  4. Sorting arrays
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
Sorting arrays
8 Posts 2 Posters 1.7k Views 2 Watching
    When you train a rule or expression on a large number of devices, you're going to get activity when those devices change, and that can be a lot. There's more activity than you know, normally. Not everything gets logged at the default level. 21286 does contain a bit more logging.
    @toggledbits Master, following the discussion of this thread, the variable FaultMSG is composed with the list of devices that will be displayed, example below.
    As you can see, the final string of devices, not sorted by name, follows the array generated by the device ID, composed one step earlier.
    Is it possible to sort by device name? Before generating the string? I think when generating the array?
      This actually is a separate topic, so I forked it here...
      I'll need to add a sort() function to the expression language. This is something I've had on radar for a while, but doing it "right" is not as simple as one might think.
        OK. In build 21297 just released, there is now a sort() function in the expression language/library.
        FaultOn = sort( each id in FaultSensor: do e=getEntity( id ), e?.attributes?.x_vera_device?.failed == true ? e.name : null done )
        wmarcolinW 1 Reply Last reply
          @toggledbits there is an error in the expression.
          Expecting 'EOF', 'COMMA', 'EXPRSEP', ')', '-', 'POW', 'RANGE', '', '/', 'MOD', '+', '<<', '>>', '>>>', 'BAND', 'BOR', 'BXOR', 'LAND', 'LOR', '==', '!=', '===', '!==', 'IN', '<', '<=', '>', '>=', 'COALESCE', 'COALESCENAN', '?', 'ELSE', 'ENDIF', 'DONE', got 'COLON'
          Error: Parse error on line 1:
          ...ice?.failed == true : e.name : null done
          at Parser.parseError (C:\MSR\reactor\common\lexp.js:281:21)
          at Parser.parse (C:\MSR\reactor\common\lexp.js:348:22)
          at Object.evaluate (C:\MSR\reactor\common\lexp.js:1574:32)
          at Engine._eval_expr (C:\MSR\reactor\server\lib\Engine.js:934:413)
          at Engine.evaluateGlobalExpression (C:\MSR\reactor\server\lib\Engine.js:1135:115)
          at Immediate._onImmediate (C:\MSR\reactor\server\lib\Engine.js:1149:35)
          at processImmediate (node:internal/timers:464:21)
          [latest-21297]2021-10-24T22:00:57.220Z Engine:ERR Engine#1: error evaluating expression FaultOn: Error: Parse error on line 1:
          [latest-21297]2021-10-24T22:00:57.220Z Engine:ERR Engine#1: expression: sort( each id in FaultSensor: do e=getEntity( id ), e?.attributes?.x_vera_device?.failed == true : e.name : null done )
          [latest-21297]2021-10-24T22:00:57.221Z Engine:ERR Engine#1: path FaultMSG->FaultOn
          [latest-21297]2021-10-24T22:00:57.223Z Engine:CRIT Error: Parse error on line 1:
          Expecting 'EOF', 'COMMA', 'EXPRSEP', ')', '-', 'POW', 'RANGE', '*', '/', 'MOD', '+', '<<', '>>', '>>>', 'BAND', 'BOR', 'BXOR', 'LAND', 'LOR', '==', '!=', '===', '!==', 'IN', '<', '<=', '>', '>=', 'COALESCE', 'COALESCENAN', '?', 'ELSE', 'ENDIF', 'DONE', got 'COLON'
          at Engine._expr_resolve (C:\MSR\reactor\server\lib\Engine.js:1185:38)
          at _resolve (C:\MSR\reactor\common\lexp.js:1172:35)
          at _run (C:\MSR\reactor\common\lexp.js:1205:31)
          at _run (C:\MSR\reactor\common\lexp.js:1430:38)
          at C:\MSR\reactor\common\lexp.js:1424:33
            Sorry, see edit in my prior post.
              @toggledbits I updated the expression, and the syntax error disappeared. I see that it now returns the name directly in the array and no the ID...
              .. but continues following the ID sequence, no sort.
                OK. Pull the latest release package (again) and try it. I respun the release. Sorting is locale-specific, not that that would affect you since you're likely using the default locale, but it changes the way things work internally and makes it more complicated, and I missed a parameter on a call.
                  @toggledbits PERFECT!!!
                  Well, now it's time to review everything I had before and put it in order 😁
                  And best of all, remember that I did 3 steps:
                  1. List of all devices;
                  2. Applying the rule, like battery level;
                  3. Generate a string to send by message putting the device name.
                  Now, with the sort get the name, I can eliminate the third variable, and using format() generate the message directly, SHOW!!
                  The game is getting fun.
                  It's going to be a long night 🙂
                    164.4k
