reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
[Solved] Reboot option (bug?)
I have a scene to reboot my Vera weekly. I may not need it as much now that I am fully on MSR, but to keep Vera snappy, I'll keep it. Anyway, I moved this scene to a MSR rule using the sys_system.reboot option. This doesn't appear to work though. I tried manually running the reaction as well as setting it to run at a schedule time. I changed it to use lua code and use os.execute "reboot" and it rebooted upon manually running the reaction.
Not yet implemented, and when it is, it will be renamed to restart and just do a Luup reload. Your Lua alternative is correct for your objective.
