x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Hey @toggledbits
Why can you select Vera scenes as a trigger?
You can trigger on any entity, and since a script is an entity, it's on the list. That said, I've found Vera's reporting of scene state to be very inconsistent, so caveat emptor.
