  4. Vera - Attempt to set primary to power_switch.state invalid
12 Posts 2 Posters 2.0k Views 2 Watching
    I am seeing errors like these in the log file:
    <VeraController:NOTICE> Controller VeraController#vera-edge is now online.
    2021-07-22T15:41:29.586Z <default:ERR> [Entity:setPrimaryAttribute] Attempt to set primary to power_switch.state invalid, not in { "x_vera_device": { "device_number": 139, "device_type": "urn:schemas-upnp-org:device:RGBController:1", "parent_device": 0, "failed": false, "configured": --null--, "mapped_class": "rgbcontroller_plugin", "mapped_by": "*;device_type=urn:schemas-upnp-org:device:RGBController:1" }, "x_vera_svc_upnp_org_RGBController1": {  }, "x_vera_svc_upnp_org_SwitchPower1": {  }, "x_vera_svc_micasaverde_com_HaDevice1": {  }, "x_vera_rgbcontroller_plugin": { "device_type": "FGRGBWM-441", "configured": true, "color": "#0000000000", "message": "" } }
    2021-07-22T15:41:29.587Z <VeraController:ERR> VeraController#vera exception/error while updating VeraController#vera
    2021-07-22T15:41:29.588Z <VeraController:CRIT> Error: Entity#vera>device_139:setPrimaryAttribute() can't set power_switch.state, not defined for entity
    and
    <default:ERR> [Entity:setPrimaryAttribute] Attempt to set primary to power_switch.state invalid, not in { "x_vera_device": { "device_number": 75, "device_type": "urn:schemas-micasaverde-com:device:WindowCovering:1", "parent_device": 1, "failed": false, "configured": false, "mapped_class": "fibaro_cover_scenecontrol", "mapped_by": "*;device_type=urn:schemas-micasaverde-com:device:WindowCovering:1;pnp=/^(3222)$/" }, "x_vera_svc_upnp_org_SwitchPower1": {  }, "x_vera_svc_upnp_org_Dimming1": {  }, "x_vera_svc_upnp_org_WindowCovering1": {  }, "x_vera_svc_micasaverde_com_Protection1": {  }, "x_vera_svc_micasaverde_com_EnergyMetering1": {  }, "x_vera_svc_micasaverde_com_HaDevice1": {  }, "x_vera_svc_micasaverde_com_ZWaveDevice1": {  }, "x_vera_svc_micasaverde_com_ZWaveNetwork1": {  }, "x_vera_svc_micasaverde_com_GenericSensor1": {  }, "x_vera_svc_micasaverde_com_Color1": {  }, "x_vera_svc_micasaverde_com_SceneController1": {  }, "cover": { "state": false }, "position": { "value": 0 }, "zwave_scene_controller": { "scene_activated": "0", "key_attribute": --null--, "scene_deactivated": --null--, "central_scene": --null-- }, "x_vera_scene_controller": { "last_scene_id": "26", "last_scene_time": "1626714753" } }
    2021-07-22T15:41:28.925Z <VeraController:ERR> VeraController#vera exception/error while updating VeraController#vera
    2021-07-22T15:41:28.926Z <VeraController:CRIT> Error: Entity#vera>device_75:setPrimaryAttribute() can't set power_switch.state, not defined for entity
    What does it mean?
    One is an RGBW Plugin device the other is a real Z-Wave device, a Fibaro Roller Shutter 2.
      In the config section of the controller configuration (in reactor.yaml ) for this controller (vera, apparently, not vera-edge), please add the following, indented the same as source: in that section:
        dump_entity: ['device_75','device_139']
      This will create two files in logs called vera-device_75.json and vera-device_139.json. Please post them here or in a PR.
        I've posted the files here
        https://reactor.toggledbits.com/mantisbt/view.php?id=233
          OK. I think I've got it sorted. Build later today.
            OK. Build 21203 is available.
              @toggledbits said in Vera - Attempt to set primary to power_switch.state invalid:
              Just updated to this build and now my Ezlo Plus controller is missing in MSR and I have error alerts about missing devices.
              I can see this in the log:
              2021-07-23T08:44:19.384Z <Structure:WARN> Structure#1 findEntity ezlo-plus>device_60e4a54a120bab11f9d77f67 controller undefined not found
              2021-07-23T08:44:19.384Z <Structure:WARN> Structure#1 promiseEntity(ezlo-plus>device_60e4a54a120bab11f9d77f67,30000) timeout!
              2021-07-23T08:44:19.384Z <Rule:CRIT> Rule#rule-kr7n2q7p failed subscription to ezlo-plus>device_60e4a54a120bab11f9d77f67
              2021-07-23T08:44:19.385Z <Rule:CRIT> !timeout
              2021-07-23T08:44:19.385Z <Rule:5:Rule.js:703> Rule#rule-kr7n2q7p start() dependencies resolved, performing initial evaluation
              2021-07-23T08:44:19.386Z <Rule:5:Rule.js:962> Rule#rule-kr7n2q7p (Stairs Cupboard Door Closed) evaluate() acquiring mutex
              2021-07-23T08:44:19.387Z <Rule:5:Rule.js:966> Rule#rule-kr7n2q7p._evaluate() mutex acquired, evaluating
              2021-07-23T08:44:19.388Z <Rule:5:Rule.js:970> Rule#rule-kr7n2q7p update rate is 0/min limit 60/min
              2021-07-23T08:44:19.388Z <Rule:5:Rule.js:892> Rule#rule-kr7n2q7p evaluateExpressions() with 0 expressions
              2021-07-23T08:44:19.389Z <Structure:WARN> Structure#1 findEntity ezlo-plus>device_60e4a54a120bab11f9d77f67 controller undefined not found
              2021-07-23T08:44:19.392Z <Rule:CRIT> ReferenceError: Can't find entity ezlo-plus>device_60e4a54a120bab11f9d77f67
              I tried rebooting the Ezlo Plus controller but its still the same.
                That's too late in the log, so it's a downstream effect of whatever else happened. Look up higher, near the startup of Reactor. Look for the string "starting controller interface" and then follow down from there.
                  Patrick
                  <Structure:ERR> [Structure:start] failed to start controller ezlo-plus: Error: Cannot find module 'server/lib/Configuration'
                  Require stack:
                  - /home/stuart/reactor/server/lib/EzloController.js
                  2021-07-23T15:30:55.837Z <Structure:CRIT> Error: Cannot find module 'server/lib/Configuration'
                  2021-07-23T15:30:55.261Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController)
                  2021-07-23T15:30:55.272Z <Structure:INFO> Structure#1 starting controller interface vera-edge (VeraController)
                  2021-07-23T15:30:55.274Z <Structure:INFO> Structure#1 starting controller interface ezlo-plus (EzloController)
                  2021-07-23T15:30:55.276Z <Structure:INFO> Structure#1 starting controller interface weather (OWMWeatherController)
                  2021-07-23T15:30:55.279Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController)
                  2021-07-23T15:30:55.412Z <default:null> Module VeraController v21202
                  2021-07-23T15:30:55.436Z <default:null> Module OWMWeatherController v21140
                  2021-07-23T15:30:55.441Z <default:null> Module SystemController v21102
                  2021-07-23T15:30:55.452Z <VeraController:NOTICE> VeraController#vera starting
                  2021-07-23T15:30:55.596Z <VeraController:INFO> VeraController#vera loaded mapping ver 21202 rev 1 format 1 notice
                  2021-07-23T15:30:55.629Z <VeraController:NOTICE> VeraController#vera-edge starting
                  2021-07-23T15:30:55.641Z <Controller:CRIT> Controller: failed to load ezlo-plus implementation file:///home/stuart/reactor/server/lib/EzloController.js: Error: Cannot find module 'server/lib/Configuration'
                  Require stack:
                  2021-07-23T15:30:55.644Z <Controller:CRIT> Error: Cannot find module 'server/lib/Configuration'
                  Require stack:
                  Require stack:
                      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:885:15)
                      at Function.Module._load (internal/modules/cjs/loader.js:730:27)
                      at Module.require (internal/modules/cjs/loader.js:957:19)
                      at require (internal/modules/cjs/helpers.js:88:18)
                      at Object.<anonymous> (/home/stuart/reactor/server/lib/EzloController.js:527:157)
                      at Module._compile (internal/modules/cjs/loader.js:1068:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
                      at Module.load (internal/modules/cjs/loader.js:933:32)
                      at Function.Module._load (internal/modules/cjs/loader.js:774:14)
                      at ModuleWrap.<anonymous> (internal/modules/esm/translators.js:199:29)
                  2021-07-23T15:30:55.704Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                  2021-07-23T15:30:55.836Z <Structure:ERR> [Structure:start] failed to start controller ezlo-plus: Error: Cannot find module 'server/lib/Configuration'
                  Require stack:
                  Require stack:
                  Require stack:
                  2021-07-23T15:30:55.839Z <app:INFO> Structure running; pausing for controllers' initial ready
                  2021-07-23T15:30:56.081Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
                  2021-07-23T15:30:57.165Z <VeraController:NOTICE> Controller VeraController#vera-edge is now online.
                  2021-07-23T15:31:04.144Z <VeraController:NOTICE> Controller VeraController#vera is now online.
                  I don't know what happened? It was working fine for the Ezlo Plus yesterday on the prior MSR build.
                  This is what I see in that folder:
                    What install method are you using, and how are you starting MSR?
                      I downloaded the reactor-latest-21203-9503e5d.tar.gz file from this page: https://reactor.toggledbits.com/download/latest/
                      I copied it to my Linux machine in this folder: /home/stuart
                      I then SSH in to the box with Putty and run these commands one by one, as root user:
                      cd /home/stuart
                      pkill -QUIT node
                      tar xzvf /home/stuart/reactor-latest-21203-9503e5d.tar.gz
                      sudo systemctl start reactor
                      This is the way I've always updated MSR. Except you now have a new download page.
                      Only slightly different thing about when I did it this morning, was that the downloaded file was called:
                      All the other ones prior had "generic" in their names, but I figured it likely didn't matter and maybe you'd just omitted that from the file name etc.
                      Regarding starting MSR nothing has change there either.
                      In this directory: /etc/systemd/system
                      There is a file called: reactor.service
                      # This file allows you to run your Reactor installation under systemd,
                      # so it can be started at boot. Copy this file (as root or under sudo)
                      # to /etc/systemd/system, and then run "systemctl daemon-reload". You
                      # can then able Reactor to start at boot "systemctl enable reactor".
                      # The usual systemctl subcommands can also be used to start, stop, and
                      # restart reactor at will (e.g. "systemctl restart reactor").
                      [Unit]
                      Description=Multi System Reactor
                      After=network.target
                      [Service]
                      Type=simple
                      User=stuart
                      WorkingDirectory=/home/stuart/reactor
                      ExecStart=/usr/bin/node app -p
                      Restart=on-failure
                      RestartSec=5s
                      [Install]
                      WantedBy=multi-user.target
                        Add above WorkingDirectory:
                        Environment=NODE_PATH=/home/stuart/reactor
                        and then:
                        sudo systemctl daemon-reload
                        sudo systemctl restart reactor
                          and then:
                          Appears to have done the trick the Ezlo-Plus controller is back again in Entities.
                            159.9k
