  4. [SOLVED]. Build 22021-f83a39c Status page is blank
9 Posts 3 Posters 1.5k Views 3 Watching
    Using Brave browser (which triggers on nothing shield-wise) clicking thru to Status page nets me a blank main portion of the page. Left pane all good, top bar all good. Doubled-check with Safari browser, same outcome.
    The notification bell is also red... but I can't get to the Status page to see what it's on about! 🙂
    I did go re-read the release notes just in case I missed a "and do this thing" but didn't see anything. I do have a log I pulled after doing a Restart Reactor but I see nothing jumping out at me.
        Bare metal... you need to update dependencies. From your Reactor directory, do npm i --no-save --omit dev
          @toggledbits Saw it - did it - all is WAI. Did I miss that verbiage - I'd swear I looked multiple times and did not see it.
            You didn't. I forgot to add it. I'm going to start recommending it for every upgrade.
              @toggledbits That's a relief - sanity still in check. Appreciate you jumping on that so quick - "Uh, everything's under control. Situation normal."
              I'll mark this as solved.
              • X Offline
                X Offline
                xAPPO
                wrote on last edited by xAPPO
                  That makes no sense. The Status page is all widgets, so "the status page... not updating... other widgets do" is... nonsense. Can't work from that.
                  X 1 Reply Last reply
                    X Offline
                    X Offline
                    xAPPO
                    @toggledbits Sorry - your support is too on the ball 👍 - I had deleted the post as I realized it was non sensical and created a new post
