  4. Ezlo device capabilities
31 Posts 3 Posters 9.2k Views 2 Watching
  • ElcidE Offline
    ElcidE Offline
    Elcid
    great, just one last question, I take it remote.send_codes will just send ir codes?
      Yes, do you need RF as well?
      • ElcidE Offline
        ElcidE Offline
        Elcid
        No, just confirming. I can use x_ezlo_device.set_item_value
          I'm actually going to remove the remote capability and split it into ir_remote and rf_remote... I kind of realized I made an error making the capability name too generic. So that will be in today's build, which will break your actions, but I don't think we'll need to change it again.
          • ElcidE Offline
            ElcidE Offline
            Elcid
            wrote on last edited by Elcid
            #25
            I took your early advice and have only been testing on MSR. Now 1.0 has been released, I will of course now start moving from Reactor to MSR. Having Ezlo Broadlink has brought my Broadlink under local (not sure if ezlo is using local or cloud integration for Broadlink, msr>>ezlo>>broadlink>>device, It seem instantaneous)) control, and I can now drop my Alexa remote2 workaround.
              Cool. I just posted 21201. Since I can't test myself, you're the first to try. Let me know how it works out.
              • ElcidE Offline
                ElcidE Offline
                Elcid
                #27
                21201 failed to load ezlo controller, I have uploaded a log file to mantis bug tracker
                  Can you look in your console logs (there is some logging that occurs prior to the internal logger being started, and it logs to the console), and see what it reports for the module path?
                  • ElcidE Offline
                    ElcidE Offline
                    Elcid
                    module.paths [
                      '/data/data/com.termux/files/home/reactor/node_modules',
                      '/data/data/com.termux/files/home/node_modules',
                      '/data/data/com.termux/files/node_modules',
                      '/data/data/com.termux/node_modules',
                      '/data/data/node_modules',
                      '/data/node_modules',
                      '/node_modules'
                    NODE_PATH undefined
                      I sent you some info on the PR for setting NODE_PATH. Give that a go and see what happens
                      • ElcidE Offline
                        ElcidE Offline
                        Elcid
                        #31
                        Setting node path worked, still not getting ir_remote_send_codes to work though. I added to the PR
                          146.8k
