x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Hey @toggledbits
Contents of fields now hidden
Already fixed for next release.
I'm still seeing some weird behaviour in regards to this on build 21118.
This is another rule I've just looked at, the first HTTP request was fully visible OK, however the second HTTP request was not visible at all.
Noted that the second HTTP request is longer in length than the first one, which is why there is a scroll bar present.
