  4. SMTP Gmail issue
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
SMTP Gmail issue
14 Posts 5 Posters 4.1k Views 4 Watching
  • ElcidE Offline
    ElcidE Offline
    Elcid
    Having issues with gmail. This was working 3 days ago. I updated to nodejs14 and for some reason had to reinstall MSR I did not have backup of notification.yaml, so re-entered the settings. The log is showing the smtp call is timing out. Any Ideas. I turn logging to 6 but no aditional info.
      Have you tried connecting to the configured server direct from a command line? What options are you passing in the yaml file?
      ElcidE 1 Reply Last reply
        ElcidE Offline
        ElcidE Offline
        Elcid
        notification:
          # Alert is the system-default notification method that displays an alert
          # in the Status tab of the UI. It has no options.
          Alert: {}
          # SMTP (Simple Mail Transfer Protocol, for sending email)
          SMTP:
            profiles:
              default:
                # description - A friendly description of this profile (for menus)
                description: main email
                # host - Hostname or IP address of SMTP server. Default: localhost
                host: "smtp.gmail.com"
                # port - Port on which to make connection. The typical values are 25,
                #        465, and 587. Port 25 is usually only usable for local (LAN)
                #        servers, as some ISPs block it for SPAM control. Port 465 is
                #        usually for SSL/TLS-originated connections to the MTA, and
                #        port 587 is for STARTTLS to the MTA. If you're not sure, it's
                #        usually best to start with 587. Default is 25.
                port: 465
                # allow_invalid_cert - if true, self-signed certificates are accepted
                #                      on secure connections; otherwise, they are not
                #                      verified.
                #allow_invalid_cert: true
                # sender - email address to be used in "from" field of messages. The
                #          default is "username+reactor@hostname" where username is
                #          the user under which the Reactor service is running.
                sender: "********@gmail.com"
                # default_recipient - email address to use when no recipients are spec-
                #                     ified in the Notify action. This can be a list of
                #                     comma-separated values. Default: sender address.
                default_recipient: "*******@gmail.com"
                # default_subject - default subject if the notification does not provide
                #                   one.
                default_subject: "Notification from Reactor"
                # username and password - for authentication with the MTA. If not given,
                #                         no login/auth is attempted (often acceptable
                #                         for connections to local/LAN servers).
                username: "*****@gmail.com"
                password: "dddjdyyyddkfuyydysb"
                # auth_method - Future. Don't uncomment or modify the line below.
                #auth_method: "PLAIN"
                # secure: if true, an SSL/TLS connection is established to the specified
                #         port. If false, STARTTLS is attempted after connecting. It is
                #         usually NOT necessary to uncomment and use this value; please
                #         not uncomment it unless advised to do so.
                #secure: false
                # ignore_tls - if true, STARTTLS is not used even if the server
                #              advertises its support. This is sometimes useful for MTA
                #              connections to servers on trusted/local/LAN networks.
                #ignore_tls: false
        • ElcidE Offline
          ElcidE Offline
          Elcid
          wrote on last edited by Elcid
          I get no response from
          openssl s_client -connect smtp.gmail.com:465
          if i leave it a minute i get
          4024960164:error:0200206E:system library:connect:Connection timed out:crypto/bio/b_sock2.c:110:
          4024960164:error:2008A067:BIO routines:BIO_connect:connect error:crypto/bio/b_sock2.c:111:
          connect:errno=110
          I have googled error and it suggests the wrong port or server is refusing secure connections on that port.
          465 is the standard gmail smtp port that i use in reactor.
            I can connect to smtp.gmail.com on 465 fine from where I am (using openssl as you gave it), so it suggests either a temporary routing failure of your upstream or maybe incorrect network configuration on your network (incorrect netmask, firewall/filtering, etc.).
            • ElcidE Offline
              ElcidE Offline
              Elcid
              Ok, that got me thinking, turns out app password is being blocked when vpn is on, this hasbeen working for over a year. They really are making vpn's more difficult
              seems google is blocking ipvanish maidenhead servers, I have moved back to london as they are still working.
                That would do it. Glad you're sorted, although why do you want to use a VPN to connect to them?
                • ElcidE Offline
                  ElcidE Offline
                  Elcid
                  So my ISP does not get a record of my internet interactions, also it stops them throttling my connection my upload speed goes from 1.3 to 5 when connected to a VPN all for $39 a year unlimited with 500gb cloud storage
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    Hi @Elcid do you recommend IPVanish?
                    • ElcidE Offline
                      ElcidE Offline
                      Elcid
                      Yes the connection is very stable my 35 mb /10mb connection gets 30/1.2 normally from my ISP
                      when connected to VPN I get 20-28 /5mb. and connection is stable very rarely do I get VPN connection issues.
                      There help desk response time is pretty good to. The VPN is unlimited downloads and devices.
                      I have also got 80mb when downloading multiple files simultaneously
                      They also have split tunneling so you can bypass VPN for certain apps, and you can allow local lan access without VPN
                        I've been using IPVanish for a couple three years now. I have had success with it. Little pricey but seemingly more stable than others.
                        • ElcidE Offline
                          ElcidE Offline
                          Elcid
                          How is $39 a year pricey?
                          • ElcidE Elcid
                            @elcid You should review their pricing. $39 for the first year... future years it's ~$80. I've been with them a couple three years now.
                              ElcidE Offline
                              ElcidE Offline
                              Elcid
                              @gwp1 I have been with them for 3 -4 years and never paid more than $4 a month. I have haggle every year and I get an offer every year, but this year I just used a different email address.
                                163.8k
