  3. Zigbee
  4. Genuinely impressed with Zigbee and HA / Reactor
Zigbee
Hello oh great ones. After a couple of hours messing with ports and permissions I have Zigbee2mqtt installed and running on my virtual pi Can connect to the front end and everything Odd one though, simply cannot get systemctl to work and the error is, well, unhelpful. The service file is this: [Unit] Description=zigbee2mqtt After=network.target [Service] Environment=NODE_ENV=production Type=notify ExecStart=/usr/local/bin/node index.js WorkingDirectory=/opt/zigbee2mqtt StandardOutput=inherit # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5) StandardError=inherit WatchdogSec=10s Restart=always RestartSec=10s User=pi [Install] WantedBy=multi-user.target Straight out of the docs with the change to point to my local node install (which we know works as it's the same as the very fine Reactor is using. Running manually pnpm start in /opt/zigbee2mqtt works fine However: catman@openluup:/etc/systemd/system$ sudo systemctl start zigbee2mqtt.service Job for zigbee2mqtt.service failed because the control process exited with error code. See "systemctl status zigbee2mqtt.service" and "journalctl -xe" for details. Which I have catman@openluup:/etc/systemd/system$ sudo systemctl status zigbee2mqtt.service ● zigbee2mqtt.service - zigbee2mqtt Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; disabled; vendor preset: enabled) Active: activating (auto-restart) (Result: exit-code) since Tue 2025-12-16 12:32:42 GMT; 4s ago Process: 3093 ExecStart=/usr/local/bin/node index.js (code=exited, status=217/USER) Main PID: 3093 (code=exited, status=217/USER) and -- A start job for unit zigbee2mqtt.service has begun execution. -- -- The job identifier is 17477. Dec 16 12:35:16 openluup systemd[3178]: zigbee2mqtt.service: Failed to determine user credentials: No such process Dec 16 12:35:16 openluup systemd[3178]: zigbee2mqtt.service: Failed at step USER spawning /usr/local/bin/node: No such process -- Subject: Process /usr/local/bin/node could not be executed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The process /usr/local/bin/node could not be executed and failed. -- -- The error number returned by this process is ERRNO. Dec 16 12:35:16 openluup systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=217/USER -- Subject: Unit process exited -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- An ExecStart= process belonging to unit zigbee2mqtt.service has exited. -- -- The process' exit code is 'exited' and its exit status is 217. Dec 16 12:35:16 openluup systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'. -- Subject: Unit failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The unit zigbee2mqtt.service has entered the 'failed' state with result 'exit-code'. Dec 16 12:35:16 openluup systemd[1]: Failed to start zigbee2mqtt. -- Subject: A start job for unit zigbee2mqtt.service has failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- A start job for unit zigbee2mqtt.service has finished with a failure. Which strikes me as very odd. Any blindingly obvious things I'm missing? TIA! C
Zigbee
Zigbee
Zigbee
Zigbee
Zigbee Smart bridge
Zigbee
Silvercrest (LiDL) WiFi plug
Zigbee
L
Zigbee
Zigbee
Deconz
Zigbee
Zigbee
9 Posts 2 Posters 2.1k Views 2 Watching
    SONOFF Universal Zigbee 3.0 USB Dongle Plus ZBDongle E Gateway with Antenna for Home Assistant, Open HAB etc, Support Data Flow Control : Amazon.co.uk: Computers & Accessories
    SONOFF S60ZBTPG Smart Plug (Requires Zigbee Gateway) – Remote Control, Energy Monitoring, Timer Schedules, Overload Protection, Zigbee Repeater, Compatible with eWeLink App : Amazon.co.uk: DIY & Tools
      The migration has started. Pulling Z-wave devices and replacing them with Zigbee. Really successful so far. Much much snappier response. No range issues as each socket I'm adding acts as a router. Gonna have a play later see if I can flash the Tuya cloud plugs I bought to Tasmota....
        So far just keeps getting better. I thought I'd hit a snag yesterday wit the newly installed garage light switch being slow to trigger (IRO 6 seconds) but realised I was using the wrong HASS sensor attribute (durrr) once I sorted that, it's all sorted. Typical response times are sub second.
        Some oddities in where I've migrated with some hacky virtual switches which I need to track down. I'd get rid of them but trying to expose HA entities to Alexa seems a bit hit and miss...
          I tried different things and after all I’ve just switched to my own emulated hue bridge, calling reactor HTTP endpoints. I was toying with the idea of sending MQTT commands, but HTTP just works. I did my own bridge because I have 100 switches/scenes/virtual switches mapped to Alexa and ha-bridge has not the ability to define multiple bridges on the same host, so I wrote mine 😬
          But ha-bridge should just work. Never tried HASS native hue emulation. I tried matter bridge and unfortunately Alexa will only see 20 devices.
            @therealdb only just caught up on this. HA bridge works fine for me, in fact it's 100% reliable until it's not (if that makes sense)
            Biggest issue I have is that Alexa is very reluctant to update a named entity. If I point the same HA Bridge endpoint to a different Vera device, that's fine. If I delete one and re-create one with the same name, absolutely no go as far as Alexa is concerned. Delete it from the Alexa app, re-discover. Totally not interested.
            So I've worked out a hack where I call it something random in HA Bridge, then Alexa discovers it, it works fine, then I can rename it in the Alexa app.
            I am, however, having issues getting Alexa to see exposed endpoints from HA
              Yes, same here. Once discovered, you have to stick with it.
              I’m calling reactor endpoints to control hass devices. I posted the urls in a previous post, but I could post it again if needed.
                @therealdb if you could, that would be super. I seem to have missed...
                  @CatmanV2 here we go: https://smarthome.community/topic/1593/howto-using-habridge-with-reactor
                    Well pretty much complete with the migration. I have one Fibaro smart module left which will be retired when my external Temperature / Humidity sensor arrives today, then the main and underfloor thermostats (which I will probably keep as response time is not really a major issue)
                    There's a stack of virtual switches which trigger things like getting up and going to bed. I can replace those in HA (and probably will).
                      157.7k
