  4. Adding Homeseer as a Controller
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
4 Posts 2 Posters 1.5k Views 2 Watching
  • Black CatB Offline
    Black CatB Offline
    Black Cat
    How can I do this?
    The topic in the instructions is very limited.
    Other Controllers
    Other controllers that you may find as add-ins will each have their own specific configuration instructions. Please refer to their accompanying documentation.
    What information should I be looking for?
    I've tried port 1880 which is used for node-red, assuming that this is a listening port - no go. Really not sure how to go about this as everything I do is mostly trial & error.
    BTW, I added my Vera Lite into the mix successfully, HS4 would make it a trifecta!
    aka Zedrally
    • toggledbitsT Online
      toggledbitsT Online
      There isn't yet a controller for Homeseer, and I don't have/use it myself. Another thing to add to my list...
        Black CatB Offline
        Black Cat
        So there are no instructions on how to roll your own?
        Would MQTT be a better solution for use of peripheral controllers?
        aka Zedrally
          Black CatB Offline
          Black Cat
          I've done some reading on the HS forums and a workable solution might be to use the HASS Controller.
          The theory being to run HASS > MQTT > HS, it seems convoluted but should work, I'll give a go tomorrow.
          aka Zedrally
            164.0k
