authtrack:
max_attempts: 4
EDIT: some logs
reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
New to MSR, my observations
Sorry if some of these have been answered or explained elsewhere, I tried to find it in the docs, mantis or forums.
Never used Reactor and now migrating everything to MSR, I have a few questions
- Is this expected or a bug?
This scenario is not intended to use in any automation, only for demo purpose:
- Create trigger for example Weekday - Select today as day, set condition to Pulse and save.
- Expand the Rule and the trigger pulse green.
- Change the condition back to Follow and save.
- Hard refresh browser, Expand the rule and the trigger still pulse green.
Is there a way to simulate a different time of day to see what happens with various Rules? If not this would be a neat feature.
Feature request: Subgroups in Rule sets.
Am I going to complex trying to do On and Off schedules in the same Rule set? Seems like it's doable due to Reset Reactions.
Constraints - blocks the Rule when NOT Constraints is false? and Set triggers to true when NOT Constraints is true? Correct? (I confuse myself with negation and booleans)
