  4. Running reactions /Blocked?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 3 Posters 1.0k Views 3 Watching
    Matteburk
    What does Blocked mean in running reactions?
    Anyone having a lot of empty alerts that is not possible to erase?
    Hubitat - MSR
    /Mattias!
      I initially saw a few of those empty alerts but haven't seen any recently.
      • toggledbitsT Online
        toggledbitsT Online
        As @cw-kid said, empty alerts were an issue several versions ago, but I think they're dealt with, so make sure you're on 21106.
        A reaction being BLOCKED means that it is waiting for a driver of some type to finish work on a step (that step is identified as #0, so it's the first step in those reactions). The drivers can be Controllers (when performing an action on an entity) or Notifiers (when sending a notification). Normally, a reaction will only remain in this state for a few milliseconds, and is so quick that most people will never even know this state exists. If you have reactions in BLOCKED state and that passes within a minute, that's an indication that whatever the step is doing is timing out (e.g. communicating with a remote API that is not responding and timing out, or taking a very long time to respond). This can happen to controllers and notifiers. If a reaction is stuck in BLOCK state until you restart MSR, that indicates something went very wrong with the run of that reaction (there's a lot of coding to prevent situations like this). Either way, looking at the reactor.log file will give some clues.
          164.0k
