  4. [Solved]. Snipe hunting a missing entity
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
7 Posts 3 Posters 1.2k Views 3 Watching
    I'm getting these two alerts regarding an entity that cannot be found. Entirely possible as I cut some fat out of my Hubitat last week.
    I've confirmed in MSR that entity hubitat>161 doesn't exist, again, totally fine.
    My issue is trying to find the two rules impacted here. I seem to recall in past builds of MSR that there was a yellow triangle next to a ruleset if it had an issue like this but I've gone thru every ruleset and don't see this.
    Is there a means by which I can search by rule-kohw6jf2?
    wmarcolinW 1 Reply Last reply
      @gwp1
      In theory the rule that is using this device is Garage Door, search for it and you will certainly have this device within your process. The yellow triangle shows that the trigger has an error. Can you send a screen shot of this Garage Door rule?
        As @wmarcolin said, it's giving you the name of the rule, so it should be easy to find by name, rather than by ID. And the <SET> indication means it's in the SET reaction (and also RESET, apparently) of that rule (that's also the meaning of :S and :R on the rule IDs).
        • wmarcolinW wmarcolin
          @gwp1
          @wmarcolin I'm right with that theory... except I don't have a Reaction or ruleset named "Garage Door". I looked at any rules related to the garage door, especially those that happened at or near the time noted in the error.
          None of those ruleIDs match, however.
            Found it - it was a notification ruleset, well buried.
            Confirming, there's no indicator if the error is in the <SET> <RESET> portion of a ruleset, just a trigger?
              @gwp1
              The error you showed is in SET and RESET, you must be using this device that does not exist hubitat>161 in both.
              Can you send me a printout of the rule you found in the ruleset? Edit it and show how the configuration looks like.
                @gwp1
                @wmarcolin
                cfed25b0-2e93-49d5-b96d-8ffcedce36ff-image.png 3d808a0f-a6b4-4722-96bf-a0da86050911-image.png b131df05-d61f-42bb-a6fd-19f2336e9fbb-image.png
                a2013bf1-ee7c-4225-8d7e-5295f40cfc9f-image.png ce640840-fd72-43b1-9226-ac55cfa21e57-image.png
                Even though the Echo's are using "Announce All" you have to choose ONE as the entity. Seems the one I'd chosen here was one of the ones I've downsized from my account.
                  163.9k
