  4. Not all options available when creating a new rule
4 Posts 2 Posters 750 Views 2 Watching
  • J Offline
    J Offline
    jsimmo
    @togglebits,
    Not sure when this happened, but now when I create a new rule I get the boxes open up for Triggers and Set Reaction only. Clicking in any of the Constraints, Reset Reaction or Expressions boxes does not expand them and allow me to enter anything.
    I'm getting round it for now by copying an existing rule which has Triggers, Set Reactions, Reset Reactions and Expressions in it and then modifying this to be my new rule.
    Any thoughts on how to make these boxes available again?
    MSR is installed on a Raspberry Pi 4B (8GB) - Bare Metal (without Docker) and is the latest-21228-05d7497
      Icons missing... try doing npm update --no-save in your Reactor install directory, then restarting, then doing a hard refresh of the browser.
      J 1 Reply Last reply
        J Offline
        J Offline
        jsimmo
        No joy with that I'm afraid. This is the outcome of the update. Any clues here?
        pi@raspberrypi:~ $ cd ~/Documents/reactor
        pi@raspberrypi:~/Documents/reactor $ npm update --no-save
        npm WARN bootstrap@4.6.0 requires a peer of popper.js@^1.16.1 but none is installed. You must install peer dependencies yourself.
        • bootstrap-icons@1.5.0
        • jsdoc@3.6.7
        • influx@5.9.2
        • uuid@8.3.2
          added 25 packages from 23 contributors, updated 2 packages and audited 102 packages in 8.223s
        9 packages are looking for funding
        run npm fund for details
        found 1 moderate severity vulnerability
        run npm audit fix to fix them, or npm audit for details
        • diskusage-ng@1.0.2
          removed 25 packages, updated 1 package and audited 77 packages in 2.926s
        8 packages are looking for funding
        pi@raspberrypi:~/Documents/reactor $ sudo systemctl restart reactor
        • J Offline
          J Offline
          jsimmo
          OK. It's all good now. I rebooted my system and all my icons are back and I'm able to access all the options now. Thanks for your help.
            160.0k
