  4. Pick the middle of 3 values.
  • Tom_DT Offline
    Tom_DT Offline
    Tom_D
    I have 3 outside temperatures and I would like to pick the middle value of the 3 to use as the outside air temperature for calculations and logic.
    The obvious, to me, mid() function does not seem to exist. What function can I use to pick the middle of the three values?
    Thanks,
    Tom
    latest-25082-3c348de6
      Do you mean arithmetic mean (often called average), or median?
      • Tom_DT Offline
        Tom_DT Offline
        Tom_D
        Median. Get rid of the high and low value.
          I'll add a median() function to the expression language. In the meanwhile, this should work:
          define average( arr ) sum( arr ) / count( arr ),
          define median( arr ) do
              t = sort( arr, $1 == $2 ? 0 : ( $1 < $2 ? -1 : 1 ) ),
              n = count( t ),
              n % 2 == 0 ?
                  average( slice( t, n/2-1, n/2+1 ) ) :
                  t[ floor( n/2 ) ]
          done,
          median( [ OutsideTemp, FrontOSATemp, PatioOSATemp ] )
          • Tom_DT Offline
            Tom_DT Offline
            Tom_D
            Thanks! That works.
            • Tom_DT Tom_D marked this topic as a question on
            • Tom_DT Tom_D has marked this topic as solved on
              152.8k
