  3. Zigbee
  4. Sudden offset in temperature reading
Zigbee
Hello oh great ones. After a couple of hours messing with ports and permissions I have Zigbee2mqtt installed and running on my virtual pi Can connect to the front end and everything Odd one though, simply cannot get systemctl to work and the error is, well, unhelpful. The service file is this: [Unit] Description=zigbee2mqtt After=network.target [Service] Environment=NODE_ENV=production Type=notify ExecStart=/usr/local/bin/node index.js WorkingDirectory=/opt/zigbee2mqtt StandardOutput=inherit # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5) StandardError=inherit WatchdogSec=10s Restart=always RestartSec=10s User=pi [Install] WantedBy=multi-user.target Straight out of the docs with the change to point to my local node install (which we know works as it's the same as the very fine Reactor is using. Running manually pnpm start in /opt/zigbee2mqtt works fine However: catman@openluup:/etc/systemd/system$ sudo systemctl start zigbee2mqtt.service Job for zigbee2mqtt.service failed because the control process exited with error code. See "systemctl status zigbee2mqtt.service" and "journalctl -xe" for details. Which I have catman@openluup:/etc/systemd/system$ sudo systemctl status zigbee2mqtt.service ● zigbee2mqtt.service - zigbee2mqtt Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; disabled; vendor preset: enabled) Active: activating (auto-restart) (Result: exit-code) since Tue 2025-12-16 12:32:42 GMT; 4s ago Process: 3093 ExecStart=/usr/local/bin/node index.js (code=exited, status=217/USER) Main PID: 3093 (code=exited, status=217/USER) and -- A start job for unit zigbee2mqtt.service has begun execution. -- -- The job identifier is 17477. Dec 16 12:35:16 openluup systemd[3178]: zigbee2mqtt.service: Failed to determine user credentials: No such process Dec 16 12:35:16 openluup systemd[3178]: zigbee2mqtt.service: Failed at step USER spawning /usr/local/bin/node: No such process -- Subject: Process /usr/local/bin/node could not be executed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The process /usr/local/bin/node could not be executed and failed. -- -- The error number returned by this process is ERRNO. Dec 16 12:35:16 openluup systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=217/USER -- Subject: Unit process exited -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- An ExecStart= process belonging to unit zigbee2mqtt.service has exited. -- -- The process' exit code is 'exited' and its exit status is 217. Dec 16 12:35:16 openluup systemd[1]: zigbee2mqtt.service: Failed with result 'exit-code'. -- Subject: Unit failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- The unit zigbee2mqtt.service has entered the 'failed' state with result 'exit-code'. Dec 16 12:35:16 openluup systemd[1]: Failed to start zigbee2mqtt. -- Subject: A start job for unit zigbee2mqtt.service has failed -- Defined-By: systemd -- Support: https://www.debian.org/support -- -- A start job for unit zigbee2mqtt.service has finished with a failure. Which strikes me as very odd. Any blindingly obvious things I'm missing? TIA! C
Zigbee
Zigbee
Zigbee
Zigbee
Zigbee Smart bridge
Zigbee
Silvercrest (LiDL) WiFi plug
Zigbee
L
Zigbee
Zigbee
Deconz
Zigbee
Zigbee
9 Posts 4 Posters 3.5k Views 4 Watching
    wrote on last edited by PerH
    One of my aqara sensors suddenly stated that the temperature in the garage passed +650 degrees.. I checked, and it wasn't. 😉
    Both humidity and pressure is reading normal levels - i guess this must be a HW error?
    Its not dead either, just severely offset:
      strange indeed... seems like a hardware problem!
        Took out the battery for a moment, and now its back.. Just a "senior moment" (well, 10 hours) i guess!
          ..and now its back at 655° again.. order a new one i guess..
          • I Offline
            I Offline
            iRobot
            wrote on last edited by iRobot
            If it's suppose to be around 65F° then it it could be a notation error. Mixing up decimal points and decimal comma
            US notation 65.5 would result in 655 when the notation is not set to imperial. E.g. EU notation is 65,5.
            Still doesn't explain why it changes all of the sudden though.
              Hm! It wasn't that, but rather when it goes below 0° C! (cold in Norway)
              I'll throw one of the others outside to see if the same happens, mabye its a flaw in the zigate plugin?
                Sounds like a signed value is being interpreted as an unsigned one, so the MSB is set when the temperature goes negative. I’d guess that a 16 bit value is scaled so that 32768 = 327.68 degrees. This would also be consistent with the UPnP standard representation of temperature being in units of 1/100 of a degree.
                  ..And this is done in the plugin, i presume? Seems like all message handling is done there in zigbee?
                  I'll have a look at the code tomorrow..
                    If it’s as I think, then the fix is easy... if the value exceeds 327.67 then subtract it from that number.
                      163.8k
