reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Fibaro Modules "Scene Activation" How to here
Looks good. This can apply to a variety of scene controllers, not just Fibaro, and one of the vexing things about that is the variables that are set depend heavily on what engineer implemented the device support in the firmware -- there's no consistency. So for some devices, it may be that
sl_SceneActivatedneeds to be tested rather thanLastSceneID(which may not even exist). And for others it may besl_CentralScene.A good way to figure out what you need to watch (and set/reset) is to open the detail panel for the entity in the Entities list and play with it. Watch what attributes are changing and how.
Double Switch Click as Trigger
