  4. Ezlo Controller leak_detector supported for Influx-Feed?
4 Posts 2 Posters 785 Views 2 Watching
    Hi
    I added today a Centralite Zigbee Water Leak sensor device to my Ezlo Plus.
    I created a rule in MSR for when it detects water to alert me and that is all working fine no problems.
    I then wanted to add a panel in Grafana to show the leak sensor status etc.
    The MSR user manual says that leak_detector is one of the default capabilities that will be exported.
    In Grafana I was able to find the new Water Leak sensor device and add it to a new panel. however it always says "No data".
    I tried various visualisation types and also for the field value tried mean, distinct, last etc but nothing ever appears data wise, tried Table View only and also changing the time range of the query.
    I have actually tested the Water Leak Sensor by putting water down underneath it and it does trip OK.
    I don't know how to directly query the InfluxDB, I only know how to add panels in Grafana to see the data.
      Looking in MSR in Entities for this device this is the output:
      arming.state=false
      battery_power.level=1
      battery_power.since=1643058392345
      leak_detector.state=false
      tamper.state=false
      x_ezlo_device.battery_powered=true
      x_ezlo_device.category="security_sensor"
      x_ezlo_device.manufacturer="CentraLite"
      x_ezlo_device.model="3315-G"
      x_ezlo_device.parent=""
      x_ezlo_device.reachable=true
      x_ezlo_device.ready=true
      x_ezlo_device.room="5f4e2f8c120bab1069c13c43"
      x_ezlo_device.status="idle"
      x_ezlo_device.subcategory="leak"
      x_ezlo_device.type_id="CentraLite_3315-G"
      x_ezlo_item.battery=100
      x_ezlo_item.security_threat=false
      x_ezlo_item.tampering_cover_alarm="no_tampering_cover"
      x_ezlo_item.water_leak_alarm="no_water_leak"
      x_ezlo_object.id="61eef16e120bab124d14462b"
      Capabilities: arming, battery_power, leak_detector, tamper, x_ezlo_device, x_ezlo_item, x_ezlo_object
      Actions: arming.arm, arming.disarm, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check
      Looks like leak_detector is a listed capability of the device.
        Never mind I was doing something dumb, under Select Measurement I hadn't clicked that and selected Leak Detector.
          No worries. Also noted, you can't use mean with non-numeric values, and that state is a boolean
            160.0k
