  4. [Solved] Issue with matchEntities() in Expression using groups key for Dynamic Group
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
10 Posts 2 Posters 2.2k Views 2 Watching
    Following the docs:
    In expressions; dynamic groups can be referred to in the groups key of the matchEntities() function, or by passing the group's canonical ID to getEntity(). The former is probably preferable, as it's much easier to read and understand what is going on.
    Example in docs:
    each e in matchEntities({group:'groups>low_battery_entities'}): e.name
    each id in getEntity('groups>low_battery_entities').attributes.sys_group.members: getEntity( id ).name
    I set up a Dynamic group:
      - id: groups
        name: Dynamic Group Controller
        enable: true
        implementation: DynamicGroupController
        config:
          groups:
            "EzloDevicesNotResponding2":
              name: Ezlo Devices Not Responding
                - include_controller: ezlo
                - include_capability: x_ezlo_device
              filter_expression: entity.attributes.x_ezlo_device.reachable != true
    But when I try the Expression I get a compilation error
    Log:
    [latest-22004]2022-01-09T12:24:35.420Z <Engine:NOTICE> [Engine]Engine#1 expression testing has changed; recomputing dependencies
    [latest-22004]2022-01-09T12:24:35.421Z <Engine:ERR> [Engine]Engine#1: error evaluating expression testing: [ReferenceError]ReferenceError: Invalid reference to member name of ezlo>device_61baf610129e0725bd9f80f3
    [latest-22004]2022-01-09T12:24:35.422Z <Engine:ERR> [Engine]Engine#1: expression: each e in matchEntities({group:'groups>EzloDevicesNotResponding2'}): e.name
    [latest-22004]2022-01-09T12:24:35.422Z <Engine:5:Engine.js:960> [Engine]Engine#1: path testing->testing
    [latest-22004]2022-01-09T12:24:35.422Z <Engine:CRIT> ReferenceError: Invalid reference to member name of ezlo>device_61baf610129e0725bd9f80f3
        at _run (/home/homebridge/reactor/common/lexp.js:1411:31)
        at _run (/home/homebridge/reactor/common/lexp.js:1514:41)
        at /home/homebridge/reactor/common/lexp.js:1246:29
        at _run (/home/homebridge/reactor/common/lexp.js:1245:28)
        at run (/home/homebridge/reactor/common/lexp.js:1609:22)
        at Object.evaluate (/home/homebridge/reactor/common/lexp.js:1645:20)
        at Engine._eval_expr (/home/homebridge/reactor/server/lib/Engine.js:958:280)
        at Engine.notify (/home/homebridge/reactor/server/lib/Engine.js:644:142)
        at /home/homebridge/reactor/server/lib/MessageBus.js:106:223
    [latest-22004]2022-01-09T12:24:35.424Z <Engine:5:Engine.js:1000> [Engine]Engine#1 set global testing; value=(object)(null)
    When not referring to e.name It's an array with three members
    latest-22004-6d6c6b7 bare metal installation.
    What I'm I doing wrong?
      matchEntities() returns a list (array) of canonical IDs, not entity objects. You need:
      each id in matchEntities({group:'groups>low_battery_entities'}): getEntity( id ).name
        I suspected that, then consider this post a PR to change the example in the docs. Thank you!
          This is the example in the docs. I'm not seeing any issue here:
                  sensors = matchEntities( { controller: 'vera',
                    capability: [ 'binary_sensor', 'value_sensor' ] } )
                  low_battery = each e in sensors:
                                  getEntity( e ).attributes.battery_power?.level < 0.5 ? e : null
          sensors is handled as an array of canonical IDs by the second expression. Is there another place in the docs you are referring to that I'm not thinking of?
            Yes, at the bottom of the page under "Using Dynamic Groups".
            Also referred to at the beginning of my first post.
              OK. I was looking at the Expressions docs.
              Edit: changes will make their way into the next release, along with strong messaging that dynamic groups should be used in preference to matchEntities() for group filtering (you can still use it to get the group members, but let DynamicGroupController do the hard work). DGC is much more efficient (and flexible) in its filtering, by design.
                So to get the names in an Expression for a notification, is it still preferred to use do..done or just getEntity(id).name?
                  Confusing. The only way to get the name (currently) is through getEntity(). The do...done statement doesn't enter into it; it's just a language construction that may or may not be needed in the expression as written. I think you're thinking of each...in, which is how you iterate over an array, so yes, if you have an array of entity IDs, you'll need each...in and getEntity() together to make a list of them.
                    Sorry for assuming you remember every post you ever made 😆
                    I was referring to this excellent advice
                    I guess it’s not necessary when I only do one getEntity for the name.
                      Ah, yes... if you need to reuse the fetched entity several times, it's definitely better to use a do...done block as the loop body and keep the result of getEntity() in a local variable, so you're only doing that fetch one time. You can then use the local variable as many times as needed... a cache of sorts. I'm with you...
                        165.6k
