned by this process is ERRNO. Dec 16 12:35:16 openluup systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=217/USER -- Subject: Unit process exited -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- An ExecStart= process belonging to unit zigbee2mqtt.service has exited. -- -- The process' exit code is 'exited' and its exit status is 217. Dec 16 12:35:16 openluup systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'. -- Subject: Unit failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The unit zigbee2mqtt.service has entered the 'failed' state with result 'exit-code'. Dec 16 12:35:16 openluup systemd[1]: Failed to start zigbee2mqtt. -- Subject: A start job for unit zigbee2mqtt.service has failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- A start job for unit zigbee2mqtt.service has finished with a failure. Which strikes me as very odd. Any blindingly obvious things I'm missing? TIA! C
Zigbee
Zigbee
Zigbee
Zigbee
Zigbee Smart bridge
Zigbee
Silvercrest (LiDL) WiFi plug
Zigbee
L
Zigbee
Zigbee
Deconz
Zigbee
Zigbee
Scheduled Pinned Locked Moved Solved Zigbee
4 Posts 2 Posters 1.7k Views 2 Watching
    Can connect to the front end and everything 🙂
    [Unit]
    [Service]
    Type=notify
    WatchdogSec=10s
    Restart=always
    RestartSec=10s
    User=pi
    [Install]
    However:
    Which I have
    and
    TIA!
      Have you looked in the logs in /var/log for other messages? Usually there's a good bit more chatter there that can be helpful.
        Good call. Syslog:
        Dec 16 12:30:09 openluup systemd[1]: Stopped zigbee2mqtt.
        Dec 16 12:30:09 openluup systemd[1]: Starting zigbee2mqtt...
        Dec 16 12:30:09 openluup systemd[2984]: zigbee2mqtt.service: Failed to determine user credentials: No such process
        Dec 16 12:30:09 openluup systemd[2984]: zigbee2mqtt.service: Failed at step USER spawning /usr/local/bin/node: No such process
        Dec 16 12:30:09 openluup systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=217/USER
        Dec 16 12:30:09 openluup systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'.
        Dec 16 12:30:09 openluup systemd[1]: Failed to start zigbee2mqtt.
        Same message in all of them 😞
        zigbee2mqtt doesn't even log when started from systemctl
          FFS!
          User=pi
          Looks like it's fixed
          • CatmanV2C CatmanV2 marked this topic as a question on
          • CatmanV2C CatmanV2 has marked this topic as solved on
            155.5k
