reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Help with MSR Rule
I have been trying to get my windowshadeautomation (outside window)to work for some time in reactor but I cant get it working good..
What I want is that shades should close if above 20000lux if window is closed else if window open only set shade position to 0.7And if shade is closed and window is opened shade should go to 0.7 and if closed again shade should go back to closed
I have tried so many variants with different results.
I need som help...
/Mattias
I have :Trigger
light sensor ( above 20000 lux )Constraint
Rainsensor ( no rain)
Windsensor(no wind)
Window (closed, or open )Set reaction
Cover close or set 0.7Reset reaction
Cover open -
