  4. Plugin InfluxFeed - some data missing
4 Posts 2 Posters 887 Views 2 Watching
    Using MSR 22028 on Synology Docker and InfluxDB 2.1.1. In reactor.yaml file I have in influx -section and under "select_capabilities"
    x_vera_svc_cd_jackson_com_SystemMonitor: true
    I don't see any errors in logs. However, in InfluxDB I can see only partial data about SystemMonitor:
    The actual values are missing... They show up fine on MSR:
    @toggledbits, how could I troubleshoot this further?
      If the measurement is available for you to choose, the data is there. The problem I think here may be that all Vera values are strings, and that gave 1.8 some heartburn when trying to handle them as numbers, and 2.x is worse. What I recommend is playing around in the explorer doing queries, dropping the group specifications and the aggregators (mean() and the like). Learning to use the explorer to sift through the data will (a) show that it's there, and (b) have long-term benefits in building other quieries and displays, so recommended.
      Also, you don't need to specify every filter on a measurement (controller, entity, name). Filtering to the entity alone is sufficient, since it's going to be a unique key for that purpose.
        @toggledbits thanks! Selecting "view raw data" reveals those strings that you mentioned. And float conversion (toFloat() in Flux) did the trick to show a graph.
        • tunnusT tunnus marked this topic as a question on
        • tunnusT tunnus has marked this topic as solved on
          Forgot to mention, the 22044 build includes some new InfluxDB measurement control capabilities. Documentation
            157.7k
