  4. MQTTController "tasmota_generic_relay" power_switch.state always false
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
9 Posts 2 Posters 1.6k Views 2 Watching
    I can't get power_switch.state to reflect current state in the UI for Tasmota sonoff basic/dual/4channel pro.
    It triggers a green glow in the Entities for the device but the value is never changed to true.
    Config:
    "larmlampa_takfläkt_hall":
      name: "Larmlampa Takfläkt Hall"
      topic: "TakfläktHall"
      unit: "1"
      uses_template: tasmota_generic_relay
    Log:
    [latest-21314]2021-11-16T18:03:02.003Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=tele/TakfläktHall/STATE, payload={"Time":"2021-11-16T19:03:00","Uptime":"35T11:31:51","Vcc":3.170,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Orion","RSSI":52,"APMac":"60:F4:45:E7:68:E6"}}
    [latest-21314]2021-11-16T18:03:02.006Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=openLuup/update/30009/TakfläktHall/tele, payload={"Time":"2021-11-16T19:03:00","Uptime":"35T11:31:51","Vcc":3.170,"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Orion","RSSI":52,"APMac":"60:F4:45:E7:68:E6"}}
    [latest-21314]2021-11-16T18:03:02.007Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=openLuup/update/30009/TakfläktHall/Uptime, payload=35T11:31:51
    [latest-21314]2021-11-16T18:03:02.008Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=openLuup/update/30009/TakfläktHall/Time, payload=2021-11-16T19:03:00
    [latest-21314]2021-11-17T10:30:48.246Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=cmnd/TakfläktHall/POWER2, payload=
    [latest-21314]2021-11-17T10:30:48.246Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=cmnd/TakfläktHall/POWER1, payload=
    [latest-21314]2021-11-17T10:30:48.247Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/RESULT, payload={"POWER2":"OFF"}
    [latest-21314]2021-11-17T10:30:48.247Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for takfläkt_hall: {"POWER2":"OFF"}
    [latest-21314]2021-11-17T10:30:48.249Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for larmlampa_takfläkt_hall: {"POWER2":"OFF"}
    [latest-21314]2021-11-17T10:30:48.297Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/POWER2, payload=OFF
    [latest-21314]2021-11-17T10:30:48.298Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/POWER2 for takfläkt_hall: OFF
    [latest-21314]2021-11-17T10:30:48.298Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/RESULT, payload={"POWER1":"OFF"}
    [latest-21314]2021-11-17T10:30:48.298Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for takfläkt_hall: {"POWER1":"OFF"}
    [latest-21314]2021-11-17T10:30:48.298Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for larmlampa_takfläkt_hall: {"POWER1":"OFF"}
    [latest-21314]2021-11-17T10:30:48.304Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/POWER1, payload=OFF
    [latest-21314]2021-11-17T10:30:48.304Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/POWER1 for larmlampa_takfläkt_hall: OFF
    [latest-21314]2021-11-17T10:30:50.592Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/RESULT, payload={"POWER1":"ON"}
    [latest-21314]2021-11-17T10:30:50.593Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for takfläkt_hall: {"POWER1":"ON"}
    [latest-21314]2021-11-17T10:30:50.593Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for larmlampa_takfläkt_hall: {"POWER1":"ON"}
    [latest-21314]2021-11-17T10:30:50.596Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/POWER1, payload=ON
    [latest-21314]2021-11-17T10:30:50.597Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/POWER1 for larmlampa_takfläkt_hall: ON
    [latest-21314]2021-11-17T10:30:52.585Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/RESULT, payload={"POWER1":"OFF"}
    [latest-21314]2021-11-17T10:30:52.586Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for takfläkt_hall: {"POWER1":"OFF"}
    [latest-21314]2021-11-17T10:30:52.587Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for larmlampa_takfläkt_hall: {"POWER1":"OFF"}
    [latest-21314]2021-11-17T10:30:52.588Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/POWER1, payload=OFF
    [latest-21314]2021-11-17T10:30:52.588Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/POWER1 for larmlampa_takfläkt_hall: OFF
    I've also tried some best guessing with a custom template without success, probably because of lacking knowledge from my side.
    OT: Is ìnit in an upcoming build? Because how to handle a system restart is my next puzzle.
    CrilleC 1 Reply Last reply
      Can you turn your log level for MQTTController up to 5 or 6 and try again?
      I suspect I know what the problem is: the special characters in your device ID. There are several points where this could be a problem, but I can't discern which at the current low log level. It may be something simpler, though. Restart MSR, manipulate your device, and let's see if we can get a better view.
        Was at log level 5 in first post. This is log level 7:
        [latest-21314]2021-11-17T13:47:13.971Z <MQTTController:7:MQTTController.js:99> MQTTController#mqtt registering takfläkt_hall for stat/TakfläktHall/RESULT
        [latest-21314]2021-11-17T13:47:13.972Z <MQTTController:7:MQTTController.js:99> MQTTController#mqtt registering takfläkt_hall for stat/TakfläktHall/POWER2
        [latest-21314]2021-11-17T13:47:13.972Z <MQTTController:7:MQTTController.js:99> MQTTController#mqtt registering larmlampa_takfläkt_hall for stat/TakfläktHall/RESULT
        [latest-21314]2021-11-17T13:47:13.972Z <MQTTController:7:MQTTController.js:99> MQTTController#mqtt registering larmlampa_takfläkt_hall for stat/TakfläktHall/POWER1
        [latest-21314]2021-11-17T13:47:14.101Z <MQTTController:7:MQTTController.js:283> MQTTController#mqtt sending takfläkt_hall query cmnd/TakfläktHall/POWER2
        [latest-21314]2021-11-17T13:47:14.101Z <MQTTController:7:MQTTController.js:283> MQTTController#mqtt sending larmlampa_takfläkt_hall query cmnd/TakfläktHall/POWER1
        [latest-21314]2021-11-17T13:47:14.109Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=cmnd/TakfläktHall/POWER2, payload=
        [latest-21314]2021-11-17T13:47:14.115Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=cmnd/TakfläktHall/POWER1, payload=
        [latest-21314]2021-11-17T13:47:14.144Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/RESULT, payload={"POWER2":"OFF"}
        [latest-21314]2021-11-17T13:47:14.145Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/RESULT to takfläkt_hall
        [latest-21314]2021-11-17T13:47:14.145Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for takfläkt_hall: {"POWER2":"OFF"}
        [latest-21314]2021-11-17T13:47:14.147Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/RESULT to larmlampa_takfläkt_hall
        [latest-21314]2021-11-17T13:47:14.147Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for larmlampa_takfläkt_hall: {"POWER2":"OFF"}
        [latest-21314]2021-11-17T13:47:14.166Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/POWER2, payload=OFF
        [latest-21314]2021-11-17T13:47:14.167Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/POWER2 to takfläkt_hall
        [latest-21314]2021-11-17T13:47:14.167Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/POWER2 for takfläkt_hall: OFF
        [latest-21314]2021-11-17T13:47:14.194Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/RESULT, payload={"POWER1":"OFF"}
        [latest-21314]2021-11-17T13:47:14.195Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/RESULT to takfläkt_hall
        [latest-21314]2021-11-17T13:47:14.195Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for takfläkt_hall: {"POWER1":"OFF"}
        [latest-21314]2021-11-17T13:47:14.195Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/RESULT to larmlampa_takfläkt_hall
        [latest-21314]2021-11-17T13:47:14.195Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for larmlampa_takfläkt_hall: {"POWER1":"OFF"}
        [latest-21314]2021-11-17T13:47:14.202Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/POWER1, payload=OFF
        [latest-21314]2021-11-17T13:47:14.202Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/POWER1 to larmlampa_takfläkt_hall
        [latest-21314]2021-11-17T13:47:14.202Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/POWER1 for larmlampa_takfläkt_hall: OFF
        [latest-21314]2021-11-17T13:47:17.110Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/RESULT, payload={"POWER1":"ON"}
        [latest-21314]2021-11-17T13:47:17.111Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/RESULT to takfläkt_hall
        [latest-21314]2021-11-17T13:47:17.112Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for takfläkt_hall: {"POWER1":"ON"}
        [latest-21314]2021-11-17T13:47:17.113Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/RESULT to larmlampa_takfläkt_hall
        [latest-21314]2021-11-17T13:47:17.114Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for larmlampa_takfläkt_hall: {"POWER1":"ON"}
        [latest-21314]2021-11-17T13:47:17.117Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/POWER1, payload=ON
        [latest-21314]2021-11-17T13:47:17.117Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/POWER1 to larmlampa_takfläkt_hall
        [latest-21314]2021-11-17T13:47:17.118Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/POWER1 for larmlampa_takfläkt_hall: ON
        [latest-21314]2021-11-17T13:47:18.828Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/RESULT, payload={"POWER1":"OFF"}
        [latest-21314]2021-11-17T13:47:18.828Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/RESULT to takfläkt_hall
        [latest-21314]2021-11-17T13:47:18.829Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for takfläkt_hall: {"POWER1":"OFF"}
        [latest-21314]2021-11-17T13:47:18.830Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/RESULT to larmlampa_takfläkt_hall
        [latest-21314]2021-11-17T13:47:18.831Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/RESULT for larmlampa_takfläkt_hall: {"POWER1":"OFF"}
        [latest-21314]2021-11-17T13:47:18.835Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/TakfläktHall/POWER1, payload=OFF
        [latest-21314]2021-11-17T13:47:18.836Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/TakfläktHall/POWER1 to larmlampa_takfläkt_hall
        [latest-21314]2021-11-17T13:47:18.837Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/TakfläktHall/POWER1 for larmlampa_takfläkt_hall: OFF
          OK. Can you try changing the device ID, just for this test, to something with only lower half (<127) ASCII characters? That is, no international. You'll need to adjust your config to match as well, of course.
            Yes, made no difference though. See post below instead.
            [latest-21314]2021-11-17T14:09:02.639Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/takflakthall/RESULT, payload={"POWER1":"ON"}
            [latest-21314]2021-11-17T14:09:02.640Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampa_takflakt_hall
            [latest-21314]2021-11-17T14:09:02.641Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampa_takflakt_hall: {"POWER1":"ON"}
            [latest-21314]2021-11-17T14:09:02.650Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/takflakthall/POWER1, payload=ON
            [latest-21314]2021-11-17T14:09:02.651Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampa_takflakt_hall
            [latest-21314]2021-11-17T14:09:02.651Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampa_takflakt_hall: ON
            [latest-21314]2021-11-17T14:09:03.644Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/takflakthall/RESULT, payload={"POWER1":"OFF"}
            [latest-21314]2021-11-17T14:09:03.644Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampa_takflakt_hall
            [latest-21314]2021-11-17T14:09:03.645Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampa_takflakt_hall: {"POWER1":"OFF"}
            [latest-21314]2021-11-17T14:09:03.649Z <MQTTController:5:MQTTController.js:176> MQTTController#mqtt message topic=stat/takflakthall/POWER1, payload=OFF
            [latest-21314]2021-11-17T14:09:03.650Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampa_takflakt_hall
            [latest-21314]2021-11-17T14:09:03.650Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampa_takflakt_hall: OFF
            FYI: My AM2301 sensor is reporting fine with ID "källartemp" and topic "Källartemp"
            • CrilleC Crille
              Ok, now I'm getting more info, hope this is better.
              [latest-21314]2021-11-17T14:13:51.569Z <MQTTController:5:MQTTController.js:58> MQTTController#mqtt configuring entity larmlampatakflakthall
              [latest-21314]2021-11-17T14:13:51.569Z <MQTTController:6:MQTTController.js:71> MQTTController#mqtt created new entity for larmlampatakflakthall
              [latest-21314]2021-11-17T14:13:51.569Z <MQTTController:7:MQTTController.js:99> MQTTController#mqtt registering larmlampatakflakthall for stat/takflakthall/RESULT
              [latest-21314]2021-11-17T14:13:51.569Z <MQTTController:7:MQTTController.js:99> MQTTController#mqtt registering larmlampatakflakthall for stat/takflakthall/POWER1
              [latest-21314]2021-11-17T14:13:51.724Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt sending queries for larmlampatakflakthall: [ "cmnd/%topic%/POWER%unit%" ]
              [latest-21314]2021-11-17T14:13:51.724Z <MQTTController:7:MQTTController.js:283> MQTTController#mqtt sending larmlampatakflakthall query cmnd/takflakthall/POWER1
              [latest-21314]2021-11-17T14:13:51.794Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:13:51.794Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"OFF"}
              [latest-21314]2021-11-17T14:13:51.795Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:13:51.795Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:13:51.854Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:13:51.854Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: OFF
              [latest-21314]2021-11-17T14:13:51.854Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:13:51.854Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:14:00.895Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:00.895Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"ON"}
              [latest-21314]2021-11-17T14:14:00.895Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:14:00.895Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=true
              [latest-21314]2021-11-17T14:14:00.896Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:00.896Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: ON
              [latest-21314]2021-11-17T14:14:00.896Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:14:00.896Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:14:04.396Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:04.397Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"OFF"}
              [latest-21314]2021-11-17T14:14:04.397Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:14:04.397Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:14:04.411Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:04.411Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: OFF
              [latest-21314]2021-11-17T14:14:04.411Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:14:04.411Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:14:06.495Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:06.495Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"ON"}
              [latest-21314]2021-11-17T14:14:06.495Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:14:06.495Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=true
              [latest-21314]2021-11-17T14:14:06.501Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:06.501Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: ON
              [latest-21314]2021-11-17T14:14:06.501Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:14:06.501Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:14:07.877Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:07.877Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"OFF"}
              [latest-21314]2021-11-17T14:14:07.878Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:14:07.878Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:14:08.601Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:08.601Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: OFF
              [latest-21314]2021-11-17T14:14:08.602Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:14:08.603Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:14:59.496Z <MQTTController:5:MQTTController.js:58> MQTTController#mqtt configuring entity larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:59.496Z <MQTTController:6:MQTTController.js:71> MQTTController#mqtt created new entity for larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:59.497Z <MQTTController:7:MQTTController.js:99> MQTTController#mqtt registering larmlampatakflakthall for stat/takflakthall/RESULT
              [latest-21314]2021-11-17T14:14:59.497Z <MQTTController:7:MQTTController.js:99> MQTTController#mqtt registering larmlampatakflakthall for stat/takflakthall/POWER1
              [latest-21314]2021-11-17T14:14:59.628Z <MQTTController:6:MQTTController.js:278> MQTTController#mqtt sending queries for larmlampatakflakthall: [ "cmnd/%topic%/POWER%unit%" ]
              [latest-21314]2021-11-17T14:14:59.629Z <MQTTController:7:MQTTController.js:283> MQTTController#mqtt sending larmlampatakflakthall query cmnd/takflakthall/POWER1
              [latest-21314]2021-11-17T14:14:59.673Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:59.674Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"OFF"}
              [latest-21314]2021-11-17T14:14:59.674Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:14:59.675Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:14:59.724Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:14:59.724Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: OFF
              [latest-21314]2021-11-17T14:14:59.724Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:14:59.724Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:21.321Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:21.321Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"ON"}
              [latest-21314]2021-11-17T14:15:21.321Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:21.321Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=true
              [latest-21314]2021-11-17T14:15:21.370Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:21.370Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: ON
              [latest-21314]2021-11-17T14:15:21.370Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:21.370Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:23.994Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:23.995Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"OFF"}
              [latest-21314]2021-11-17T14:15:23.996Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:23.996Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:24.000Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:24.000Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: OFF
              [latest-21314]2021-11-17T14:15:24.001Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:24.002Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:26.029Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:26.029Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"ON"}
              [latest-21314]2021-11-17T14:15:26.030Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:26.031Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=true
              [latest-21314]2021-11-17T14:15:26.033Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:26.034Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: ON
              [latest-21314]2021-11-17T14:15:26.034Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:26.035Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:28.869Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:28.869Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"OFF"}
              [latest-21314]2021-11-17T14:15:28.869Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:28.870Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:28.873Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:28.873Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: OFF
              [latest-21314]2021-11-17T14:15:28.873Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:28.873Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:34.207Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:34.207Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"ON"}
              [latest-21314]2021-11-17T14:15:34.207Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:34.207Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=true
              [latest-21314]2021-11-17T14:15:34.256Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:34.256Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: ON
              [latest-21314]2021-11-17T14:15:34.256Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:34.256Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:36.623Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:36.623Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"OFF"}
              [latest-21314]2021-11-17T14:15:36.624Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:36.624Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:36.627Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:36.627Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: OFF
              [latest-21314]2021-11-17T14:15:36.628Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:36.628Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:38.599Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:38.599Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"ON"}
              [latest-21314]2021-11-17T14:15:38.599Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:38.600Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=true
              [latest-21314]2021-11-17T14:15:38.603Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:38.603Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: ON
              [latest-21314]2021-11-17T14:15:38.604Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:38.604Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:50.196Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:50.196Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"OFF"}
              [latest-21314]2021-11-17T14:15:50.196Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:50.196Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:50.247Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:50.247Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: OFF
              [latest-21314]2021-11-17T14:15:50.247Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:50.247Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:52.262Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:52.263Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"ON"}
              [latest-21314]2021-11-17T14:15:52.264Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:52.265Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=true
              [latest-21314]2021-11-17T14:15:52.268Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:52.268Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: ON
              [latest-21314]2021-11-17T14:15:52.269Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:52.269Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:56.795Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/RESULT to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:56.795Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/RESULT for larmlampatakflakthall: {"POWER1":"OFF"}
              [latest-21314]2021-11-17T14:15:56.796Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "if_expr": "! isnull( payload[ \"POWER\" + str(unit) ] )", "expr": "upper( payload[ \"POWER\" + str(unit) ] ) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:56.796Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              [latest-21314]2021-11-17T14:15:56.800Z <MQTTController:6:MQTTController.js:206> MQTTController#mqtt dispatching stat/takflakthall/POWER1 to larmlampatakflakthall
              [latest-21314]2021-11-17T14:15:56.800Z <MQTTController:5:MQTTController.js:304> MQTTController#mqtt handling stat/takflakthall/POWER1 for larmlampatakflakthall: OFF
              [latest-21314]2021-11-17T14:15:56.800Z <MQTTController:7:MQTTController.js:338> MQTTController#mqtt entity larmlampatakflakthall attribute power_switch.state source { "expr": "upper(message) == \"ON\"" }
              [latest-21314]2021-11-17T14:15:56.800Z <MQTTController:6:MQTTController.js:391> MQTTController#mqtt setting Entity#mqtt>larmlampatakflakthall power_switch.state=false
              It flickers to true once with the first ON, then back to false and stays there when toggled.
              EDIT: I created a rule with true as trigger and it triggers every time when relay is turned on but the power_switch.state returns to false immediately.
              • CrilleC Crille
                @toggledbits This seems to do the trick:
                 my_tasmota_generic_relay:
                    type: Switch
                    capabilities: ['power_switch', 'toggle']
                    primary_attribute: power_switch.state
                    query: "cmnd/%topic%/POWER%unit%"
                    events:
                      "stat/%topic%/RESULT":
                        "power_switch.state":
                          if_expr: "! isnull( payload[ 'POWER' + str(unit) ] )"
                          expr: "upper( payload[ 'POWER' + str(unit) ] ) == 'ON'"
                      "stat/%topic%/POWER%unit%":
                          expr: "upper(payload) == 'ON'"
                    actions:
                      power_switch:
                        "on":
                          topic: "cmnd/%topic%/Power%unit%"
                          payload: "on"
                        "off":
                          payload: "off"
                        set:
                          payload:
                            expr: "parameters.state ? 'on' : 'off'"
                            type: raw
                      toggle: "cmnd/%topic%/Power%unit% toggle"
                Switching the ' and " in expr and changing to upper(payload) instead of upper(message)
                This works with international characters in the ID as well.
                • CrilleC Crille
                  Config:
                    unit: "1"
                  Log:
                  @crille said in MQTTController "tasmota_generic_relay" power_switch.state always false:
                  @toggledbits Last question before I mark this as solved. Is ìnit available in build 21319?
                    No, not yet. Probably in a couple of hours.
                    • CrilleC Crille marked this topic as a question on
                    • CrilleC Crille has marked this topic as solved on
                      163.6k
